Question about Kensington (K33348) Bluetooth Wireless Adapter
How to function for vista
I have this adapter, but it does not work on my pc because i have Vista on it.
Could you send the solution for my problem. I would realy apreciate.
Thank you.
  • 4 more comments
  • dbscout Nov 30, 2007
    I also have this adapter, but it does not work on my pc because i have Vista on it; also software povided by Kensington does not install on vista and the usb port with the bluetooth is not recognized.
  • irisheye Jan 07, 2008
    same here...vista will not allow setup.exe file from kensington website to run
  • Oasis75 Feb 19, 2008
    Even run in compatiblity mode adapter doesn't work. Crashes system after restart :(
  • Anonymous Mar 25, 2008
    same thing
  • Anonymous Jan 31, 2009
    Same here.
  • Anonymous Feb 20, 2009
    Kensington Bluetooth will not work in Vista 64-bit
Must set software to "XP compatable"
and
"Run as Adminstrator"
Posted on Jan 06, 2008
Does dynex DX-WGDTC wireless desktop work for windows vista
The DX-WGDTC adapter is not compatible with Windows Vista. It was designed to work with Windows 98 through Windows XP. However, you can try to use it with a Windows Vista system. What will happen a lot of times is that the router will provide basic functionality but it may display some quirks, or it may drop the connection occasionally.
You can get a decent Wireless-G adapter for $30 or so, so you're probably better off just buying a Vista-compatible adapter, but if you already have this one, might as well see if it will work!
May 06, 2010 | Dynex 802.11g Wireless-G Desktop Card
Wireless Problems dv6400
Windows WiFi Fix,
Windows Zero Wireless Configuration is one of the best programs to run a WiFi in Windows XP or Vista. Most of the other software packages that come with the different adapters have been poor at best in keeping a connection through Windows. Here is the best guide to get you back up and connected.
Windows XP:
Click Start
Right click on My Computer
When a window pops up click on properties
Click on the Hardware tab
Click Device Manager
Click the [+] next to Network Adapters
Find your wireless card and right click on it.
Click Disable
Windows may warn you that disabling the device may make it stop functioning.
Continue disabling the device.
Wait 30 seconds or so.
Right click on your wireless again and click Enable.
Exit the device manager.
Reconnect to your router.
You should now be able to connect to the internet.
Windows Vista:
Click Start Logo
Right Click Computer
Windows will ask you about opening Device Manager Click Continue
Click Disable
Oct 26, 2009 | Computers & Internet
Cisco Aironet350(AIR-PCM352) compatible with vista
Sorry to say but this adapter don't have a driver for windows Vista so the chance that it will work with it is very small, the possibility that this device has a built in driver on vista is also a small chance so its safe to say it wont work with vista...
Jul 31, 2009 | Cisco Aironet 350 (AIR-PCM352-BSTK)...
Error code 43 "Incompatible display adapter has been disabled"
I have got Dell comp with same n-vidia 8800GT suddenly after installing adobe's update only 1 monitor functions and slowly.
Any reinstaling and updating drivers that i ve tried did not help.
May 07, 2009 | PNY XLR8 NVIDIA GeForce 8800 GT 512MB...
Voyager 5929 doesn't work with Vista
The problem isn't your scanner or Vista, it's your adapter. Power requirements and speed of data require special adapters. One I always recommend is Scan Technology's part # STI-PS2-USB. I've tested it with all Metrologic scanners and it hasn't failed yet.
Dec 30, 2008 | Metrologic Instruments Voyager MS9520...
How to install Fuji Finepix 2650 in Windows VISTA environment?
All Fujifilm digital cameras will work on Windows Vista using drivers already installed on the operating system.
The finepix viewer software supplied with our cameras will require a update which can be downloaded from the following link
http://www.fujifilm.com/products/digital/download/02/index.html#windows5.3
Accessories
The following products are not compatible with Windows Vista:
FD-A1/FD-A2 (Floppy Disc Adapter)
DM-R1 (Image Memory Card Reader)
DPC-R1 (Image Memory Card Reader)
The following products are compatible with Windows Vista:
SM-R1/SM-R2 (Image Memory Card Reader)
PC-AD3 (PC Card Adapter)
DPC-AD (PC Card Adapter)
DPC-CF (CF Card Adapter)
DPC-UD (USB Pen Drive)
Nov 11, 2008 | Cameras
Display drivers for vista
Hi all,
I tried numerous solutions for this issue and none of them worked except this one. I tested it with Vista Ultimate and don’t know if other Vista versions have the same drivers but here’s what worked for me:
1. Right click ‘Computer’ then left click ‘Properties’ to open up System window.
2. Click ‘Device Manager’
3. Click ‘+’ on ‘Display Adapters’ and you should see the drivers for your video. Right click and select ‘Update Driver Software...’
4. Select ‘Browse my computer for driver software’ and click ‘next’.
5. Click ‘Let me pick from a list of device drivers on my computer’
6. Untick ‘Show compatible hardware’
7. Select ‘Intel Corporation’ then select ‘Intel 82865G’. Click next
This will install the drivers. No they are not the same drivers for the hardware but they work a treat!
- Lorenzo Rubbo
Nov 02, 2008 | Dell OptiPlex GX260 PC Desktop
My wireless network adapter's device driver doesn't work
Download the latest drivers for XP or Vista
Note: If you can't find Vista drivers for Vista use XP drivers.
Uninstall the driver from XP or Vista.
If you have PCMICA adapter card in laptop remove it.
Reboot the PC
Note: If the network adapter is built-in laptop or PCI (desktop) leave it along.
Re-install the drivers and wait for the driver to tell you when to install the device if you have this option and don't have PCMICA card adapter for wireless.
If the card still doesn't work it could be faulty or OS is corrupted and needs to be re-installed. (this would be the last step to fix the problem)
Aug 01, 2008 | Computers & Internet
Can't connect to internet with 2wire PC port
yes U R right. this is most probably a "Driver" problem. You could try installing the software in "Administrator Mode".. with "Compatability Mode" set for XP. If this doesn't work.. then ya may have to try to contact the manufacturer and ask for a compatable driver for Vista.
Aug 31, 2007 | 2wire PC Port Phoneline HomePNA 10Mbps USB...
Kensington (K33348) Bluetooth Wireless Adapter Logo
249 people viewed this question
Top Kensington Computers & Internet Experts
Alun Cox
Pierre Legault
Are you a Kensington Computer and Internet Expert? Answer questions, earn points and help others
