Printer Duplex Function
We have a Toshiba e-Studio25s, with no instruction booklet. I was trying to program the machine to run duplex, and now the duplex function will not turn off. Can you please assist us?
Thank you!
Glenna Orman
Office Administrator
Camp Balcones Springs
Marble Falls, Texas
830.693.2267
    Problem Solver:
  • 8 Answers
Its highly unlikely you'll get a free answer on this web-site, so it's either fork over the money to these jokers or get an answer for free on another forum.
Posted on May 25, 2009
Hp p3005x - how to replace formatter board
This is a known issue that cannot be addressed through menus. What you need is a PJL (print job language) file that programs the formatter activate the duplex function. Does your configuration page show the correct serial number and page counts? If not then likely the formatter you purchased was used. If you provide serial number, page count I can provide you with the correct PJL file that will restore your duplex function.
Sep 16, 2014 | HP LaserJet P3005x Printer
Need step by step instructions on how to duplex with my mfc 8500
1. From your application, Choose the print command (in ms Word "Ctrl + p"C1. From you application, choose the print command (in ms Word "Ctrl + p")
2. Choose the name of your machine in the Print dialog box and click Properties.
3. Choose Duplex / Booklet in the Properties dialog box and click OK.
(see page 57 in the manual)
Download Manual Here
May 05, 2011 | Brother MFC-8500 All-In-One Laser Printer
Will not duplex - fails duplex quick test
Hello.
Here are some suggestions from Lexmark as to why the printer will not duplex:
The ability to select duplex printing requires the following:
  • -The printer must recognize the physical duplex option.
  • -The duplex option must be recognized by the driver under Properties > Install Options.
  • -The selected Paper Type must not be:
    -Transparency
    -Labels
    , or
    -Cardstock/Extra Heavy Paper.
  • -Under Page Layout > More Page Layout Options, the following options must not be selected:
    -Booklet printing
    Poster printing
Printer recognition of duplex option Some printers and MFPs have the duplex option built into the physical printer while others require physical connection of the duplex option or tray.
To check for an installed duplex option:
Print a Menu Settings page and check for DUPLEX under Device Information > Installed Features. (The embedded web server path is Reports > Device Settings > Device Information > Installed Features.)
If DUPLEX does not appear as an installed option, consider the following possible reasons: -The duplex drawer or tray is not properly connected to the printer. Try reseating the printer onto the duplex option so that the duplex option's upper auto-connect connector is properly aligned with the printer's bottom auto-connect connector. NOTE: A "982 duplex error" may also result from this condition.
-Turn the printer off for about 15 seconds, and then turn the printer back on. If the printer was quickly turned off and on, a low-voltage power condition could prevent the peripheral from being acknowledged during the initial printer start-up.
-The auto-connect connector is damaged on the printer or duplex option.
Software driver recognition of duplex option - reinstall driver.
Hope these suggestions help.
Nov 27, 2009 | Lexmark E450dn Laser Printer
Copier Programming Problem
Did u mean that u do not want to print duplex?
What u need to do is to configure the printer driver, that's all.
May 25, 2009 | Office Equipment & Supplies
Double sided copying
http://www.brother-usa.com/ModelDocuments/Consumer/Software%20Users%20Manual/SUM_DCP_7030_7040_MFC_7340_7345N_7440N_7840W_EN_1650.PDF
here is the manual p4 and p16 discuss the topic:
Duplex printing 1
The supplied printer driver supports duplex printing.
Guidelines for printing on both sides of the paper 1
�� If the paper is thin, it may wrinkle.
�� If paper is curled, turn over the stack, straighten it and then put it back in the paper tray or the Manual Feed
Slot.
�� If the paper is not feeding properly, it may be curled. Remove the paper, straighten it and turn over the
stack.
�� When you use the manual duplex function, it is possible that there may be paper jams or poor print quality.
If there is a paper jam, see Paper jams in the User’s Guide. If you have a print quality problem, see
Improving the print quality in the User’s Guide.
Manual duplex printing 1
The machine prints all the even-numbered pages on one side of the paper first. Then, the Windows® driver
instructs you (with a pop-up message) to reinsert the paper. Before reinserting the paper, straighten it well,
or you may get a paper jam. Very thin or thick paper is not recommended.
Simultaneous scanning, printing and faxing 1
Your machine can print from your computer while sending or receiving a fax in memory, or while scanning a
document into the computer. Fax sending will not be stopped during PC printing. However, when the machine
is copying or receiving a fax on paper, it pauses the PC printing operation, and then continues printing when
copying or fax receiving has finished.
�� Manual Duplex
Check Manual Duplex. In this mode, the machine prints all the even numbered pages first. Then the
printer driver stops and shows the instructions required to re-install the paper. When you click OK the odd
numbered pages are printed. There are six types of manual duplex binding directions available for each
orientation.
�� Booklet Printing
When you want to print a booklet, use this function. To make the booklet, fold the printed pages down the
middle.
�� Binding Offset
If you check the Binding Offset option, you can also specify the offset for binding in inches or millimeters
May 14, 2009 | Brother MFC-7440N Laser Printer
Duplex Printing
do you have duplex installed ? if you trying to copy duplex originals, you need duplex feeder.. in main displey the left tab is dupleks printing, if you have there options 1 -1; 2-1; 1-2; 2-2 then you have a duplex installed and you can copy/print duplex. also in driver menu there is a option duplex, wath you have to choose if you printing.
Apr 25, 2008 | Konica Minolta bizhub C250 All-In-One...
Copying using the Duplex function
Press on duplex button and scan your originals one by one on the platen mode (exposure glass). You cannot use the ADF for this function.
After every scan press the Start button.
After the last page please press the enter button as displaying in the display.
Then the copier itself can finish making duplex copies as you wanted.
Good luck and please rate me, thanks.
Nov 27, 2007 | Ricoh Aficio 1515MF All-In-One Laser...
70 people viewed this question
k24674
jasbo
jasbo
