Question about Teledyne Laars Laars Lite 2 Pool Heater 250,000 Btu / Propane Gas
Pilot light on but heater will not start
Pilot light is on but pool heater will not start. Repair person suggested to replace fusible link assembly but still does the same. Heater is a teledyne laars lite using propane. Tank is full
  • 3 Answers
Check the high-limit switches. Under the inlet/outlet header. if either is open it will not allow you to fire up. my 150 degree switch was corroded and after jump9ng out, bam it worked.
Posted on Aug 07, 2010
Laars Pool Heater, pressure valve or something else,
bad pressure switch or incorrectly set should have no continuity when off it should when running put on 2000 for ohms should have 500 millivolts when off then turn on and it will start counting down at about 200 should light make sure all connections are good and all safety circuit is good
Jun 24, 2015 | Teledyne Laars Laars Lite 2 Pool Heater...
Unit takes about a minute to light then the built up gas explodes(for lack of a better word). Unit runs fine after that. This can't be right. What could be the problem?
burner orifices need to be cleaned out. pull the burner assembly out and clean the burners and manifold orifices. im surprised the flame roll out didn't blow the fusible link
May 31, 2014 | Jandy Lite 2 Natural Gas Pilot Light...
Zodiac Jandy Legacy LRZ Pool Heater pilot wont light only used 1 season
check safety circuit possible fusible link open if bad check gas pressure if too low will run too hot and soot up make sure to clean outside of heat exchange so heat can go through top not front
May 27, 2012 | Zodiac Jandy Legacy LRZ 175K Commercial...
The service person replaced the fusible link on my LAARS Lite 2 heater. It worked for a while, but then it stopped (won't turn on or heat). I removed the two wires from the fusible link and shorted them...
The fuse link is a saftey for flame that is rolling up into the cabnet,There are a few things that will make this happen,down drafting from wind,cloged flue,burners cloged,gas pressure.Turn it on with the cover off and stand back look to see if any flames are rolliing up near the fuse link.
Jul 07, 2010 | Lite On Laars Lite 2 Heaters: 250,000BTU...
I HAve old Teledyne Laars pool heater. When I try to light the pilot it a larger flame creeps out from the pilot. IS this a pilot generator issue. Also any links to old terradyne manuals ?
The aluminium has gotten old in the pilot tube and is starting to leak. You can just replace the tube but when you start disturbing the pilot it can lead to other problems. I would sugest getting a whole new pilot assembly and replaceing the whole thing.If it that old be sure to ask for propane or natural gas when you order the part.
I don't know about old books online but you can write to Laars and ask them. They are under Jandy-Laars now.
Jun 27, 2010 | Teledyne Laars END CAP - 10403800
Pilot wont light //suspect corrosion, connections..
If your pilot assembly is corroded, you will have trouble lighting the pilot.
I would highly recommend replacing the pilot assembly. By doing this, you will have a new pilot generator that will be producing a larger amount of voltage to run the gas valve. Also, you will have a clean pilot tube and orifice so gas can run unobstructed.
Oct 21, 2009 | Hayward H Series Millivolt 250,000 Btu...
Gas pool heater pilot will not stay lit
Depending on the make and model of your heater, the first thing I would check for is gas pressure. If it is sufficient, check the pilot assembly for corrosion and/or a damaged pilot tube. Sometimes replacing the entire pilot assembly is a sure fix and also replaces the pilot generator that degrades over time. A new pilot assembly takes care of a couple of problems by improving gas flow and millivolts generated. Also, the orifice inside the pilot assembly could be corroded or clogged.
Jun 15, 2009 | Hayward H Series Pool & Spa Heater 400k...
Pool heater won't stay lit
check gas pressure might be running out of pressure gas meter might be too small and heater could be overheating
Jun 03, 2009 | Teledyne Laars Pool & Spa
Laars LX400P pool heater Hi Limit Switch light is on? ???Fix?
This indicator normally means that your water temperature in the pool heater exceeds the internal limit. The corrosion should not be causing this problem. Since the high temperatures can be dangerous, you will probably have to contact a pool professional to service the machine.
May 31, 2009 | Teledyne Laars Laars Lx Pool Heater /...
Teledyne Laars Laars Lite 2 Pool Heater 250,000 Btu / Propane Gas  Logo
413 people viewed this question
Top Teledyne Laars Pool & Spa Experts
paulcarew
Jay Finke
Jay Finke
Bill Jordan
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
