Question about HP PSC 1315 All-In-One InkJet Printer
I can not reinstall Windows..and hard disk is not working
I can not reinstall Windows..and they sad it from my hard disk is not working...but when i make it salve it cam"s but it freeze the PC..why?
    Sniper:
  • 73 Answers
Your hard disk medium is not working properly or it is disturbed, thats why it cannot read the boot up sequence or 0 sector data. You are facing this problem in both cases as master and slave. The best solution is to change the drive, othervise you hard is not reliable, it may disturb all of your data in future or may not responed or boot up.
Best regards.
Posted on May 25, 2009
  • 585 Answers
Did you use the option to remove all partitions and create/format new partitions for the install? That could be what you missed.
  • Bruce Volkers
    Bruce Volkers May 26, 2009
    If there is only one hard drive, the jumper on it must be set to CS (cable select) or to Master depending on the bios.
No operating system found/compaq presario
Sadly the disk is corrupt, buy a new hard drive and get the data off the old one.
Dec 16, 2012 | Compaq Presario M2000 Notebook
I need a new hard drive do I need to reinstall windows agin
Yes the new hard drive will be completely blank. Your dell should have came with recovery disks (a windows disk, driver disk, ect) or a recovery patition that you would have to burn the disks from to make a set of disks. These disk will reinstall the software on your Dell computer and make it fully functional. If you do not have any recovery disks, you can contact Dell for a set. Be aware they sometimes will charge a fee to provide you with these disks.
Hope this helps
Jun 17, 2012 | Dell Inspiron 15 Laptop
I have dell inspiron 1525, with windows 7, and this message appear whenever trying to login to my pc.. "Windows failed to start, a recent hardware or software change might be the cause. File:...
The hard drive may had a BAD SECTOR ( corrupt section )
try to format with normal mode,NOT quick format.
try using LLFTOOL ( hard disk low level format ) http://hddguru.com
quite bit longer to fix the bad section,but works.
akee.4shared.com
Aug 15, 2011 | Dell Inspiron 1525 Laptop
I cannot start windows xp. Reboot not possible. I get error message Invalid partition table. Recovery package does not work, system failure. What can I do?
Sadly, you've lost the hard disk partitions. You can try to recover that with software from Hiren's Boot CD, under Partition Tools: http://www.hirensbootcd.org/. If that won't do it for you you will have to repartition the HDD and reinstall Windows, but you will lose everything from it.
The bad news is that probably the hard disk drive is failing so you may need to get a replacement.
Jan 29, 2011 | Computers & Internet
I'm getting a popup "windows
Modern disk-drives have built-in performance-counters and self-diagnostic capabilities.
These 'SMART' disk-drives can tell when the disk-drive is not performing "optimally";
it's a sign, as Windows indicates, that the disk-drive is *SOON* to completely *FAIL* to work.
Backup your files (and E-mail and contacts and music) to DVD-recordable media, or to an external file-storage system. Then, on another computer, "test" to ensure that you can read that backup copy, before you do anything to the "original" files.
Then, buy a replacement disk-drive, install it, and reinstall Windows onto it,
reinstall your anti-virus, reinstall MS Office, run Windows Update several times,
and finally reload your files from your "backup" device.
Nov 29, 2010 | Toshiba MK2546GSX 250GB SATA 5400 RPM 8MB...
I can not reboot my Dell Studio XPS 1645 running Windows 7, because everytime I try reboot my computer the Windows Dianostics Utility keeps on starting up. I tried to use my Windows 7 installation...
Sounds like you've tried everything except a complete reinstall. If there is information you need off that computer the hard drive will need to be taken out and plugged into another PC as a second hard drive then all can be copied. Then try a complete reinstall and good luck with that. If any problems doing a reinstall i would look at the ram. Cheers from Scott and plz vote
Nov 03, 2010 | Dell Studio XPS 1645 Laptop
just try to repair your OS if you are using windows xp. use that repair option after F8 during installation of XP.
Jan 07, 2010 | Compaq Presario Notebook
Installing windows on acer notebook help
you cannot usually switch installed operating systems from computer to computer like that and still expect windows to boot, but with windows 98 it *might* work.
to install windows 98 on the usb drive, insert and boot from the windows 98 disk like you were to install it on that computer , and then, it should, before it formats any drives, give you a choice of what drive to format.
Oct 09, 2009 | Acer TravelMate 340T Notebook
Lenovo T61error 2100: HDD0(hard disk drive)
To all users with: lenovo T61error 2100: HDD0(hard disk drive),
Possible cause:
  1. Corrupted hard disk logical sectror/hard disk logical error (bad format).
  2. Hard disk connector not well in place.
  3. Hard disk broken, physical fault.
Solutions:
  1. Format hard disk and reinstall system using a Windows setup CD.
  2. If that does not work the Hard disk must be removed to check thge connector, and to test the hard disk on a different computer.
  3. If the hard disk is bad , it must be replaced, and windows reinstalled repeating step one.
Nov 25, 2008 | Lenovo ThinkPad T61 Notebook
New hard drive to install windows sayind
If you have not checked these(I am sure you have probably gone through this or don't need to but just in case)
First thing is first you have installed a new hard disk, is this the only hard disk installed. If Yes, does the bios recognize it? If Yes, is it bootable. Meaning is there a working copy of windows installed? If not reinstall from windows installation disk. If Yes, you may still have to reinstall windows you can use the windows installation disk as well.
This sounds like an issue that I had taking a hard drive from one computer and placing it in a brand new one. This message sounds like windows is damaged. I had to reinstall windows and leave the file system intact. There is an option to do this. If you feel comfortable you can always use a boot disk and check the boot .ini to make sure that it has the correct path for windows written in that may be the issue there. This file is hidden in the root directory of the drive.
Nov 30, 2007 | Computers & Internet
HP PSC 1315 All-In-One InkJet Printer Logo
55 people viewed this question
Ben Johnson
