Question about Samsung SCX 4521F All-In-One Laser Printer
Printer/Paper Jam Brother MFC
I cleared a paper jam.  It came out in two pieces.
When I went to print again I received the paper jam tone and LED read "Paper Jam Open back cover"  I checked for more paper. Nothing, clean as a whistle. Tried to print again, no luck.
I've had several people check, no paper jam.
I put the screws to the machine, everything clear.
Every time I try to print, same thing happens, plus it makes a weird sound like the mechanism is trying to do something.
Oh and the on/off switch doesn't work.  I have to unplug/plug it to get it to reset.
Also, this happened around the same time I intalled a Cyan cartridge.
Printer is less than a year old, bought new.
Can anyone help me?
  • 13 more comments
  • Carmen Kearney
    Carmen Kearney Nov 04, 2007
    Response to wbmassel inquiry.
    It's an MFC 240C.
    Fourteen days later and I'm still getting the "Paper jam open back cover then remove paper. " message.
    I still am unable to print. When I try it just makes a lot of noise and I get the paper jam message again.
  • ladbala Nov 05, 2007
    we have the Brother mc 9600, had a printer jam in the drum, cleared it, still states, printer jam/ offline, makes the loud noise. I need a soluion.
    Stephanie
  • Stephen Lubberts Dec 13, 2007
    Word for word, I have the same problem, except I just got my printer new last week. This happened after I loaded a piece of paper that had already been printed on. Didn't know it was so finicky!
    Anyway, I've contacted Brother's online support and am currently awaiting their answer.
    Their online solution manual ishttp://welcome.solutions.brother.com, which has some nice diagrams. On the Paper Jam page, highlighted in green is a suggestion to "move the print head to take out the paper" which I have no idea how to do.
    Hopefully after a good night's rest the printer will feel better and I'll plug it in again to see if it's better.
    PS. It makes flawless photos when it's working!
  • Anonymous Dec 14, 2007
    There was a paper jam. I opened the back and took out the paper. the message reads print unable 51. I will lilke whaat next to do.. I unplugged more than once still no result. Please help
  • shashia Feb 10, 2008
    paper jam cleared but still get the same message. paper jam open back cover and clear.
    i have checked it many times and switched it off and on and still get the same message. when i switch it on, it makes a loud noise and then the bleep and same message again. please help. i have no manual.
    thanks
  • photoshock Mar 22, 2008
    I had printed on on woven photo paper last week. but today, i when i try to print on gloss or even on satin photo paper it doesn't work even on 4x6" or A4. The printer said paper jam, open back cover, remove paper. but there's no paper jam. when i try to use the ordinary paper and follow some tips from other people with the same prob., it works on ordinary paper but i can't still print on my photo paper.
  • Anonymous Jul 09, 2008
    Same problem. It's been weeks since I have been able to print. THERE IS NO PAPER JAM
  • Sc_niko_33 Jul 28, 2008
    unable to print 30
  • riyaqar Jul 29, 2008
    The same exact problem
  • Anonymous Aug 08, 2008
    my paper jamms somehow to the right...??? why
  • ferral Aug 12, 2008
    Hi I have an Epson Stylus Inkjet printer too. I don't know how to open it up to have a look at it but whenever I try to print from it it just says there is a paper jam even though there isn't. I've changed the cartridges and everything but no results
  • 1966diane Jan 30, 2009
    ive got a brother dcp-135c printer it saying paper jam and theres no paper in it its clear and its making noises wont let me print or anything can anyone help me please
    i have same problem says paper jamed and no paper in it and making noises wont let me print can you help me please
  • shal gal Apr 01, 2009
    Yep same problem on my DCP - 130 ... paper jam remove back cover ...its only a couple years old. BROTHER SHOULD FIX IT FOR US>>> its not our fault clearly!
  • lilliankrn May 14, 2009
    printer states remove paper jam and there is no paper jam!
