Question about Lexmark E340 All-In-One Laser Printer
950 system board
Lexmark e340 950 system board ?????
    Genius:
  • 1,011 Answers
Usually, at least on the Lexmark products I am most familiar with, a 950 error had occured when a printer had the systemboard replaced and the repair tech failed to update the new systemboard to reflect the correct information contained the printer's NVRAM.
From a software perspective, this should never accidently happen. Either the NVRAM on the printer is blown or the systemboard memory of the matching terms has been cleared.
Again, not a trivial endevor.
At this point, I'd suggest a service call to get the diagnostics run against the printer. You may have to replace the systemboard.
Don
Posted on May 31, 2009
    Problem Solver:
  • 14 Answers
Hi All
Lexmark designed their printer to come up with this error is you gonna put a new board in. The problem is the control panel and formatter board are married to each other. To fix this you need to replaced the serial eeprom chip on the control panel which is a 24c64 or similar chip. I have had this problem with Lexmark color printers as well and fixed them the same way. If you want to contact me just drop me an email
Thanks Reedwaan
Posted on Sep 04, 2012
3 Suggested Answers
Printtech
  • 1087 Answers
SOURCE: Lexmark e352dn error 950 system
Please click on the link below to see instructions on how to go about the procedure.
http://bit.ly/j7Jzkz
Posted on Jul 05, 2011
Printtech
  • 1087 Answers
Ideally the printer should be connected directly to the wall outlet not to a UPS or surge protector.
If you experience the same issue please contact Lexmark Technical Support for further assistance
Posted on Jul 25, 2011
My lexmark E340 printer displays the message: "remove cartridge paper jam" continuously and not print more pages
There is probably a sensor that is being blocked by paper that you might not be able to see easily. Remove cartridge and check the inside of the printer with a flashlight. Please turn off printer before doing this.
Sep 06, 2013 | Lexmark E230, E232, E234, E238, E240,...
The paper is jamed in the back and I can't find a way to release it. Lexmark E340
jammed in fuser which is in the back to get to fuser remove rear door remove redrive two screws you will see the fuse be carful output sensor in middle of fuser just pull it gently if it jams again may need a new fuser
Sep 08, 2011 | Lexmark E340 Laser Printer
202 papier vast open both doors from the lexmark e340 printer
Please click on the link below to resolve paper jam problems. To prevent paper jams, please make sure that the paper settings on the printer is in sync from the application (e.g Microsoft word).
http://bitly.com/pbUgyr
If you need further assistance please contact Lexmark Technical Support.
Jul 27, 2011 | Lexmark E340 Laser Printer
Erro 950 system boar
The most common cause of this problem is that the wrong interconnect board or the wrong system board has been installed into the printer. This creates a conflict which can produce this 950 error.
For further assistance, please call Lexmark Technical Support.
May 24, 2011 | Lexmark Lemark E352DN Laser Printer
Lexmark e352dn error 950 system board: I have replaced the board but the problem remain. Any suggestion?
Apr 27, 2011 | Lexmark Lemark E352DN Laser Printer
Error: 900 Service , RIP software e340 Printer
Turn the machine off unplug the power cord from it and leave disconnected for 10 mins.
Power back on if error still is present..
Power off again disconnect whatever cables are plugged in (Network cable/ USB) power back on if error error goes away with the cable(s) disconnected replace the usb/cat5 cable(s)
once that's done and the error is still present the system board will need to be replaced.
Oct 19, 2010 | Lexmark E340 Laser Printer
I need lexmark e340 laser printer driver
Here's the link for the available Lexmark E340 drivers: http://bit.ly/cW7nSd. Click on the drop-downs found below the page to choose the version of your computer's operating system. Download and execute the file. Thanks for choosing Lexmark.
Aug 25, 2010 | Lexmark E340 Laser Printer
My computer is asking me to replace photocon
Here's an article in the Lexmark website which should guide you on how to replace the photoconductor kit on your Lexmark E340. Just click on this link: http://bit.ly/ctJ5Mz . There are some graphics in it that should better describe the instructions. Read the WARNING, NOTE and IMPORTANT messages for your guidance. Hope this helps. If you need more assistance, just place a comment so I can get back to it.
Apr 14, 2010 | Lexmark E340 Laser Printer
Lexmark E340 printer gave error " Replace Fotoconductor" I replaced the fotoconductor, but it still gives the same error
Reset Procedure(s) after putting in new Photoconductor kit
Resetting the Lexmark E340/342 (display type) machines
1) Turn the printer off
2) While still off, press and hold the SELECT and RETURN buttons.
3) Keep both buttons pressed, and turn the printer on. Continue to hold both until either “Performing self test” or “Config menu”
appears on the display.
4) Release the two buttons
5) RESET PC CNT should now show on the display. If it does not, press the left or right menu buttons until it does.
6) Press the SELECT button once. “Resetting PC Cnt Value” should show on the display.
7) When the display shows CONFIG MENU again, turn the printer off.
8) Turn the printer back on. (Do not hold any buttons down this time). The printer is reset.
You can confirm the counter was reset by printing a “menu settings page”.
Aug 28, 2008 | Lexmark E340 Laser Printer
Lexmark E340 All-In-One Laser Printer Logo
1,980 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
