Question about Gateway GTW-P42M303 42 in. Plasma Television
No picture I have a plasma screen gateway television and all of a sudden the sound went off, so I turned the tv off and waited a minute and then turned it back on... NOw i hear little sound and its all black with a random pixle here and there flashing. What went bad and how can i get this fixed?
SOURCE: Gateway GWT-P42M303 screen problem
the 15v is shorted to the ysus board and probably one of the two big heat sinks with the number 4921QP1002B is the cause. If you don't repair it can I have it for parts?
Posted on Apr 17, 2008
SOURCE: Slow start
(I'm copying a guest's comment above. What Gateway told him does seem to work - although in my case, the monitor was slow to start when plugged directly into the wall, and it was immediately fixed when I plugged it back into a heavy duty power bar.)
hey, I had the same problem. Gateway told me "Plug the monitor power plug directly into a wall electrical outlet
or a different wall outlet by removing any surge suppressors." I did that and it works. It might be a certain kind of power bar they do not like. It worked for me so try that and see if that helps.
Posted on Sep 17, 2008
  • 3 Answers
SOURCE: remove back panel on gateway plasma tv
jeff
I just took the back off my Gateway for a simular problem
I just took the screws out of the legs on the back of the set and all the screws around the edge then the support where the legs were attached and then the screws around the box with all the video jacks that pulls off. Hope this helps
brucep63
Posted on Mar 24, 2009
SOURCE: plasma tv picture goes on and off but always has sound
I install a fan in the back, there is a only o9ne 5 v, 3,3 a that you can connect workin fine..
Posted on Apr 14, 2009
stonephoenix
  • 563 Answers
SOURCE: The screen on my Gateway Plasma 42 in TV went
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. The question will be, is the part still available? Before paying a TV repair person $75+ to diagnose the problem, ask yourself if you're willing to pay $250 minimum to fix this particular set. Also keep in mind that most TVs that old have a very limited number of replacement parts still available. Normally it will cost at least $75 to have the set looked at by a repair shop (diagnostics). If the part needed to complete the repair isn't available, you won't get that money back.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here.
Please let me know if I can be of further assistance.
Posted on Jun 18, 2009
No picture, no sound
Diagnose the Problem
The first step in diagnosis is to check the display for any cracks on the screen. If the screen appears cracked, then the repairs may require plasma screen replacement. A cracked screen means that the gases inside have probably escaped. There is no way to refill the gases and the whole display will have to be changed. In this case, an authorized service may be able to provide more details. If the problem persists, then a gas leak is perhaps not the cause of a loss in display. Lamp burnout could be one reason behind a blank screen.
Check the Fuse
Most of the time, the plasma TV fuse is at fault for no picture on an LG Plasma screen. In such a case, changing the fuse should make an LG Plasma TV functional.
  1. Unplug the TV and wait for 10 minutes for the capacitors to discharge.
  2. Take a Digital Multimeter and set it to the 0-200 ohm range.
  3. Touch the red and black probes to each other and check the readings. The multimeter reading should be in the range of 0-2 ohms.
  4. Now touch the red and black probes to each end of the fuse. If the multi-meter reads '1' or 'OL', then the fuse has blown and needs replacement. If the multi-meter shows the same reading as before, the problem lies elsewhere. Some cases may require the motherboard to be completely replaced.
Fix the Problem
If an LG plasma TV has no picture and no sound, then either the Y-sustain or the Z-sustain are at fault. Follow these steps to determine and fix the problem.
  1. Unplug the TV and wait for 10 minutes for all the capacitors to discharge. Then open the back panel of the TV.
  2. Unplug the Z-sustain from the TV and plug the TV into the power supply. If there is sound, then the Z-sustain is faulty and will need changing.
  3. If there is no sound, follow the same procedure and unplug the Y-sustain. Check for sound. If there is a sound, then the Y-sustain is faulty.
  4. If the Y-sustain is faulty, a user may have to check the Y-buffer. He will have to follow the same procedure and unplug the Y-buffer this time. If there is some picture with sound, it means that the Y-buffer is faulty.
Keep in mind that a plasma TV runs on very high voltage. The voltage on some connectors exceeds 400V (in excess of 200 joules of energy). This high voltage can be very dangerous. That why it's important for users to always make sure the capacitors have discharged before performing any type of diagnosis or fixes on an LG Plasma or any other television set.
Feb 04, 2016 | LG 42PW350 42-Inch 3D Plasma HDTV...
Have a haier plasma tv model#42hp25bat. sound but no picture. can it be repaired?
Did this occur suddenly, or was the picture gradually failing over time?
Jun 05, 2008 | Televison & Video
6MTH OLD HOTPOINT PLASMA TV SUDDENLY HAS NO PICTURE NO SOUND
Hiya!
Sounds like it's on the wrong input, maybe it's analog tuner. Have you tried changing it's input?
Feb 21, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Turns on But No Picture and No Sound
sounds like it could be a cabling issue, try replacing the cabling (if you have another tv, you can borrow the cabling before purchasing new set of cabling)
Apr 04, 2009 | LG 50PC5D Television
50 inch LG plasma model 50PX5D. Lost picture and sound
well it looks to me u need a new tv....all the details u give are pointing that ur picture tube is gone.....but call LG help and costumer line and ask them......u may get away from it to get a new tv
make sure when u get a new plasma to extend ur warren tie to a max o 3 to 5 years and if this would happend u get it repaires for free.......cost for a new screen app 1000 to 1500 dollars
Mar 12, 2009 | LG 42PC3D 42 in. Plasma Television
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
Toshiba 50HP66 Blank Screen with sound
I would suggest to read what other members have reported by clicking here.
Good Luck.
Apr 28, 2008 | Toshiba 50HP66 50 in. Plasma Television
DELL 42 inch Plasma TV
I have a 42" LG LCD TV and just experienced this today. Watching cable, then the screen went to black, but audio continued. I pressed the guide button on my remote and pic came on with my guide menu. But then went to black again 10sec later and has remained that way for nearly an hour. Tried switching off both cable box and TV, disconnecting and reconnecting cables, but no luck. Finally unplugged mains, waited a minute, then turned back on. Everything seems normal now after the reboot. Phew.
Jan 17, 2008 | Sony KV-36XBR450 36" TV
The screen went black
I tried to see where you come from but it was unspecified. If you are in the States you might be lucky....go here and have a look they might be able to fix your screen up.. http://lcdrepair.net
Sep 11, 2007 | Sony FWD50PX2/S 50 in. Plasma Television
Sony FWD50PX2/S 50 in. Plasma Television power problem
It does sound like a power supply problem but that can be misleading because a problem somewhere else in the TV can be "holding down" the power supply. This can usually be determined by using some isolation techniques.
Aug 08, 2007 | Sony FWD50PX2/S 50 in. Plasma Television
Gateway GTW-P42M303 42 in. Plasma Television Logo
189 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
