Question about Mtd Products Yard Machines 158CC Tiller
Tiller won't stay running
My mtd tiller won't stay running, it starts and then dies right away, what could be wrong? Please help me.
Thanks,
Sherry
  • 376 Answers
If you choke or prime the engine, it starts up for a second or two and dies, the carburetor need to be cleaned/repaired.
Posted on May 25, 2009
Why won't my brand new tiller stay running? Starts, runs a few seconds, then stalls.
sounds like its flooding
the float needs adjustment or seat needs cleaning or replace
May 31, 2014 | Mtd Products Yard Machines 158CC Tiller
Starts but doesn't stay running
carb needs cleaning and also replace air filter
May 15, 2010 | Mtd Products Yard Machines 158CC Tiller
Engine dies out
Could be any of several problems. Since you indicate you just bought it, I'd suggest you return it. Troy-Bilt is pretty good at making customers happy and should repair or replace it right away.
Apr 09, 2010 | Troy-Bilt Pony Garden Tiller
Which small ''mini'' tiller to purchase
Definitely stay away from Ryobi, Troy Bilt, Bolens and Yard Machines by MTD. They are all Ryobi with different brand names on them. (goes for trimmers too) MTD owns them all. The best small tiller, IMHO, is Mantis. (2-cycle) I think Sears sells them now. I have one and it will run circles around the rest.
Jun 14, 2009 | Ardisam Inc Earthquake Mini Cultivator
Garden want stay running
maybe air supply is restricted. sounds like the fuel side is working. Also you may turn carburator adjusting screws all the way in then back them off 1-1/2 turns. after it starts you can adjust them to the right adjustment, you just have to play with them.
Jun 07, 2009 | Mtd Products Yard Machines 158CC Tiller
Hmmmm.....it sounds like restricted fuel flow to me, but explain "rebuilt the carb" so I can get an idea on what you did.
Though it sounds right off like you whooped it good and got the basics.
Right off, go back through the "system", check the fuel flow, check that spark on the plug. Eyeball for any loose wires (E.G., Kill Switch, etc.) that are grounding (you never know!)
Stick to KISS on this one, since it ran before the carb got bad and got rebuilt, it will be one of those things you replaced, rebuilt, or changed. Sometimes, it is the SMALLEST thing......
May 28, 2009 | Mtd Products Yard Machines 158CC Tiller
MTD 12.5 HP Ride On Mower won't stay running
It could be a needle valve sticking or a mal-adjusted float but more common is a fuel filter that is restricted, once you use up the fuel in the line and float bowl it runs out and dies. A less common but easily tested issue is when the mower has run for the amount of time it begins to sputter and die, loosen the cap on the fuel tank just a bit, if it helps or resolves the issue the vent in the cap may be clogged.
May 26, 2009 | Mtd Garden
We have a mtd yard machine roto tiller model 21A-340-06295208
i need a part list for a tiller model 21a
Mar 28, 2009 | Mtd Garden
My 1998 Chev Cavalier Theft System light stays on
If the car starts and dies right away you may have a pass key sensor fault.
Try to start the car,if the car dies right away just leave the key on and watch the security light in the insturment panel,if it begins to blink leave the key on until it stops blinking (apx 10 mins.) this will reprogram the pass lock to the pcm and may solve all your problems.if the car continues to die after running a min or so then you may have other faults,or if the car dies right after start the pass lock sensor may need to be replaced.
Please dont forget to rate this solution
Jan 03, 2009 | 1998 Chevrolet Cavalier
Mtd Products  Yard Machines  158CC Tiller Logo
1,457 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
