Question about Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher
Washer stops during middle of cycle
My to washer stops in middle of a cycle, no error message display, just the front panel blinks like I pushed stop, the door is also unlocked. I hit start again and it will continue for few more minutes then stop again. every few minutes I would hear it beep. It appears to drain fine and I have ran a full cycle before, I tried to run it also with empty washer, I did a power reset, not sure what to do next....
  • 351 Answers
SOURCE: Top drawer not working
sometimes if the heater is faulty only one drawer will work and the other drawer will flash f1
Posted on Mar 03, 2008
stephanos18
  • 144 Answers
SOURCE: beeping fault code Fisher and Paykel DS603
Stop the unit and check to see if it's heating when it's beeping at you. eg is it warm water inside at the time? if not you may have a faulty element.
Posted on Mar 24, 2009
stephanos18
  • 144 Answers
SOURCE: Fisher & Paykel DS605 starts cycle, stops, beeps, shows U3 error.
U3 means the tub filled to quickly or the water failed to drain. Do you have very high water pressure? are you using the wrong detergent? eg you can't use tablets (powerballs) etc in the unit. Try putting half a cup of white vinegar in the tub to kill any foam. Check there isn't anything stuck under the motor rotor inside the tub and the there's no signs of damage. Put the drain hose in a bucket and see if the water drains ok when the unit starts? If everything seems ok I'd suspect the main motor controller module but it may be worth getting an appliance tech to inspect unit first as it's hard without seeing this unit. feel free to ask any questions. Cheers
Posted on May 13, 2009
  • 7 Answers
SOURCE: I keep getting a beep and believe it is a Fault Code
try turnning the unit of at the plug the the controll panel holde the program botton in and trun unit on try this on both draws
Posted on Jul 23, 2009
  • 67 Answers
SOURCE: Fill Fault appears during wash cycle.
Is the filter in the hose where it screws onto the tap clean?, if this is okay then most likely the valve.
Posted on Apr 19, 2010
Testimonial: "Hi, Thanks so much for the reply. I checked the filter in the hose and it appears 'clean'. As you said it may be the valve. Thank you Stephen"
Kenmore Elite HE5t Washer stops in the middle of cycle with no error codes. Any idea how to fix?
sounds like the door switch either needs adjusted or totally replaced .try leaning against .next time instead of opening it
Aug 24, 2015 | Kenmore Elite HE5t Washer
Error message: Thermistor Fault
yes it is serious as it indicates an over heating condition probably on the motor or control panel
May 17, 2015 | Asko W6761 Front Load Washer
Error F11 during the wash cycle
The error means that the controller is not talking to the other components. It is very expensive to repair,. If you want to run tests on it, there is a tech sheet behind the kick panel under the door.
Feb 09, 2014 | Whirlpool Duet GHW9150P Front Load Washer
As soon as the machine is on an error message of 3E appears and the machine stops
3E - MOTOR RESTRICTION ERROR
Hall Senior is sensed every 5OOms. 1 second after motor starts to work.
If data of hall sensor is less than 2 (2RPM), the Washing motor will stop at once.
During Washing and Rinsing when a motor restriction is sensed, the motor stops and then proceeds to the next water -flow action. If the motor stops working and this happens in one direction ten times, "3E" Error is displayed.
During dehydrating. when a motor restriction is sensed. the motor stops working and then returns to the initial stage of the dehydration unbalance sensing cycle. After ten times, "3E" Error is displayed, When the motor Is told to stop because of an operating function. no error is shown.
Power 81W OFF can clear the motor restriction error.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 14, 2010 | Samsung WF337AA Front Load Washer
Washer stops washing and gives a p5 trouble code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Mar 12, 2009 | Kenmore Elite 45986 Front Load Washer
Washer stops during middle of cycle and post 02 F
f 02 is the error code for taking too long to drain the water disconnect power remove 3 torex 20 screws from lower front panel revove cap from pump asm to check for any obstructions beware there will be water in the pump
Dec 15, 2008 | Whirlpool GHW9100L Front Load Washer
Stopped during rinse/spin cycle
try removing the bottom front panel and see if there is something blocking the drain.
Oct 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite front load washer
I HAVE A KENMORE ELITE WASHER AND IT STOPS IN THEN MIDDLE OF THE CYCLE AND DOESN'T RISNSE. THE DISPLAYS SHOWS F21. CAN YOU LET ME KNOW WHAT THIS MEANS?
Sep 22, 2008 | Kenmore Elite 45986 Front Load Washer
Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher Logo
61 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