  • 2,071 Answers
Printer/Paper Jam  Brother  MFC - 41093dd.jpgWell I fixed it!!! Here's what I did. You see this picture of the cover opened? Where the arrow's pointing is the home position of the printer head. Under there I found a scrap piece of paper! Here's exactly what I did. When I got home I decided to plug it in to see if it would work, but it made the same noise and showed the same error message as before. I opened the cover as shown above. This resets it, and it says "close cover". I closed it, and AS it started to go through its routine I OPENED IT again, and I could see the printer head moving back and forth. At this point I used a flashlight to see where the home position of the Head was, and that's where I found the scrap of paper!
I unplugged it for safety and was able to remove the scrap with my fingers.
By your descriptions, referring to the other users, you just might have the same problem.
Posted on Aug 25, 2008
  • 1 more comment
  • step Dec 14, 2011
    dude, if you're going to COPY someone else's solution, at least CREDIT the other person that you are copying and don't pretend that it's your own.
  • nettie_hendr
    nettie_hendr Aug 29, 2012
    Thanks! I tried this and it worked!
  • rck2763 Dec 17, 2013
    Thank You, Thank You, Thank You,
I opened the cover of my MFC-465CN and held the cover interlack switch closed. The print head moved and a saw a small scrap of paper under it which I removed with a hemostate.
Posted on Mar 28, 2008
  • ArtModern Jan 16, 2011
    Fantastic suggestion that worked! I first found a scrap of paper that had bundled up, sticky ink or toner and all. Thought that did the trick but I kept getting the paper jam message. Couldn't find more paper, even with a strong light. Then took your suggestion, not realizing that the printer head was the black box-like object stuck on the left, same side as the left, not the right. Guess it was stuck there due to the malfunction. Sure enough, I opened the top, both together, as you suggested and with the printer head almost in the middle was able to clearly see the bunched up piece of paper causing the jam. Removed
Clean the encoder strip! it works!! BYAAAAA!
Posted on Dec 01, 2009
Have you had any luck with your printer yet same thing as happened to mine if you have sorted it can you let me know please what you did to it thankyou yours 1966diane@live.co.uk
Posted on Jan 30, 2009
    ive got a brother dcp-135c printer says paper jam and theres no paper in it its making noises and wont let me print or anything can any one help me please
  • 1,218 Answers
One of the main causes for paper jams is the presence of dirt, dust, or debris in your toner cartridge. The paper coming into the cartridge would get stuck. So clean your printer regularly. Remove the dust from the printer. Also find out whether any jams occurred in the sensor hole in the upper part of the rotating drum. Do not touch the roller while cleaning. If the oil in your body gets into the roller, the printing media cannot roll over it properly and you can't get rid of the printer problem.
Posted on Dec 03, 2010
    New Friend:
Similar problem, similar fix. I followed Loreto's basic procedure, except that I simply held the engage button down with a q-tip. I noticed that the print head was seating at the left side, not the right. There was a wad of paper blocking it from going far enough left to start its return. Tweezered it out, and voila! Thanks a bunch.
Posted on Sep 22, 2014
Just figured this out on an MFC 885CW. Everytime the paper fed, I got that paper jam message. After trying the above sage advice to no avail, I looked the paper I had pulled out the back. The leading edge had a bend in the middle. I removed the back cover, and discovered a series of what can only be described as plastic springs. In reality they are plastic rectangles that are adhered to the cover, which seem to guide the paper from the tray into the rollers. One of these had a bend in it, enough it seems to stop the paper from feeding. Hence the jam. I straightened it out, and it works fine.
Posted on Jul 31, 2012
In my DCP 110 C the print head got dislodged from the rail (It was stuck above the rail, you can tell if you look at it closely), to put it back I had to slide it all the way away from the home position and push it down a little and then carefully pull it back so that it stays on the rail.
Posted on Jul 06, 2008
Open back cover then remove paper jam Brother DCP115C
Posted on Mar 11, 2008
  • 26 Answers
What model is it? and is all the ink genuine?
Posted on Nov 03, 2007
Paper jam on screen will not reset
To clear the error message Paper Jam after you removed the jammed paper, open and close the scanner cover.
