Question about Heavy Machinery
Metalic clanging Just bought the sears wood chipper and when I first started it it sounds like the flails and fingers are hitting something continuously, not just during the starting sequence. Is this right?
  • 513 Answers
No its not you might have something cought in the safety gaurd check & clean if it still happens then somethings really loose inside check & replace if needed
Posted on Jun 05, 2009
Why is my 1987 300e Mercedes making a loud clanging noise at start up?
I would think the honeycomb ceramic "Brick" inside the Catalytic Converter has broken up, makes a terrible rattling when this happens.
Nov 26, 2011 | 1987 Mercedes-Benz 300-Class
I need a gas tank for a Craftsman 242-27006 shredder-chipper
go to http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears type in your model look through the pictures and you should be able to find the part number and sears can order it for you.
Feb 22, 2010 | PDP Systems 1.5 Horsepower Electric Wood...
Replace flails on 5.5 Yard Machine
Go to www.ordertree.com. The flailblade is p/n 719-0329, The shredder blade is p/n 942-0571, The chipper blade is p/n 981-0490.
Replace them you have to take casing off the unit to get to them.
Jan 22, 2010 | Yard Machines 24a 452g729 5.5 Hp Chipper...
No drive to flails, the side belts are intact
If this is a chipper there might be something stuck in the flailer section holding it from turning .
Oct 18, 2009 | Garden
10 hp Troy Built chipper pull start frozen
If a branch was already being chipped when it ran out of gas...you must clear the hopper of any chunks of wood in it. Pull the plug wire and use a metal pry bar to dislodge any pieces of wood. when the flywheel runs free, put the plug wire back on and the choke on. Try it now!!!
Jun 14, 2009 | Troy-Bilt® Briggs and Stratton Chipper
Drive belt and a manual for 8 hp tomahawk chipper shredder
did you find a manual? mine is 8hp Super Tomahawk, model 47258. I have manual, but not parts diagram. I need parts, flails and tamper. Got any leads? twinblade88 at hotmail dot com
Jun 08, 2009 | Troy-Bilt® Briggs and Stratton Chipper
I don't have a manual for the tomahawk chipper and I cannot figure out how to change the blades.
You will need to turn the flails (also called cylinder hammers).  Each flail has  4 sharp corner cutouts, only one of which is in use.  When you turn them you get to use a fresh corner, the dull one is still there but no longer contacts the stuff you are chipping.  You will need to remove the chute to access the flywheel, and by rotating the flywheel access the steel bars (cylinder pins) that hold the flails and spacers.  I lay the chipper down, with a 5 gallon bucket protecting the engine, gas tank, to access the bottom, so that you can, using a punch, drive out the 3/16X3/4 roll pin which can be found in one of the long spacers.  You will note each bar has 4 flails, with two long spacers and two short spacers and the roll pin goes through one of the long spacers.  You buy the roll pin punch at a hardware store.   There are four sets of bars with spacers and flails, so four roll pins.  You will want four fresh roll pins also, because the old ones are compressed and shouldn't be used again.  When you have punched out the roll pin you can then drive the bar from the end (where the chute was) but be sure to line the other end of the bar up with the hole on the other sidewall of the chipping compartment.   When you are trying to punch out the roll pin it helps to stabilize the fly wheel--I use a couple of vise grips in a way that the fly wheel is stable.  When you are pounding out the bar (called a cylinder pin) you will need a slightly lesser diameter long (6-8") bolt as a driver.  You can pound on it and it will follow the cylinder pin as it gets pushed out the other side.   When the spacers and flails fall out onto the floor, then you can turn the flails to use a fresh cutting corner and put the spacers and flails back on.  I find it helpful to file the rough edges of the inside ends of the spacers so they slide easily on the cylinder pins.  Get a round file for this purpose.  Also, keep some WD 40 on hand because these things tend to be stuck.  I do only one cylinder pin (with its four flails and four spacers) at a time, so I correctly put it all back in the right order.   You will see that the the order alternates.)
Mar 20, 2009 | Troy-Bilt Heavy Machinery
What is a chipper?
Most of our industry refers to chippers or chipper-shredders as pieces of equipment that can handle both wood and leaves. These machines have both a chipping device and a leaf-shredding mechanism. This mechanism is basically a hammer mill, cylinder or drum with a series of pivoting flail-type knives. The chipper-shredder usually is a smaller machine and may include a vacuum to clean up leaves. These machines can be self-propelled or stationary. Most chippers are disc-type, consisting of a large, heavy, rotating disc with knives mounted to it and are for chipping wood only.
Aug 27, 2008 | PDP Systems 1.5 Horsepower Electric Wood...
Wood Chipper how to
Great input tina783. I have just one thing to add. Try to shred the branches within a reasonable amount of time. I found out that with my shredder, if I put older, dried up branches in, it tends to take a lot more time, as well as tosses chips back out at you. With newly cut branches, this wasn't nearly as much as an issue.
Aug 27, 2008 | AMANA TOOL 658060 PRESTIGE FINE DADO SET...
Heavy Machinery Logo
182 people viewed this question
Top Heavy Machinery Experts
Bill Boyd
Daryl Gleaton
Tom Chichester
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
