Question about Polaroid TDA-03211C 32 in. LCD HDTV
Watched a video last night, put it on video mode, when i put it back on correct mode for satellite, got not signal. no matter what i do i get no signal
No signal eventhough it's on the right input mode
  • 822 Answers
Please check your cable properly. and your settings.
Posted on May 25, 2009
Yamaha Surround Sound HRT-6030
Hi!
maybe you select the Fader mode.. you simple select the fader balance to center then you hear the sounds coming out to the front fader mode.
Nov 16, 2007 | Yamaha HTR-6030 Receiver
I would like to have whole complete instruction for my CASIO G-Shock GW-500A. Especially I want to know how to get back that little radar image at the top right... Thank you.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
(The little "radar" image is an indication of the strength of the timing signal when the the signal was last transmitted. No image means the it did not receive a signal last night; a partial image means that a weak was received.)
Apr 18, 2011 | Watches
Component video problem. Hi I got the Denon AVR-3806 receiver and has it hooked up with a component cable to my background projection TV. To the reciever I have a satellite box connected also with a...
Just fixed this myself - made my head hurt to figure out. 1. Switch to a setting (say DVD). 2. Watch the AVR screen as it switches. You'll see the audio and video settings. For example, Audio = DVD, Video = DVD (Mine showed Audio = DVD, Video = DBS even though is was set correctly using the SETUP for audio and video)3. Under the round control knob on the left, push the (tiny) Video Select button. 4. Turn control know to choose the correct video source
Your system should work right. Mine did.
Jan 03, 2011 | Denon AVR-3806 Receiver
Let me be more specific on our problem. We installed the reciever according to directions. The 2 questions are: first, we have Dish Network. Isn't it possible to watch tv with the Yamaha reciever off with...
Look towards the back of the manual. You go into setup. Choose HDMI. Then there is another setting that you have to activate. The receiver must be set to the HDMI input that you want, before the receiver is turned off. I just installed my receiver last night and followed that procedure. Works great.
Oct 11, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
When I turn on the tv it automatically turns off itself
Back again. It appears that the key is the order in which you connect things and switch the TV on or off. It took some experimenting to get to what's reliable. I'll spare you the details and confine myself to what works.
1. Start with the monitor cable disconnected at the laptop.
2. Turn on the TV with the source set to your regular satellite (or cable) signal.
3. With the laptop on, plug the monitor cable into it.
4. Switch the source (at the TV) to receive the VGA signal (from the laptop).
Voila!
To turn off, reverse the procedure.
Mar 27, 2009 | Televison & Video
How do you set the time on a casio g shock watch????????
I had the same problem following recent daylight savings time (DST) change. The watch has three DST mode settings (ON, OFF, and AUTO). You get to the setting mode by pressing and holding the "adjust' button until the city time zone indicator starts to flash. Then press the "mode" button. This should give you the DST setting. Now press the "receive" button to cycle through the ON, OFF, and AUTO modes for DST. I set it for AUTO. I then existed the setting mode by pressing "adjust" again.
Now you can initiate a manual update of the time by pressing and holding the receive button. Put your watch by a window and make sure the signal strength indication is showing level 4 (full picture of satellite dish on my version). Give it a few minutes to down load new time.
After doing this the watch corrected itself and now shows correct time. Other wise I assume you could set the DST function to ON or OFF as well depending on whether you need to add or subtract the hour from the time.
Oct 26, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Deep Sleep
use the TV VIZEO remote to get out of RGB mode and go to hdmi2 and for me that ALWAYS works.  or whatever mode your cable is set to.  good luck
Sep 11, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Unable to record one tv channel while watching another tv channel
You CAN record one channel and watch another with satellite service, but it would require two separate DBS receivers. The issue is that all satellite broadcasting is encrypted until it hits the receiver, which decodes it and transmits it outward toward your other AV devices. If it weren't for the receiver, connecting the coax cable to your other devices and trying to tune channels with them would yield no signal and possibly much frustration. You would need to split the signal into each receiver and have one connected to the television via one input and the other to the recorder then to the TV via another input.
With cable, you can split the signal without having to have two boxes - this way the QAM tuner in the cable box is still capable of tuning channels while the recorder can tuner basic cable channels for recording separately. You can also have the cable box connected to the recorder via composite so that you can record premium stations on a DVD recorder input mode anytime you like - but you would have to be watching that channel at the same time unless the DVD recorder had a pass-through RF signal (rather than a composite clone) - meaning you could also use coaxial to your television from the recorder and tune channels separately on your television while the recorder is recording one channel.
A lot of what-ifs there, but it is all quite possible.
Mar 18, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Multiple video inputs
Unfortunately, you cannot use the connectors at the same time. The S-Video connector overrides the standard video connector. This is why they share common audio left/right inputs. If you could use them separately, they would each have their own set of audio inputs. (S-Video does not carry audio signals on the cable.) I'm assuming that you are connecting your Satellite as an input to your VCR, and then your VCR to the TV via a video connection. The VCR passes the satellite signal through unless you are watching a tape, then it overrides the dish signal. You have a few choices here: 1. You can connect the coaxial (RF) output from the VCR to the TV, and watch the satellite and VCR on channel 3 (or 4). You can then connect the DVD via S-Video, and watch it on "video". This is the simplest solution, and provides the best picture quality for the DVD (with this TV), but lower quality for the dish and VCR. 2. You can connect the DVD player via RF (if it supports that), watch the DVD on channel 3, and connect the VCR via video. This will make the DVD picture quality terrible. 3. You can replace the VCR with a combo DVD/VCR unit. You can then connect the S-Video out from the combo unit to the TV. This is a more expensive solution. 4. You can replace the TV with a model that includes more inputs. This is the most expensive solution, but will allow you to watch your DVD over component cables (very high quality) and VCR and dish over S-Video. Ironically, the obvious choice, connecting the DVD as an input to the VCR (as a pass-through) simply WON'T WORK. The signal put out by the DVD player is "copy protected" (using a system called MacroVision) which the VCR will refuse to play, even as a pass-though. Best of luck with this. Given that you are trying to make this all work without replacing equipment, I recommend option #1, until you decide to break down and buy a shiny new HDTV. They are coming down in price every week, but only you can decide when the time is right.
Mar 22, 2007 | Sony KV-32S26 32" TV
Polaroid TDA-03211C 32 in. LCD HDTV Logo
141 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