If you still receive the error message, a small piece of paper may be stuck inside your Brother machine.
Refer the below link for the steps to remove any ripped paper remaining inside your Brother machine:
still receive the error message Paper Jam after removed the jammed paper...
Apr 22, 2014 | Brother International Brother MFC-J4510DW
Brother mfc 8670 paper jam duplex
remove the small, or scratch into pieces inside the duplex to clear the paper jam.
Feb 10, 2014 | Brother MFC-8670DN - 30 PPM Multifunction...
Paper jam when there is no paper jam?
Hi
According to your problem, May there is no paper jam but memory is not cleared. First make sure that there is no paper jam. Delete all pending print job from the print queue. Turn the printer and your system both for 2-3 mins and turn the both again. It will clear the memory.
May 10, 2011 | Brother MFC 420CN All-In-One InkJet...
My brother mfc 240 c is keep saying paper jam but we have move the cover and we do not see a paper jam how do we resolve this issue please help
If there is no direct symptom of paper jam and still you cannot do printing properly, find whether it is because of drum problem. If the paper gets into the end gear of the rotating drum and gets stuck there, you cannot access the printing function. Switch off your printer and check the plastic arms of the printer drum. If there is any paper piece jammed in any of the arms, you can't continue printing. Here also cleaning is the best method to solve the problem. While cleaning, check the arms of the rotating drum. get more information to fix brother mfc printer paper jam problem .
Jan 24, 2011 | Brother Multi-Function Center MFC-240C...
I have a brother MFC 8440
Have you checked the back paper door?, the paper tray?, and the drum/toner unit? If a paper was torn out of the machine, you may not be able to see the piece that is still triggering the jam signal. You can also pull down the paper guide around the orange fuser roller through the back door by pulling it gently to the left.
Sep 11, 2008 | Brother MFC-8440 All-In-One Laser Printer
Printer says paper jam, but there is no paper in the printer. (mfc 210c)
If the paper tore when removing it, chances are there could be a small piece of paper still causing the paper jam. Sometimes all you need to do is turn the fax off for a few minutes and then turn it on again and the paper jam message is gone
May 10, 2008 | Brother MFC 210C All-In-One InkJet Printer
Paper jam in brother MFC 240C
Usually small pieces of paper are jammed at the print head area. Lift up the scanner and see if you can find the paper at the print head parking area, clear the paper . If you can't find the paper, remove the scanner cables, then the scanner. You will see 2 screws at the rear and one near the USB connection. Another 3 screws towards the front will remove the front panel. Under the panel remove 4 screws and the two panel harnesses. The is a speaker harness which you must remember to attach back later (most people don't remember to put back). Lift up the top cover and you can see the whole engine. Clear any pieces of paper that might be there.
Apr 20, 2008 | Brother MFC-7220 All-In-One Laser Printer
Brothe MFC-240C paper jam error msg won't clear
**, it is not fixed. I followed instructions on Brother web site and was able to find a piece of paper near the printhead, so I removed it. The printer makes a grinding sound when it tries to print and the same paper jam error returns and can't be cleared. I beleive that the printer repair cost will be more expensive than replacing it with a different printer, and it won't be Brother brand. I probably would not be able or have the tools to do any complicated repair job.
Mar 08, 2008 | Computers & Internet
Paper LED Blinking
Did you see http://www.fixya.com/support/r310860-lights_indicate
The Paper LED is flashing.
papereroor2.gif Meaning of LED Indication
Front cover is open:
Close the front cover of the printer.
Back cover is open:
Close the back cover of the printer.
Paper jam:
Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the Go button.
No paper fed manual feed slot:
Put the paper back in the manual feed slot.
Memory full:
The printer memory is full and the printer cannot print full pages of a document. To solve this problem, click here.
Print overrun:
A print overrun occurred and the printer cannot print full pages of a document. To solve this problem, click here.
Clean drum unit:
The corona wire needs to be cleaned. To see how to clean the corona wire, click here.
Jan 04, 2008 | Brother HL-2040 Laser Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
14,377 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
