It a H5461BP oven. Food spills including sugar has been baked onto the bottom of the oven. I am afraid to use anything too strong or harsh on the oven. I have scraped the surface spill of with a metal spatula but am afraid of damaging the surface. I'm afraid to use the pyrolytic process in case it makes the problem worse
SOURCE: Oven bakes unevenly and burns food
Jenn Aire oven is about 5 to 7 % cooler than electronic temperature setting. How may this be re-calibrated?
SOURCE: Burnt marks inside glass oven door
stain is between glass in oven door. can we take door apart
SOURCE: I have foil that is baked on the bottom of my oven
Should never line the oven or surface pans with type of foil as it becomes brittle from the heat and can cause major electrical problems and you money. Clean the foil out of the oven and you will be good to go.
SOURCE: Food spilled between the two pieces of glass on the door
careful when cooking. u have to take the dor apart to clean this
SOURCE: my pilotless oven wont light
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
