Question about Broksonic TV
How to watch TV without cable , using antena
How can I watch TV with Rabbit ears. The TV seams to be on "analog'/Cable" I think I need to select Digital VHF but I'm not sure how to do it or if its necesary
  • 3 Answers
Try to goto set up then autoprogram
Posted on May 25, 2009
No reception with rabbit ears
Check to see if you have the "Rabbit ears" plugged into the correct spot and you are on "Analog tv" if you are trying to use digital tv on "Rabbit ears" it can't send out a strong signal like the areal ontop of a house. You may need to get an adapter to broadcast a stronger signal but even better if you can connect to roof antena.
Oct 24, 2012 | Panasonic TH-42PX6U Plasma TV
How do i use the built in antena on my tv?
Be sure you are tuned into 'over the air' signal. I would guess you are asking about the rabbit ears. Also there is a cable setting and satellite setting. Hope this will give a good start to watching over the air programing!
Apr 19, 2010 | Philips 32PF5531D 32 in. LCD Television
I am in Los Angeles,Ca. Converter box signal problem
Just go to walmart and buy a good digital antena.Should work great.Just rescan all ur channels again.
Mar 11, 2010 | Digi Sansonic FT-300A tal To Analog TV...
Westinghouse 32" TV NO Singal rabbit ears
Buy a digital antena,or a roof antena set it up plug it in,the in hole said Input or Ant..Go to the menu select where said Cable or Air.Select Air for free Air Tv.Scan for channels.
Sep 12, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Finds no channels
It is meant for Rabbit Ears or Outside Antenna Only.....
Jul 24, 2009 | Insignia Digital-to-Analog Converter for...
Digital Converter connection with old Rabbit Ears TV
First, make sure your connections are right. The rabbit ears need to be disconnected from the TV and reconnected to the converter box. Then the output cable from the converter box connects to the TV. Then try turning the rabbit ears or re-locating them near a window if the wire is long enough. You should be able to get some signal. A newer indoor antenna may help you pull in some of the weaker stations.
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
Analog or dtv
Hi, This tv has an NSTC tuner which is analog. If you subscribe to cable or satellite it will work just fine without you having to do anything for the upcoming change. However if you are using your own outside antenna or rabbit ears you will need a converter. Hope this helps.
Jan 30, 2009 | Philips 20PT6446 20" TV
Do I need an antena in order to use the new black box with my TV?
Yes, you need an antenna. Any set of rabbit ears will do. Don't pay extra for a "HDTV" antenna, there is no difference in the antenna for a digital or analog signal.
Jan 10, 2009 | Insignia Digital-to-Analog Converter for...
Sanyo dvw 5000 setup
If you rabit ears have a ribbon cable you will need a coax adaptor. Radio Shack carries them. If you cant find them, you might have to get a set of rabit ears that has coax wires. The antenna will plug into the cable in of the DVR. You take the coax output and plug that into the tv using a coax wire.
Aug 04, 2008 | Sanyo DVW-5000 DVD Player/VCR
TV without cable
Depending on how far you are from the broadcaster you can try Rabbit ears or and outside antenna.. If the set is more than two years old you may need a digital converter after Feb 17th
Mar 12, 2008 | RCA 27F500TDV 27 in. TV/VCR/DVD Combo
Broksonic TV Logo
150 people viewed this question
Top Broksonic Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
