Question about Dewalt D51321 3/4" 1 3/4" Heavy Duty Coil Roofing Nailer, 70 120 Psi
Roofing nailer not working
The plunger that forces the nail out is not returning for the next nail
    President:
  • Dewalt Master
  • 1,388 Answers
This problem is usually caused by two separate issues. Part # 631568 plate seal which is below the bumper and prevents air from leaking out the nose of the gun and forces the driver up. There is also the check seal which is a series of small holes drilled into the cylinder. These holes will be covered by orings or rubber band. Remove the head and pull out the cylinder, replace orings or band as needed. Good luck
Posted on Apr 02, 2015
  • 36 Answers
I dont know this particular piece of equipment but it sounds like a broken return spring
Posted on May 25, 2009
Plunger will not return on D 51823 nailer
Likely a nail jammed in the chute. The front of the nailer opens so you can pull the jammed nail out.
Sep 03, 2014 | Air Tools & Compressors
Hitachi nail gun
If gun firing but nails not being driven could be one of two basic problems:
1. Nail jammed in magazine not allowing nails to move up.
Empty magazine, does follower move to top of magazine. Push gun against work piece, does fan motor start? Yes - jam in magazine or lock out bar not operating. (this would allow nail un to fire when out of nails)
2. Piston/driver not returning fully after firing, hence driver blade on top of next nail instead of behind it. This could again be caused by a jammed nail or just a nail head. Another case of not returning is the combustion chamber not making a good seal, check O rings on framer (they are steel rings on bradders) it may just need a good clean it is surprising how dirty they can get and if not cleaned a build up of dirt could break a seal. If not been cleaned for a long time worth checking piston rings, worst case scenario dirt builds up around the rings and stick fully in requiring new piston if the rings will not come out.
Nail guns work on the principle that an explosion pushes the piston driver forcing a nail into the work piece, after the explosion a vacuum is created and it is this that 'sucks' the piston/driver back up the cylinder.
Mar 27, 2014 | Tools & Hardware - Others
I have a nail jammed in my Bostich coil roofing nailer
make sure nailer is unloaded loosen front slide remove nail and make sure plunger is all the way reset to top and reassemble
Mar 09, 2013 | Air Tools & Compressors
Nv45ab won't advance nails
The allen screw/s that you mention are there to plug holes where automatic equipment would normally connect (such as automatic nailing machines) . This is only a plug and should not be driven in too far. I have also seen allen screws installed in the head to repair small crack/s.
Jan 22, 2013 | Hitachi Air Tools & Compressors
Hitachi NV45AB won't advance nails
This problem could be caused by the head gasket fliped the wrong way not sealing small hole in the body. Also the head valve gasket (small round gasket between headvalve and head) could be place with vent hole mis-aligned. Check these two items and post again.
Jan 22, 2013 | Air Tools & Compressors
Porter-cable plunger extended and will not reload new nail
could be a jammed nail in the nose assembly, try removing all the nails and dry firing. If still the same after making sure nothing stuck in the nose, you probably have an issue with the firing valve or piston.
Dec 31, 2011 | Porter Cable Tools & Hardware - Others
When firing nailer first nail shoots good but next nails head will get stuck between the push rod chamber. push doesnt seem to return fully top when nail is cycled.
Try oiling the tool first. Remove the nails, squirt a decent amount of air tool oil in the stem where the air hose coupler connects, and fire the tool a dozen times or so. Then put in the nails and test. If it still hangs up then it will need the o-rings replaced.
Jun 11, 2011 | Porter Cable Coil Roofing Nailer
Air leaks around green cylinder at trigger area and nail plunger will not retract. this is a stanley bostich rn45b nailer
Your nailer uses a trigger valve (part # tva6 cost about $20) and is sold at www.bostitch.com or generic valves sold on ebay . If you have a source for orings, you could try to repair the valve. Remove the roll pin that holds the trigger to expose the tva6 valve. There are roll pin/pins that hold the valve in just above the valve in the body. Remove these pins and apply air pressure to gun to pop-out the valve. Use caution when you do this. Remove nails, lower pressure to gun and use glove or rag to catch valve because it could come out with force. With tva6 valve in hand remove two pins that hold valve together and remove inner plunger. The middle oring on plunger is cause of leak. Try using an oring about same size as the broken seat. It must fit pretty tight to work. If you had a small leak it could be that the firing pin orings fit too loose or just too worn. Use silicone lube or oring lube on the orings and the valve port. Good holidays.
Dec 02, 2010 | Stanley Bostitch Rn45b1 Industrial Coil...
GT90CH fires but no nail after twenty shots.
a bit of air tool oil might help, make sure you are not getting condensation in the line, otherwise you may have to dissassemble to clean
Jul 27, 2010 | Senco GT90 Clipped Head Gas Framing Nailer
Dewalt D51321 3/4" 1 3/4" Heavy Duty Coil Roofing Nailer, 70 120 Psi Logo
761 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
