Question about Nuova Simonelli Microbar Espresso Machine
Leaking around the group
My ECM Giotto is 3 years old and recently started leakin. I called the place where I bought it and they suggested it might need new gaskets around the group. I received them but have no idea how to remove the old one which has become very hard. I am not mechanical and do not want to do any damage. Please help.
  • 10 more comments
  • Anonymous Nov 28, 2007
    leaking at mouth, electric will shut off.
  • Anonymous Dec 12, 2007
    I was given the name of a repair company for my x5 called Empire tn#877-854-4141 but dont know where it is address wise.
  • angelbaby1 Dec 30, 2007
    leaking around the seal that holds fhe coffee in the pot
  • fedenat Jan 28, 2008
    I have a very similar problem. Only less than 50% of the coffee gets
    into the cup. The rest is found in the drawer. Could this leak problem
    be the same. Maybe I need new gaskets too.. At the,
    there is no lavazza help. Did you solve your problem ?
    Thank you
  • Puro Mar 17, 2008
    Leak on overflow drain, we control level water with valve on back side,what i need for fixed the problem
  • Anonymous Mar 17, 2008
    milk leaks out of the top of the of the lid.
  • Mark Grasso
    Mark Grasso Mar 30, 2008
    I have a 8 monthe old Breville that is leaking around the group head. I have ordered a new steam gasket. Anyone had this problem? If so, what was the solution? Thanks.
  • coffee nut Apr 13, 2008
    Water seems to be leaking underneath my Trevi Automatica Anthracite version from Spidem.
    Cleaning doesn't seem to solve the problem.
    Model #SUPO18MR Serial Number 1043
  • Anonymous Jun 01, 2008
    Can't get water to go thru the group...the group IS the thing that you put the filter into..correct?  Bottom line - water/coffee leaking everywhere..only about .5 cup of coffee actually being brewed.
  • Anonymous Jun 22, 2008
    my ascaso dream expresso machine is leaking around the filter holder
    please provide solution
  • Anonymous Nov 26, 2008
    My Ascaso Dream is 2 years old and recently started leaking for the SECOND time (the first time was a few months after I bought the machine), The first time I was told by the repair-service (in Belgium) that they repaired the leak but they obviously didn't.
    I don't trust them anymore so I am still searching for a solution too. All suggestions are welcome.
  • Anonymous Jan 13, 2009
    already replaced gasket and it still leaks after a week. think machine could be warped?
    Problem Solver:
  • 10 Answers
I tend to remove the screw holding the shower plate to the group.
Take off the shower plate, and the metal diffuser (a round heavy metal piece) should come off with it.Sometimes this needs a little encouragement with a screwdriver..:)
Take a long thin screwdriver, and place it on the old gasket in the group.A few taps with a hammer (TAPS, not hard), and the old gasket should break.You should be able to prise out the gasket now, but it may take some moving if its been there a while.
Give the group gasket area a clean, i like wire wool for this.
Put your new gasket in the group and press upwards until it slots in.Some take more pressing than others.
Try the handle in the group to make sure everythings ok.
If the handle does not fit, the gasket is not in correctly.
Then replace the diffuser and shower plate and test.
Hope this helps..:)
Posted on May 08, 2009
  • 112 Answers
You can get seals here
Posted on Jun 02, 2008
Go to coffeegeek (dot) com and do a search for gasket replacement...they will tell you EXACTLY how to do this. This is an EASY fix! (Good Luck)
Posted on Nov 01, 2007
ECM Giotto toggle (power) switch needs replacement ASAP in Seattle area.
i had this happen myself a few months ago, power switch blew, i took the machine apart took out the power switch, and visited a few local electrical component suppliers, its a standard switch but its 2 stage single throw switch, home depot/Lowe's don't carry this type. ended up going to 3 diff suppliers and finally found a commercial supplier that had it connected the new one and now its fine, works better than the old one ever did. just make sure you bring the broken switch with you when you go to show them, most good suppliers can match it and see if they have one like it in stock.
Apr 21, 2011 | ECM Giotto Espresso Machine
Giotto Premium problem...
