Question about Epson R1900 Printer
Our epson R1900 printer head is blocket on left side of printer and dont run how we solve this problam
  • Epson Master
  • 511 Answers
If using CISS, check the ink pipe first. Or try using original chip.
Posted on May 28, 2009
Epson R1900 cartridge carrier goes lef and grinds until it stops with flashing lights
It;s general error or fatal error. Find the Adjusment Program for R1900, then Click Printer Information Check. You will find the latest fatal Error code. You can figure the actual error of your printer.
Jan 17, 2013 | Epson R1900 Printer
I have the Epson R1900 and I did a nozzle check twice and head cleaning twice. I am unable to check my supply levels. I am getting a message saying to only use genuine Epson Ink but that is what it
More than a little unusual that the printer is reporting non-OEM cartridges if those are the ones loaded unless your cartridge supplier has obtained their stock from another sales zone, in which case it may be that the printer is not recognising them as being valid.
Presumably, given the model you are getting the warning on your computer so you can disable this status monitor by doing the following:
- Open Printers & Faxes (or the equivalent for your operating system
- Locate your R1900 printer in the list
- Right click and select "Printing Preferences" (or "Properties" followed by "Printing Preferences")
- Click the "Maintenance" tab
- Click on the button marked "Speed & Progress"
- Tick the box marked "Disable status monitor 3.0" (The exact line may differ)
- Click Apply then OK
This should disable the annoying "Use genuine" warnings although it will also disable your ink monitoring capabilities via software.
I would still contact your supplier and/or Epson to complain about the problem and ask for replacement cartridges for the ones most recently changed as obviously this is something that should be covered under the cartridge warranty.
Hope that helps.
Dec 14, 2012 | Epson R1900 Printer
I have had my Epson R1900 since last July, and it has worked just fine for me up until a couple of months ago when it began printing with a very noticeable blue-green tint. I always use Epson 87 inks, and...
using your printer once a week makes your printer clog even if you use original cartridges i prefer using it once a day, if you dont have anything to print, just turn on your printer and it will automatically head cleaned its head
May 24, 2011 | Epson R1900 Printer
Vertical lines when printing. Have genuine Epson cartridges installed and most are brand new. Have done a print head alignment and cleaned the nozzles.
You have a clogged print head. If repeated running of the head cleaning routine does not work, you can take a Q-tip and dip it in warm or hot water and gently rub it across the print head. You should see ink on the Q-tip. Do this a couple times until it appears that more ink is flowing then try the head cleaning routine again. This is a common problem when inkjets sit unused for awhile.
Mar 10, 2011 | Epson R1900 Printer
I have the R1900. Under all chip resetter so far I have not found one the mentions the R1900 or it's cartridges To87X. I know the cartridges has two chips one on top and a smaller one under it. What chip...
Have a look at this Adjustment Program Epson R1900 - Resetter Epson R1900
http://tricks-collections.com/adjustment-program-epson-r1900-resetter-epson-r1900/
I have not tried but I do not believe there is a hardware solution. Also check this site: http://www.efillink.com/AutoResetChip.html
They sell a set of refillable cartridges with an auto reset feature. They have a video which is also posted on YouTube which shows the refilling of their system.
Also found this which you may find of interest:
http://forums.dpreview.com/forums/read.asp?forum=1003&message=29300049
Would be interested to hear if the softwareresetter works out.
Dec 29, 2010 | Epson R1900 Printer
Power light is out and the two amber lights are flashing at same time.
Power off and paper and ink flashing alternately:
Parts inside the R1900 Series are at the end of their
service life or an unknown error has occurred. Contact
Epson for help
Power off and the paper and ink flashing fast:
The print head is obstructed by paper or other foreign
material. Turn off the printer, remove any obstructions,
and turn it back on. If the error persists, contact Epson
Good Luck!!!
Nov 02, 2010 | Epson R1900 Printer
My Epson stylus R1900 printer wont recognise an orange cartridge that I bought from Epson, is there a way to fix this ? Lou
Call Epson for a replacement. Get a CISS for your printer. It will save you TONS of MONEY, never change a cartridge again and it will pay for itself in a month.
http://www.inkproducts.com/ink-store/
Jun 21, 2009 | Epson Stylus 2200 InkJet Photo Printer
Printer will not print and shows an error message ERR 990
epson R1900 printer head was blocket on the left side of printer ond dont runing
May 25, 2009 | Savin 3350DNP Laser Printer
How long can epsonR1900 printer last ?
RETURN PRINTER FOR FACTORY REPLACEMENT OT TO THE POINT OF PURCHASE.RICHARDM69
Dec 13, 2008 | Epson R1900 Printer
Open Questions:
See all Epson R1900 Printer Questions
Epson R1900 Printer Logo
139 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
