Question about Acer Computers & Internet
How do i find the password for my acer computer notebook with model number MS2253?
  • Craig_Evans May 11, 2010
    Which password? For your login or something else?
  • 33 Answers
Aspire x1800
Setting up a password on the Acer Aspire prevents others from accessing the computer without permission.
If the user is unable to supply the correct password at startup, the computer will lock the hardware and fail to boot.
This security measure is a useful feature, but it can create serious problems if you forget the password.
Basics
The Acer Aspire stores the password in a component called the complementary metal-oxide semiconductor.
This component is integrated into a random access memory chip embedded on the motherboard. The CMOS holds data that the basic input/output systema critical software utility that controls how the computer operates at startupaccesses when the computer boots.
If the BIOS detects that a password is registered in the CMOS, it will prevent the computer from booting until the user enters the password correctly.
Depending on which model of Acer Aspire you own, you may be able to clear the CMOS manually.
Contact Acer before attempting to clear the CMOS, as opening the computer without permission could void your warranty.
Desktop Models
Some Acer Aspire desktop models come with a jumper that is used to clear the password and other settings stored on the CMOS.
This jumper is located on the motherboard and is often found next to a label such as "JBIOS1" or "CLR_CMOS." To clear the CMOS using the jumpers, turn off the computer, disconnect the power cable and remove the case cover.
Remove the jumper shunt from pin 1 and pin 2; then place the shunt on pin 2 and pin 3. Return the shunt to its initial position after 10 to 15 seconds.
If the Aspire doesn't come with a jumper to reset the CMOS, the CMOS can be reset by removing the lithium coin-cell battery instead.
Removal is accomplished by pushing down on the tab securing the battery to the motherboard and lifting the battery out of its slot.
Leave the battery out for 24 hours, and then return it to its original position with the positive sign facing up.
Laptop Models
Resetting the CMOS password on an Acer Aspire laptop is much more difficult than resetting the password on a desktop.
Disassembly steps vary from model to model, but on most models, you'll have to take apart the computer to access the CMOS battery.
Don't take apart the notebook if you don't have experience disassembling PCs.
After turning off the computer and disconnecting the AC adapter, take out the battery (different from the CMOS battery).
All visible screws must then be removed from the bottom of the notebook.
Remove all components stored to their separate compartments on the base of the notebook.
Turn over and open the PC.
Lift up the switch cover and remove the screws securing the keyboard to the PC, if any are visible.
Remove the keyboard.
Remove the screws securing the monitor to the hinges, and then set the monitor aside. Disconnect all visible cables connected to the motherboard; and then remove the screws from the top cover.
Remove the top cover to reveal the motherboard.
Locate and then remove the CMOS battery.
Leave it out of the notebook for 24 hours; then reinstall it and reassemble the Acer Aspire.
Other Options
If removing the CMOS battery fails to clear the password, or if you don't feel comfortable with the idea of opening your computer, you might be able to gain access to the computer using a backdoor password.
These special passwords were implemented to allow technicians to access locked computers. Not all models recognize backdoor passwords.
Most Acer Aspires use the Phoenix BIOS, and backdoor passwords for this BIOS include "BIOS," "CMOS," "phoenix" and "PHOENIX."
All of these passwords are case-sensitive.
May 04, 2014 | Acer Aspire Computers & Internet
Computer was locked
Turn over and open the PC. Lift up the switch cover and remove the screws securing the keyboard to the PC, if any are visible.
Remove the top cover to reveal the motherboard. Locate and then remove the CMOS battery. Leave it out of the notebook for 24 hours; then reinstall it and reassemble the Acer Aspire.
Other Options
If removing the CMOS battery fails to clear the password, or if you dont feel comfortable with the idea of opening your computer, you might be able to gain access to the computer using a backdoor password.
Most Acer Aspires use the Phoenix BIOS, and backdoor passwords for this BIOS include BIOS, CMOS, phoenix and PHOENIX.
