Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Need instructions how to remove the ice cube tray
Our ice cubes get jammed everytime and we were going to replace the tray but can't figure out how to remove it
    Problem Solver:
  • 8 Answers
Its highly unlikely you'll get a free answer on this web-site, so it's either fork over the money to these jokers or get an answer for free on another forum.
Posted on May 25, 2009
Whirlpool side by side with in door ice the ice get made but will not eject into the door dispenser...the cubes just sit in the ice tray. i have cleared the cube's out several times and made sure no...
if ice cubes stay in the ice mker mold the heater is bad . but if this is the storage bin the the auger is not moving them . ck to see if tray in proper position and try again . sometimes ice gets under tray and you need to remove bucket and clean it out .. mm
Aug 18, 2010 | Whirlpool ED2FHEXN Side by Side...
Ice cube dispenser will only deliver crushed ice
Remove the ice bin, and in the back of the freezer you'll see a square opening with a white plastic piece inside. When you dispense cubed ice this piece lifts up, lifting the long metal rod that runs along the bottom of the ice bin. When that rod lifts it opens the ice flap at the front of bin, allowing cubes to be dispensed. If the flap is not open, the cubes will be ground against the cutters and you will get crushed ice.
Here's what you can do to make it so that you always get cubed ice. Take a wine cork and stand it on end. Using a good knife, I positioned the blade about 1/3 of the diameter from the edge and cut all the way through the length of the cork. Then remove the ice tray.
Now put your finger in the sqaure opening and lift up the white pastic piece. Slide the modified cork under the flap so that it is jammed into the raised position. (This is the position it should be in when you are asking for cubed ice.) Now slide the ice tray back in while using your left hand to push the plastic ice flap at the front of the tray to the left side (again, the position it should be in for delivering cubed ice). Peer under the tray while you're slowly sliding it back in so that you can see if the metal rod connected to that ice flap successfully slides into the square opening at the back. If it can't slide in above the cork-raised plastic piece, you may need to pull the cork back out and trim a little more off it.
This worked for me... I can't get crushed ice anymore, but I've only needed crushed ice once in the 16 months I've lived here so that's not an issue for me.
Apr 02, 2010 | GE GSS20IEP Side by Side Refrigerator
The plastic notched tray of the ice cube maker is broken
Those parts are available and require disassembly of the IM to replace.
Eric
Oct 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice stuck in ice cube tray
get a hairdryer to melt the cubes unless hot water can get poured in to mold to do the same
Aug 22, 2009 | Whirlpool Refrigerators
I can only get crushed ice, no cubes
This solution will work if you want to avoid replacing the solenoid and are willing to settle for alawys having cubed ice.
Jul 06, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Ice maker won't dump cubes
the problem is that the tray doesn't eject the cubes, they get stuck and it just breaks them and only parts come out instead of the whole cube/crescent, then the proper amount of water comes in as refill, the tray gets too full and your problem begins. Take the unit out, then take the tray out, its's easy, and give it a light coat of Pam, olive oil or corn oil, the cubes will eject properly. It took me 3 years to figure this out, it willl amaze you.
for everyone with the fan screech noise, replace the fan motor, don't buy the blade, look around the websites, I found it, my second replacement, for 28 but as high as 65.
yeah I hate this fridge too
Feb 08, 2009 | Samsung RS2630SH Side by Side Refrigerator
ICE WITH PLASTICS TRAY
the cubes that come out of most plastic trays are alot larger than the cubes harvested by the icemaker. these cubes can jam and cause the bucket to break. if you can find plastic trays that have smaller cubes it would probably work ok..peyton
Jan 25, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridgidaire side by side Ice cube jam
You can adjust the size of the ice cubes . if the cudes are too small or to big . they can get jammed... the timing screw is under the head cover clockwise is smaller . turn it one turn at a time... hope it helps
Jul 15, 2008 | Frigidaire FRS26R4A Side by Side...
Ice maker will not push out ice cubes once frozer
That means that the evaporator fan system that releases the the ice cubes is not working as it should.
The heater, or evaporator fan and heating system must be checked, and fan, or solenoid, or element must be replaced.
Use the number listed on the owner manual if you want to call a technician.
Enter model number on this website to find schematics and replacement parts.
May 12, 2008 | Whirlpool ED2FHEXN Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
73 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
