Question about Canon PIXMA iP1800 InkJet Photo Printer
Cartridge won't recognise
I loaded a new cartridge, tried to carry on printing and it keeps coming up with "ink cartridge not installed properly" however i have taken them out and put them back in several times and i'm pretty sure they are installed properly, so im not sure what the problem is?
  • Anonymous May 26, 2009
    i install now the cartridge when it times to print it says that the has run out but my is very full enough
    Sniper:
  • 73 Answers
Dear, you computer is showing the previous saved data in the system registery or hidden files, you need to remove the printer driver and install it again to remove this error.
1. Remove the carteriges.
2. Remove the driver from the system.
3. Install the driver after rebooting system.
4. Install the carteriges again.
70% chances, that your problem will be solved, if not then you need to change your printer or caterige.
Best regards.
Posted on May 25, 2009
Ive just filled my ink cartridges but have the following error message when trying to print: (see add details section)
You need to reset the chip in the cartridge that tells the printer when it's low. The part can be found on sites that sell refill kits.
Aug 07, 2015 | Canon PIXMA MG3150 Inkjet Multifunction...
Even with a new cartridge inserted, the printer does not print properly. The printer does not indicate that a new cartridge is needed. How do I clean the printer head? It is a HP Photosmart C3180 al in...
Step one: Complete the alignment process If you have already installed new print cartridges, follow these steps to complete the alignment process.
  1. After installing a new print cartridge, wait at least 20 seconds for the print cartridge alignment process to start.
  2. Wait for the print cartridge alignment process to fully complete.
  3. Make sure that the alignment page has printed on plain, white paper that has no other printing on it. If you need to create a new alignment page, load the tray with letter or A4 unused plain white paper and turn the product off and on again to create the page.
If an alignment page does not print when the product is turned on or off, the issue is resolved. If an alignment page continues to print when the product is turned on or off, you should replace the cartridges with new HP cartridges. Continue to Step two: Remove the print cartridges. Step two: Remove the print cartridges Follow the steps below to remove the cartridges. NOTE: When you remove and install the same print cartridge, the unit will not align the print cartridge as the unit remembers the alignment values for that print cartridge.
  1. Press the Power button to turn the product on. The Power button is lit when the unit is on. Figure 1: Power button lit c01336350.gif
  2. Make sure that the paper tray is down, and letter or A4 unused plain white paper is loaded in the paper tray.
  3. Lower the access door until it stops. Make sure that the print carriage moves to the right side. Figure 2: Lower the access door c01336351.gif
  4. Wait until the print carriage is idle and silent, and then using your thumb, lightly press down on a print cartridge to release it. Figure 3: Print carriage c01336352.gif
    • If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
    • If replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
    Figure 4: Proper position of the print cartridges c01336353.gif 1 - Tri-color print cartridge 2 - Black or Photo print cartridge
  5. Pull the print cartridge toward you and out of its slot.
Step three: Install the new print cartridge
  1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. Figure 5: Remove the tape c00312625.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00312564.gif
  2. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket.
    • If you are installing the tri-color print cartridge, slide it into the left slot.
    • If you are installing a black or photo print cartridge, slide it into the right slot.
    Figure 6: Print cartridge locations c00652788.gif 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print cartridges
  3. Close the print cartridge access door. Figure 7: Closing the print cartridge door c00652789.gif
  4. If you installed a new print cartridge, the print cartridge alignment process starts after about 20 seconds.
  5. The unit aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
If you have completed all the steps listed above and are still experiencing a problem, service the product. Cause The product aligns the print cartridges every time at cartridge installation or replacement to ensure the highest-quality prints. The alignment page continues to print when the product is turned on or off, or when a print job is started, for any of the reasons below.
  • The automatic alignment process is not complete.
  • The ink cartridges are not properly installed.
  • One of the ink cartridges is defective.
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
  • The product needs to be serviced.
Aug 28, 2008 | HP Office Equipment & Supplies
Installed new 28 and 29 cartridges in lexmark x2550 and it won't recognise the cartridge and won't print at all, very frustrating please help urgently
It could be that your cartridges need some cleaning. On your computer, launch the Lexmark Solution Center. Click Start menu > Programs or All Programs >Lexmark 2500 Series > Lexmark Solution Center. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through the cartridge nozzles and clean them. Try to print again.
Jun 29, 2011 | Lexmark X2550 All-In-One Printer
Out of ink message but just put new cartridge in
fix your cartridge properly...maybe it is not in plce...refer for manual so that you have put it in right place...
try to rest your printer if you know how...
Feb 06, 2010 | Epson Stylus Photo 1290 InkJet Printer
I have installed a new black ink cartridge. "Ink is out" comes up when I try to print. It is properly installed and is the second new black ink cartridge this has happened with. The "On" and 'Ink" lights...
I have installed all new cartridges. "Ink is out" comes up when I try to print. It is properly installed and is the second set of ink cartridge this has happened with. The "On" and 'Ink" lights do not stop flashing. The printer does not see the new cartridges.
Jan 04, 2010 | Epson Stylus CX4800 All-In-One InkJet...
Cartridge problem
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 19, 2009 | Canon PIXMA iP1600 Printer
Epson Stylus CX5500- Changing/Installing Cartridge (BIG) problem
they are proper mardy machines only happy when using original epson cartridges
Sep 20, 2017 | Epson Stylus CX5400 All-In-One InkJet...
No cartridge the printer say. i put new cartridge in
It mean that the black cartridge is not recognised. It the black cart is original or compatible? Some printer won't recognise cartridge, if the black and colour is not same type. Try to install the black only. Is it recognised?
May 30, 2009 | Brother MFC-3360C All-In-One InkJet...
The black ink cannot be
Are you confident the new cartridge is full and in-date? Can you confirm that the old cartridge was not removed until immediately before the new cartridge was installed? Did you remove the yellow tape from the new cartridge before you installed it? Was the black cartridge change properly completed such that an ink charging cycle occurred? Have you carried out any head cleaning cycles? If not, do it. Have you done a nozzle check print? If not, do it. Any sign of black ink? Yes, but not perfect? If not, do a couple more head cleans and nozzle checks. If still not perfect, let it rest for 24 hours to disperse air bubbles. Then repeat.
If you have already done lots of head cleans with no result, and you're sure you have a good ink cartridge properly installed, then there are other things we can try - assuming other solutions haven't worked either. Report back on my queries etc.
Feb 10, 2009 | Epson Stylus C43SX InkJet Printer
Loading the ink cartridge
Please remember to rate other users who assist you for free :)
How to install or remove ink cartridges To print normally, install or remove ink cartridges in an orderly procedure.
How to install ink cartridges
1. After confirming that the printer is powered on, open the front cover. The ink cartridge holder moves to the replacement position.
2. Take out an new cartridge from its casing and gently remove the orange protective tape in the direction of an arrow.
Caution: Do not attempt to reattach the protective tape once you have removed it. Do not touch the gold electrical contacts or the print head after removing the protective tape.
3. Insert the color cartridge into the right slot and then the black cartridge into the left slot.
Note: Push up on the nearest side of the cartridge until it clicks into place.
4. Confirm that the ink cartridges are installed properly.
(A) The ink cartridge is not installed properly.
(B) The ink cartridge is installed properly.
5. Close the front cover. Wait until the preparatory operation is complete; it takes about one to two minutes.
How to remove ink cartridges
2. Remove the ink cartridges.
Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
Sep 29, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
306 people viewed this question
old marine
old marine