Apr 22, 2013 | Acer Computers & Internet
How to unlock a computer
Is it an aspire ?
Other Options
How to remove the bios password and the windows password
Step 1:
The Acer Aspire stores the password in a component called the complementary metal-oxide semiconductor. This component is integrated into a random access memory chip embedded on the motherboard. The CMOS holds data that the basic input/output system - a critical software utility that controls how the computer operates at startup - accesses when the computer boots. If the BIOS detects that a password is registered in the CMOS, it will prevent the computer from booting until the user enters the password correctly. Depending on which model of Acer Aspire you own, you may be able to clear the CMOS manually. Contact Acer before attempting to clear the CMOS, as opening the computer without permission could void your warranty. Desktop Models Some Acer Aspire desktop models come with a jumper that is used to clear the password and other settings stored on the CMOS. This jumper is located on the motherboard and is often found next to a label such as "JBIOS1" or "CLR_CMOS." To clear the CMOS using the jumpers, turn off the computer, disconnect the power cable and remove the case cover. Remove the jumper shunt from pin 1 and pin 2; then place the shunt on pin 2 and pin 3. Return the shunt to its initial position after 10 to 15 seconds. If the Aspire doesn't come with a jumper to reset the CMOS, the CMOS can be reset by removing the lithium coin-cell battery instead. Removal is accomplished by pushing down on the tab securing the battery to the motherboard and lifting the battery out of its slot. Leave the battery out for 24 hours, and then return it to its original position with the positive sign facing up. Laptop Models b> Resetting the CMOS password on an Acer Aspire laptop is much more difficult than resetting the password on a desktop. Disassembly steps vary from model to model, but on most models, you'll have to take apart the computer to access the CMOS battery. Don't take apart the notebook if you don't have experience disassembling PCs. After turning off the computer and disconnecting the AC adapter, take out the battery (different from the CMOS battery). All visible screws must then be removed from the bottom of the notebook. Remove all components stored to their separate compartments on the base of the notebook. Turn over and open the PC. Lift up the switch cover and remove the screws securing the keyboard to the PC, if any are visible. Remove the keyboard. Remove the screws securing the monitor to the hinges, and then set the monitor aside. Disconnect all visible cables connected to the motherboard; and then remove the screws from the top cover. Remove the top cover to reveal the motherboard. Locate and then remove the CMOS battery. Leave it out of the notebook for 24 hours; then reinstall it and reassemble the Acer Aspire. Other Options b> If removing the CMOS battery fails to clear the password, or if you don't feel comfortable with the idea of opening your computer, you might be able to gain access to the computer using a backdoor password. These special passwords were implemented to allow technicians to access locked computers. Not all models recognize backdoor passwords. Most Acer Aspires use the Phoenix BIOS, and backdoor passwords for this BIOS include "BIOS," "CMOS," "phoenix" and "PHOENIX." All of these passwords are case-sensitive.
Mar 26, 2013 | Acer Aspire One AOD257-1497 Atom N570...
I forgot my power on password and i dont know my bios how can i reset password please help
is it windows password or BIOS password ?
which version, model and computer are you using ?
Jan 16, 2013 | Aspire Acer 7520-5071 Notebook
How do i reset my password , for an acer aspire model number ms2279
Hi
if you just want to reset a user password go into control panel users find your account and set a password
if its a bios password i believe you have to do it in the bios by pressing delete or F2 on startup but be very carefull not to alter other settings in the bios
Apr 26, 2011 | Acer Aspire 4520-5582 Notebook
Bagaimana membuka password bios acer 4315
Just go to here
Enter your model and hash code and they email back your bios master password for your Laptop/computer.
Sep 08, 2010 | Acer Aspire 4315 Notebook
My acer model number ZG5 not login windows i forg...
At one time I forgot my windows password. I created a windows password recovery disk with a third party program available from http://www.windowsloginrecovery.com
May 21, 2010 | Acer Aspire One PC Notebook
Computers & Internet Logo
318 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