Try to do a hard reset by unplugging the device from the power outlet or take the batteries out and wait for sometime to reconnect.
May 29, 2008 | ECM Giotto Espresso Machine
My Giotto Premium drops water from time to time - it runs out the holes in bottom of machine and makes quite a mass of water either side of machine on bench - we can't see a pattern - but do leave the...
Did you find a solution yet?
If your machine isn't plumbed in, so you have to fill the reservoir, I find it is easy to overfill, and the water runs out over the lip. I placed a fishing float with the long bit sticking up through the hole, so I can see when the water level is too low.
Dec 27, 2010 | ECM Giotto Espresso Machine
I have a Giotto ECM esspresso machine. it is approximately 3 yrs old. recently when i turn the machine on, it starts heating up, but it doesn't create any pressure. any suggestions how to fix this problem.
1 solution is your vacuum breaker valve is sticking. Try opening the steam valve and see if you can start to heat again. If it does just, replace your vacuum breaker valve.
Sep 20, 2010 | ECM Giotto Espresso Machine
My 5 year old Giotto has stopped working
The vent valve on the machine is stuck in the open position. Turn on the machine and open the steam wand until you hear a hiss or see small water bubbles from nozzle, let it steam out a little more then close wand, that should allow the machine to heat up correctly, then order a new vent valve for the machine.
May 03, 2010 | ECM Giotto Espresso Machine
ECM Giotto releases steam instead of water from the coffee group
Check the shower screen and diffuser in the head, they might be blocked, if not, check the metering jet at the top of the head(large nut) CAREFUL, make sure machine is off and cool before removing, use a paperclip or pipe cleaner to clear blockage. If not blocked then you will have to check the brew solenoid.
Mar 02, 2010 | ECM Giotto Espresso Machine
My single cup portofilter on my ECM Giotto suddendly is pouring more coffee then it should. I'm using the same grind I've been using forever. My other portofilter (2 cup) works fine and still produces the...
How old is the coffee being used? Normally if you change baskets, the grind should be the same, because the single basket has finer and less holes in it than the double basket. The only difference would be the tamp then, since the coffee grinds works great with the double basket. You would also have to use a different volume of water to produce the coffee. To produce 2 ounces of espresso you need about 3 ozs of water,(about an ounces of water will remain in the coffee).
Jul 19, 2009 | ECM Giotto Espresso Machine
ECM Giotto group gasket and shower plate falling out
I am assuming that you have basket style shower which sits in the gasket and then inserts in the group.
Find the small bevel edge on the gasket, make sure that side is facing up, place gasket on table then insert shower in gasket, then lift gasket, until it sits at the top of the shower(use a small flat screwdriver or a small hard brush to clean the group where the gaskets seats), then insert gasket and shower in group. Push in as far as you can then use the portafilter to seat the gasket in all the way.
If your shower is the flat style then there should be a hole in the middle for a screw.
May 29, 2009 | ECM Giotto Espresso Machine
Ecm giotto repair
Jonny boy,,If you ever had a Macano box as a kid, tthe best man to fix the machine is you! Take many photos before opening the pipework. Clean out the scale and learn about your machine! No kidding, you brew a better coffee after that. You know ALL the functions after looking into the machine + ther are some ways to tweek it too. Steam press cam be set as well as water amount. I brwe a better espesso tha I get on town. Thick light brown crema. I gave upo with the dealer and hes so called repair people /// Olev
Aug 25, 2008 | ECM Giotto Espresso Machine
Wet grounds
What you see is condensed stem comming out and no water. The pump is not sucking from the tank as ther is an air bubble in suction line. Still want coffe and don't want to clean your machine??? Flick up the lever with no group in place. Steam comes first then nothing. Pump is running and - voila - water comes as air bubble is gone. (Specially the first cup , never the following ones.) Now put back the group and brew your espresso. The machine is full of scale and neds total clean - by hand./// Olev
Jun 13, 2008 | ECM Giotto Espresso Machine
Nuova Simonelli Microbar Espresso Machine Logo
364 people viewed this question
Top Nuova Simonelli Coffee Makers & Espresso Machines Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Nuova Simonelli Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
