Question about Dual Electronics N99i Cellular Phone
Can't turn it on. The charger seems to be working cause the mobile turns hot while charging.
My N99i does not turn on, the charger seems to be working fine. But the mobile shows nothing on the screen. Is there any button were I can reset it? Tks!
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 158 Answers
Check the battery, it could be dead
Posted on May 25, 2009
  • Rodolfo Atun May 25, 2009
    check the battery, it could be dead
Trio Quad Core Tablet will not charge
Either the charger or the battery is faulty, from the sound of your fault description. If the tablet will turn on and run normally when the charger is plugged in, then the problem most likely lies with the battery. If it will not run even when the charger is on, then the charger is most likely the cause of the fault. If your tablet is still under warranty, either problem should be repaired free
Jan 01, 2015 | I-INC UniK Trio AXS 3G with Wifi 7.85"...
Xperia t not charging
Check the charges, the charger cable, its connectors and the connector on the phone. Everything should be clean and shiny. Not a speck of dust is allowed in any of the connectors. Use pressured air (in a can) to blow dust or a piece of paper out any contact. Never use sharp or metallic tools to pul out debris.
Perhaps you should also borrow a charger from someone else, to exclude the charger as cause of the problem.
If it is the phone, don't try to repair this yourself, if you don't have the skills.
Aug 02, 2014 | Sony Ericsson Sony Mobile Xperia T LT30p...
Motorola Fire XT (XT530) charging problem .
Motorola FIRE XT Tips for extending battery life
Back to Previous Page
Are there any tips on how to extend the battery life?
Things you should know about charging your battery.
New batteries are not fully charged. Plug the battery charger into your phone and an electrical outlet. Your phone might take several seconds to start charging the battery.
Tips:
  • It may take several charging cycles for your battery to reach optimum performance.
  • The battery charger shipped with this device is designed specifically for Motorola mobile phones. Other chargers might take longer to charge your battery, or cause your calls to fail during charging.
  • You can charge your phone via USB cable but this charging time will vary based on computer specifications.
Tips to extend battery life:
  • Select a shorter backlight duration
  • Lower the display brightness
  • Use the AC adapter to charge your phone whenever possible
  • Turn Bluetooth off when not in use
  • Turn Wi-Fi off when not in use
  • Close any third party applications running in the background
  • Playing music, videos and viewing images in your phone will affect your battery life
General Battery use & safety
  • Motorola recommends you always use Motorola-branded batteries and chargers. The warranty does not cover damage caused by non-Motorola batteries and/or chargers.
    Caution: Use of an unqualified battery or charger may present a risk of fire, explosion, leakage, or other hazard. Improper battery use, or use of a damaged battery, may result in a fire, explosion, or other hazard.
  • Your battery can be charged without it being fully depleted, and can be charged every day if desired.
  • Battery usage by children should be supervised.
  • Important: Motorola mobile devices are designed to work best with qualified batteries. If you see a message on your display such as Invalid Battery, Invalid Charger or Unable to Charge, take the following steps:
    • Remove the battery and inspect it to confirm that it bears a Motorola "Original Equipment" hologram;
    • If there is no hologram, the battery is not a qualified battery
    • If there is a hologram, replace the battery and retry charging it
    • If the message remains, contact a Motorola Authorized Service Center
  • New batteries or batteries stored for a long time may take more time to charge.
  • Charging precautions: When charging your battery, keep it near room temperature. Never expose batteries to temperatures below 0°C (32°F) or above 45°C (113°F) when charging. Always take your mobile device with you when you leave your vehicle
  • When storing your battery, keep it in a cool, dry place.
  • It is normal over time for battery life to decrease, and for the battery to exhibit shorter runtime between charges or require more frequent or longer charging times. Motorola batteries are designed to last between 350-700 charge/discharge cycles at room temperature. This amounts to approximately a year to a year and a half of battery use for most people.
  • Avoid damage to battery and mobile device. Do not disassemble, open, crush, bend, deform, puncture, shred, or submerge the battery or mobile device. Avoid dropping the battery or mobile device, especially on a hard surface. If your battery or mobile device has been subjected to such damage, take it to a local service center before using. Do not attempt to dry it with an appliance or heat source, such as a hair dryer or microwave oven.
  • Use care when handling a charged battery-particularly when placing it inside a pocket, purse, or other container with metal objects. Contact with metal objects (such as jewelry, keys, beaded chains) could complete an electrical circuit (short circuit), causing the battery to become very hot, which could cause damage or injury.
Apr 17, 2014 | Motorola Mobility XT530 Fire XT Black...
I have a golden 3 wheel scooter dose charger
If the charger is working correctly, it should turn itself off automatically (may go into float chrarge depending on type of charger). There should be an LED or an amp meter on the charger to tell you when the charge is complete. When the batteries are charged, you should be able to leave the charger switched on and it should cause no harm UNLESS the charger is faulty, in which case it will continue charging and damage the batteries. You should be able to tell if this is happening as the batteries will become very warm. If the batteries are losing their charge after you have switched the charger off, it is most likely that your batteries need replacing. Failing that, you may have a short somewhere which unfortunately, could be difficult to find.
Mar 10, 2010 | Electric Health & Beauty
AXS Mobility scooter loses battery power quickly.
hi , two problems can cause this,
1. batteries are weak, is the charger ok ? just because it 's green does not mean the charger is ok, can you validate the charge, try some other batteries ?,
2. Brake be activated or on at all times,
The best way to prove this is to remove the brake mech from the side of the motor completey now try the scooter, if the problem goes away then check the resistance of the brake, is it open or shorted ?
If you feel the brake, batteries and charger are working ok then the controller must be activating the brake and this is the fault but please double check the voltage on the brake leads.
Regards
GeWiz.
Jan 11, 2010 | Pride Mobility Products Go-Go Elite...
Charging only few minutes then have warning Bad charger contact
The charger seems to be Ok from your description. It seems that your connection in the phone is loose. Have it checked.
Jul 31, 2009 | Dual Electronics N99i Cellular Phone
N99i Warning bad connection charger
you can use just the usb cord connect it to your computer to charge the adapter for the wall mount is were your problem is occuring. I had the same issue.
Dec 05, 2008 | Dual Electronics N99i Cellular Phone
charger is broken...get a new charger or charge it on pc via usb cable provided....hope it helps you guys....
Nov 07, 2008 | Dual Electronics N99i Cellular Phone
My sidekick 3 won't turn on
Jake-
That is the right button. The charging port is probably bad. This is a common occurence on sidekick 3's. Does the orange light come on but it nevers seems like it is charging?
The best thing to do is get a edocking cradle that has an external battery charger. It will allow you charge the battery seperate form the phone.
See link below
http://fixmysidekick.com/shop/repair-replacement-parts-for-sidekick-3/Sidekick-3-Spare-Battery-Charger
Sep 10, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Dual Electronics N99i Cellular Phone Logo
125 people viewed this question
Top Dual Cell Phones Experts
William Alequin
270rexton
270rexton
iphone service
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
