Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Gas Leak on Harley Fatboy
When the engine is started, gas poors from the hose.
    Sergeant:
    Champion:
  • 205 Answers
My phone will be refreshing often while i am on internet
Posted on May 25, 2009
    Scholar:
  • 150 Answers
You have a problem in your float bowl either its stuck cause of crud init or float needs adjusting.
Posted on Jun 13, 2009
Will a 2012 Harley Fatboy FLSTF gas tank and fenders fit a 2009 Harley Fatboy FLSTF?
Hi, Jeremy after careful deliberation 4 out 5 Harley Gods give this one a thumbs up, but just to be on the safe side you should give your local dealer's parts/service department a call to confirm. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have nice a day.
Harley Davidson Manuals Mark Workshop
http://www.stcharlesharleydavidson.com/OEMpartfinder.htm
https://serviceinfo.harley-davidson.com/sip/index
Instant Tech Relief A must have !!! only $6 a month "CHEAP"
Aug 07, 2016 | GAS Motorcycles
Leaks gas from under gas tank 2002 road king
You have a hole in your gas tank or your gas lines are dry rotted. If your fuel injected, you should replace your hoses. If it is carbureted, you could have a bad petcock get yourself a bar soap, and we think it's leak in. Just pack it with soap. It's a leak stops. That's where it is. Before you do anything. No decrease it and clean it, so you can see where the leak starts from
Feb 23, 2015 | 2002 Harley Davidson FLHR - FLHRCI Road...
What is the code p0473 for a dodge sprinter van 2008
Error Code: P0404
Fault Location:
Exhaust Gas Recirculation (EGR) System - Range/Performance Problem
Causes:
-Hose leak/blockage.
-Wiring harness.
-Exhaust gas recirculation (EGR) valve/solenoid.
Error Code: P0473
Discription:
Exhaust Gas Pressure Sensor - High Input
Causes:
- Wiring short to positive.
- Exhaust gas pressure sensor (G450).
- Engine control module (ECM).
Error Code: P0674
Description:
Glow Plug Cylinder 4 Circuit - Circuit Malfunction
Causes:
-No Pre-Glow Period.
-Poor Cold Starting.
-Glow Plug Wiring faulty.
-Poor connection.
-Relay.
-Glow plug control module.
-Glow Plug faulty.
-Engine control module (ECM).
Solutions:
Check Glow Plug Wiring.
Check Glow Plug.
Error Code: P0675
Description:
Glow Plug Cylinder 5 Circuit - Circuit Malfunction
Causes:
-Poor connection.
-Relay.
-Glow Plug faulty.
Solutions:
-Check Glow Plug Wiring.
-Check Glow Plug.
Sep 20, 2014 | 2008 Dodge Sprinter
No power when give it gas.
believe carb adjustment bad & carb needs to be rejetted to exhaust, believe you need to add a higher flow gas valve & possibly new plugs & wires
Apr 21, 2014 | 2000 Harley Davidson FLSTF Fat boy
Does 2005 Fatboy have a reserve gas tank?
Hi Anonymous, no but it does have a warning light that activates when fuel gets down to approximately 1/2 gallon. Have nice day.
Feb 21, 2012 | 2005 Harley Davidson FLSTF - FLSTFI Fat...
My 1993 fatboy seems to leak gas. It didnt for a few days then it did. I turned off the gas and it leaked a little. The next day i left the gas on and it didnt leak.So this isnt a constant problem,however,...
it sounds like you petcock vavle ( your fuel shut off valve) is the problem its easy to change i would really keep a i on it no fuel leak is a safe thing to have.
May 05, 2011 | 1993 Harley Davidson FLSTF Fat boy
How to drain the gas tank on a 05 fatboy
You arent going to like this ... but it is the simple way ...
Drive around the block till you are empty ...
You could syphon the gas if you have a hose ...
if you syphon ... get all you can then run the engine until you run out of gas.
you could remove the tank ... there is a bolt at the rear of the seat to remove that ... then a rubber grommet (in all likely hood) at the rear of the tank that holds that ...
Jul 05, 2010 | 2005 Harley Davidson FLSTF - FLSTFI Fat...
Gas leak on Harley Fatboy, how to repair?
Most fuel leaks are caused by problems with the float bowl ( overflow not shuting off) You really don't give much info so we have to assume its a carb.
May 25, 2009 | Harley Davidson Harley-Davidson Motorcycle...
Oil leak from tube
you need to replace the o ring on the oil drain dolt that should stop the leak
May 24, 2009 | 2003 Harley Davidson FLSTF Fat boy
Lands Phones Logo
192 people viewed this question
Top Harley Davidson Lands Phones Experts
David Payne
David Payne
WTF Chuck.....
WTF Chuck.....
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
