Question about GE Refrigerators
GE side by side refrigerator model tps24bp
The refrigerator door does not appear to be sealing properly when closed.  It takes very little effort to open the refrigerator door unlike the freezer side.  It used to take alot more effort to release the "vacuum" of the unit.
  • 210 Answers
SOURCE: Freezer Door Popping Open
Look at the bottom of the freezer door, there is a little plastic stopper there. It may be worn out or broken. When you close the door this is what holds it there. Start there first.
Sgt 48
Posted on Jun 17, 2008
SOURCE: refrigerator not keeping cool
Your coils could be clogged with debris. i had the same problem. You can go to home depot and get a specific brush that you can use to clean out the coils. They are either behind the fridge, or under the fridge. Do it on a regular basis, cause that can cause the compressor to burn out. I am not an expert, but that worked for me
Posted on Feb 13, 2009
lenwest
  • 150 Answers
SOURCE: freezer door wont seal and stay closed
Your pushing air from the fridge part over to the freezer door when you clos it,the only thing i can suggest is make sure that the seal (which is magnetic) is clean and not falling apart,inspect it all around the door,and when closing the door i would close it gently.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Posted on Feb 27, 2009
tborn6
  • 700 Answers
SOURCE: Freezer door not sealing well (Frigidaire side-by-side)
your house may be settling and now the refrigerator needs to be tiloted back slightly. take run the adjusters on the front in a little until the doo closes by it self.
Posted on Mar 29, 2009
Greg20
  • 149 Answers
SOURCE: I have a side by side GE Monogram. When closing
the refrigerator should be leaning back enough to allow it to reclose. there are hieght adjusters behind the grill on front
Posted on Jun 12, 2009
Is there a kit to repair French Door from popping open GE model# PFS2251SBSS
Check to see if the door is warped or the hinges are not aligned. Also, does the door open easily or does it take a little effort to break the magnetic seal? If it open easy then the door seal could need replacing.
Jul 25, 2014 | GE Refrigerators
Jenn-Air side by side refrigerator, Model JRSD2490. Not staying cold enough
Larger=colder. Make sure that 1) your magnetic strip around the fridge door is sealing well. Even a small leaking area could make it difficult to keep cold, especially in warmer areas. Also, make sure there is nothing obstructing the door from closing completely and sealing properly. I had this same issue where one of the door shelves was unlatched a little and the door would close but not seal. Beyond that could be motor or more likely compressor or coolant leak. Good luck.
Jun 20, 2014 | Jenn-Air JCD2389G Side by Side...
GE (Side x DSide) Adora: closing fridge door causes the freezer door to open
That will happen if you close the door too quickly or make sure the freezer door gasket is sealing properly.
Nov 20, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
Freezer door does not close properly
inspect the seal all the way around the door. check to make sure that it is not in a bind when you open and close the door. if it is you can try a little wd40 or silicone spray on the gasket and frame of the refrigerator where the gasket meets the frame. this will help it slide accros the frame better.
if the gasket is bound up and out of shape, you can heat it up with very hot water to straighten it.
make sure that you keep the gasket and the door facing clean. spillage from the use of the refrigerator/freezer can cause the gasket to stick especially at the bottom.
Jul 01, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
When we close the refrigerator door (side-by-side unit) the freezer door pops open slightly. The unit is about 14 months old and the seals look fine.
There is something not fully in place holding the door from closing completely. It doesn't take much. You should be able to feel slight resistance when opening if it is seated properly. The cavities are connected so when you close the door fast the air pressure moves from one to the other and pops the door open.
Eric
Oct 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile freezer door problem
I wil let you know of things you can do to solve this.
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
Hope this helps, Thanks Sea Breeze
Sep 22, 2009 | Refrigerators
Food and water freezes but ice cream is soft
Check the door gasket seal.
Open the door for a few seconds and then close.
Immediately open the door again, and, if sealing properly, it should take more pulling force to open the door.
Mar 30, 2009 | Refrigerators
GE Profile Arctica Side-by-Side Refrig PSC23MGMB IS WAY TOO COLD!
it sounds as if the ice door is not closing properly. Check the little rubber door seal to see if it is sealing properly. If not try a hair dryer to soften it. Otherwise you have to buy a door kit.
Feb 01, 2009 | Refrigerators
Refrigerator door not closing tightly
HI. thanks for your question. sometimes you put a lot of heavy jars in the door shelves . so i would raise the front of the fridge to help it close better. thanks
Oct 15, 2008 | GE Monogram ZISx420DR 42-inch Side by Side...
Refrigerators Logo
231 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
