Question about Barbeques Galore Bar-B-Chef Charcoal Smoker 263350
Cooking times we have misplaced our cooking time manual
    Problem Solver:
  • 12 Answers
Check out bbq.about.com
Posted on May 25, 2009
Sears kenmore elite has a message display to enter tcp code. kenmore microwave oven
TCP is "True Cook Plus" in Kenmore speak.
Here is a cut/paste of a section of the manual.
*CUSTOMIZING TrueCookPlus' You may find that you prefer TrueCookPlus® to cook your food more or less. TrueCookPlus " can adjust to your tastes - to cook your food hotter or cooler - automatically: Example Clear 1. Press the Clear button. (§H§ 1 2. Press the TrueCookPlus® button twice. 3. If you want less cooking time when you enter a TrueCookPlus code, press 1. This will decrease the time by 6%. 345 4. If you want more cooking time when you enter a TrueCookPlus® code: Press 3 for 3% more cooking time. Press 4 for 6% more cooking time. Press 5 for 9% more cooking time. 2 5. Press 2 to reset TrueCookPlus* to factory setting default time. 6. Press the Start button.
I didn't try to clean up the copy
Hope this makes sense and helps.
Sep 14, 2017 | Kenmore Microwave Ovens
How do I change temp and time while food is cooking?
all is explained in the user manual
if you have just put food in the even and pressed the start several times to get a number of minutes to cook but want to increase that time just press start again the number of times that you want the cook time to increase
for example :-
you put a frozen pie in the oven and your start operates in 30 second increments and you have pushed it 3 times and it starts cooking-BUT - you read the cooking instructions and it says cook for 4 minutes, just press the start another 3 times while it is cooking
the new cook time will show on the display
Dec 30, 2016 | Microwave Ovens
Setting cooking time
It depends on the brand and model of your pressure cooker. If it's a stovetop pressure cooker, you start counting the cooking time once the cooker has reached pressure (check your manual for details).
If it is electric you should push either the +, or "cook time" button.
All of this information should be in your pressure cooker's manual. If you lost it, you can find an electronic copy of it here:
http://www.hippressurecooking.com/pressure-cooker-manual-library/
Nov 02, 2014 | Home
How do i clean the heating element n a sterling tech grill
According to the Owners Manual ........
Leave the Cooking Grids in place for 5-10 minutes while
the burners are on HIGH and the hood OPEN. The
Cooking Grids may also be removed and cleaned with a
brass or stainless steel bristle brush and soapy solution.
Standard oven cleaners may be used for further cleaning.
Rinse the Cooking Grids thoroughly with clean water
before using.
If you have misplaced your Owners Manual, here's a link that you can download and print for more information, now and in the future.
http://www.tecinfrared.com/manuals/Sterling%20Manual%20%28Discontinued%20Model%29.pdf
Mar 01, 2011 | Tec Sterling II Grill
How long is the baking time?
You can download a manual at the bottom of this age. That should tell you baking time depending on what you are cooking. Also there are sites with reciepes and they also indicate how much cooking time is needed.http://www.devicemanuals.com/guide/Waffle%20Maker/Oster/Oster-5838-Expressbake-Breadmaker-User-Manual-==TWpZMU56VTI=.html
Happy cooking!
Sep 01, 2010 | Oster 5838 ExpressBake Bread Maker
I have lost my manual for a Simpson Appolo Atlas Stove
call manufactuerer and ask if you can order one or try to do so online
Dec 22, 2009 | Stoves EC500DOA Electric Kitchen Range
Missing instruction manual for Charmglow Electric Turkey Fryer
Fry turkey 3 minutes per pound, then add 5 minutes to total cooking time
Nov 26, 2009 | Kitchen Appliances - Others
Timer instructions for a Rangemaster Toledo dual fuel 90 required
OK, here we go, this is actually a fairly lengthy explanation, but I will do what I can to explain.
The timer can be used to turn just one, or both ovens on and off automatically, however the start and stop time must be the same for both ovens, though different cooking temperatures can of course be set, so if you play around with temperatures to extend the cooking time of an item in one oven, you can often cook items needing very different settings for the fixed time you set in both ovens. Note that when the timer is on and the AUTO message is on the display, the ovens are disabled and will ONLY work during the timed period unless the timer is disabled again. (This is a common problem when you first power up, because the AUTO setting is automatically engaged on installation or power up after a power cut, disabling the ovens until you figure this out!). So, with all that garbage out of the way, how to use the timer settings:
For ease of understanding, I will refer to the buttons on the control pannel (Running from Left to Right as: BELL, HOT DISH, COLD DISH, HAND, + and -)
TO TIME SOMETHING THAT'S ALREADY COOKING (Minute Minder). Press and hold down the BELL symbol (Far left), use the + or - to adjust the amount of time you want to cook for (You can check time remaining at any point, or cancel the beeper when the time is up, by pressing the bell button.
TO STOP AUTOMATICALLY AFTER YOU HAVE MANUALLY STARTED COOKING. Press and hold the COLD DISH button at the same time use + and - to adjust your required stop time. AUTO will show on the display. When cooking is finished, the beeper sounds. TURN THE OVEN TEMPERATURE KNOB TO "0" FIRST, then press the HAND button, once to stop the beeper, and again to cancel auto and return to manual mode.
TO START AND STOP THE OVEN MANUALLY: Before you start, decide when you want the cooking to stop and how long you want the food to cook for (The cooker will work back from your stop time and figure out the START time for its self.). Press and hold down the HOT DISH button and at the same time set the minutes and hours you want the oven to cook for with the + and - buttons (You are NOT SETTING THE TIME HERE, you are setting how many minutes and hours to cook. Next, press and hold the COLD DISH button and use the + and - to set the stop time (YOU ARE SETTING A TIME IN THIS OPERATION). AUTO will show on the display. Set the temperature for the oven (or both ovens) that you want to auto cook with. When cooking stops the beeper sounds. Press the HAND button to cancel the beeper and press the HAND again to cancel AUTO and return to manual mode. (Note that the beeper stops after a while if you leave the oven attended, but the manual states you still have to press the HAND button twice to return to manual, I have not personally tested this).
GETTING BACK TO MANUAL MODE. If AUTO is showing on the display, because you have set automatic and no do not need it, or you have just powered the cooker up, any cooking time already set must be returned to 0:00 before you can return to manual, so hold down the HOT DISH button and ensure the display is set to 0:00, once you gave done this you can press the HAND button to return to manual mode
Dec 22, 2008 | Rangemaster Toledo 90 (Dual Fuel) Dual...
Instruction manual
Here is the link to the manual; http://www.esalton.com/static/manuals/GR26CB.pdf Hope this helps :)
Feb 06, 2007 | George Foreman GR26CB XL Indoor Grill
Barbeques Galore Bar-B-Chef Charcoal Smoker 263350 Logo
134 people viewed this question
Top Barbeques Galore Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Barbeques Galore Grilling Expert? Answer questions, earn points and help others
