Question about GE GSH25JFR Side by Side Refrigerator
Freezer fan noise
I have a GE side by side model GSH25JSRF and the evap fan inside the freezer side on the back wall about half way up makes loud noise in a wave like form. Very loud at night. Any ideas, do I need to replace the fan motor? thanks
  • GE Master
  • 3,361 Answers
Remove the freezer panel to access the fan motor. Look for any obstruction around the fan or blade. Ice, misplaced wire etc.
Check the fan blade. Sometimes they slip down the shaft too far.
If you find none of these issues, replace the fan motor.
Posted on May 25, 2009
At first the refrigerator side was freezing everything and the freezer was fine, except the ice & water quit working. I replaced the filter & it worked for a few days then it was back to the same...
if the fan was loud you could have a bad evap fan motor,is there ice on the inside back wall of the freezer?if there is you have a defrost problem and ice could be built up around the fan motor and the blade,when the blade hit the ice that could be the noise you were hearing and now the ice is stopping it from spinning at all.if there isn't any ice on the wall you could have a bad computer board,part number wr55x10942,i've seen g.e.'s that when the water and ice didn't work and the temp was warm it was the board but when you say the fan was loud it makes me think you could be iced up in there.also if the fan motor was reving up and slowing down the board could cause that,let me know if there's like snow or ice on the freezer wall and i can help you out
Sep 30, 2010 | GE PSS26LGR Side by Side Refrigerator
My GE Fridge PSS26SGRD has a moaning howling
The fan is hitting on ice buildup...unit is not defrosting...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My LG ice maker fan is making a really loud noise right after the water stops going in
Hello, Self-defrosting refrigerators use a circulating fan to move air through the freezer and refrigerator compartment. This fan runs when ever the unit is cooling. The fan is located in the freezer, as follows:
  • If the freezer is on top, the fan is on the back wall,near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, half way up or near the top.
Overtime the fan may become noisy, usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise,just open the freezer door and push in any fan/light switches, if the noise is louder when the door is open, the evaporator fan motor is the cause. You can lubricate or repair this motor. You must replace it.
There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor(if self-defrosting), or the defrost timer (if self-defrosting).
Thanks
Jun 17, 2010 | LG LSC26905TT Side by Side Refrigerator
Loud humming noise coming from freezer
I believe what is happening, is your Evap fan has some build-up of ice on it. The reason it stops when you open the door, is the Evap fan cuts off. The Evap fan starts back up when the door is closed. What you'll need to do, is open the freezer door, and remove the back panel of the freezer. This takes some 1/4 inch screws and a couple Phillips I believe. Once you get the panel off you'll be able to see if there is any ice build-up on the Evap fan. If need, be take a hair-dryer on medium or low, and melt the ice off of it. This should solve your problem.
Mar 28, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Model 106 56569400 - Freeze side appears to be Ok. Refrig side not cooling to set temp 37. Current temp is 55-60. Door appears to seal properly.
If you have heavy frost build up on the back wall of your freezer you have a defrost problem. One of three things. Defrost timer, Defrost T-stat or Defrost heater. Usually problem is with the T-stat. If no frost make sure the evap fan is blowing. You should be able to hear a fan noise when opening freezer. If no fan noise replace evap fan which is located half way up behind freezer wall. Good Luck
Jan 27, 2010 | Refrigerators
Loud humming noise
Stick you hand in the freezer, touch the back wall of freezer, see if you feel a strong or lite vibration equal to the hum you are hearing. If so, the you have a bad evap fan, if not then pull unit out from wall and see if hum is load toward the bottom rear portion of the frig, if so contact a repair tech.
Oct 01, 2009 | GE GSS25JEMWW Side by Side
GE Fridge Motor Super Loud
Open the freezer door and see if the sound is there or if its near the floor. This needs to be corrected soon to prevent damage to your refrigerator. Your explanation makes be think the fan inside the freezer is loose or has ice buildup around the blades or the fan blade has become unbalanced in some way...Let me know and please rate me, Thanks, Sea Breeze
Jul 14, 2009 | GE Refrigerators
Freezer is making a strange bubbling loud sound comes and goes
IT MAY BE THE REOAN OR REFIRICHENT THE IS RUNING TRU THE LINES OT THE EVAP. FAN OR THE COPRESER GOING OUT FIND OUT ARE IS THE NOISE CAMING FROM . INSIDE MAY BE THE EVAP. FAN. IN BACK MAY BE COPRESER. OR IN THE WALLS IT THE FREON.
Jan 25, 2009 | Refrigerators
Howling sound from freezer fan section
it is most likely the fan bushings that are making the noise. you can try to lube them with a light oil if you want to buy some time. but the fan motor will need to be replaced soon.
Jul 05, 2008 | GE Refrigerators
Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSH25JFR Side by Side Refrigerator Logo
433 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
