Sound problem I have an ACER Veriton M464 with a Samsung SyncMaster 920LM Monitor. I have no sound at all coming from monitor, yet it works OK when I plug in speakers to PC. Just replaced monitor recently due to another problem and same thing....settings must be wrong somewhere.....
  • Anonymous May 25, 2009
    Thanks for your reply but I've already checked the monitor and volume is set at highest....
  • 79 Answers
On you screen there are button, which you can change settings on your screen itself , go to the volume control, and just set your volume on your screen higher, note: not on your pc, but on your screen itself.. enjoy the sound
Posted on May 25, 2009
New monitor no sound
not all monitors come with sound built in,so yes try adding speakers.
Feb 15, 2014 | Samsung SyncMaster S22B150N - LED monitor...
Samsung syncmaster 920lm wont stop going off and on
For this case, you need to open lcd case and try to find power inverter board. That cause by cold soldering joint and you need to check and resolder all them.
Thanks for visiting FixYa. We answer your question for FREE. Please feel free to click on "YES" button in return. Have a good time...!
Thanks
Jun 30, 2011 | Samsung SyncMaster 920LM 19" LCD Monitor
Connecting audio to monitor
If correct drivers are installed and sound works ok
Then a monitor should just plug in sound card and work right away, Also make sure volume is turned on, On the Monitor.
Jun 22, 2010 | Samsung SyncMaster 713BM 17" LCD Monitor
When i turn onmt Samsung SyncMaster 920LM 19 inch LCD Monitor it blinks on the left upper corner for a few moments
WQhen you get strange problem like this, first place to look will be the caps in the power supply section.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 14, 2010 | Samsung SyncMaster 920LM 19" LCD Monitor
Monitor Blank screen,
Open the monitor, examine the circuit boards. Look for small components that look like small cans, these are capacitors. If you see any that look bulged on top, then your problem can probably be solved by replacing these. Check out the following sites;
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Follow the directions and good luck!
May 02, 2010 | Samsung SyncMaster 910MP 19" LCD Monitor
DVI output problems with Acer Veriton M464
If you are comfortable with opening the case, you can try this: Unplug the power supply, make sure are constantly grounded (touching metal)remove add-in video card. Locate the "Clear CMOS" jumper (usually 3 pins in a row with two shorted via a plastic jumper). Remove the jumper and short the other 2 pins (if originally pins 1-2 with 3 open, short 2-3 with 1 open) for a few seconds. Then replace on original pins. Plug monitor into motherboard video port and power on. If it works, you can leave as is or try to re-install your video card following the same precautions when opening the case and probably changing BIOS settings to utilize the add-on card.
Sep 12, 2009 | Acer Computers & Internet
No sound on my Samsung Syncmaster 920lm Monitor
This seems to be easy.
1) Your monitor will need to be connected to the sound output using a separate cable, unless it uses HDMI cabling.
2) If that doesn't help, check the sound output using headphones or a different speaker system.
Check it out and post your response here.
Oct 09, 2008 | Computers & Internet
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
