Question about Lanier Office Equipment & Supplies
How to replace drum unit
How do you replace the photo conductor unit in the Lanier 5613F
Open right cover, and front cover. Remove toner bottle assembly (not just bottle), unplug drum (photoconductor) connector. Press the gray/silver release tab and slide out drum. Install and plug in new unit, replace toner assembly, close covers, and the new unit is automatically detected and calibration will begin.
Posted on May 26, 2009
What is a photo conductor
The photo conductor is the round drum unit that is light sensitive. The laser in the printer writes an image of what you want to print on the drum and then the toner is applied to the drum and transferred to the paper.
Aug 30, 2015 | Ricoh Aficio 1515MF All-In-One Laser...
How to clean Ricoh Aficio MP 2000
sounds like either drum blade has fail or drum is bad. try printing the counter report and see if it is doing this. Then photo conductor unit needs to be rebuilt or replace. open right side door and look at drum make sure you don't touch it and see if toner is on it. If so drum blade has fail. call a tech or buy new photo conductor unit. this are good for approx 60,000 copies but sometimes will go longer age also play with drum blade life. were you might have 20,000 copies but unit is 5 years old
Jan 31, 2012 | Ricoh Aficio MP 2000 Black and White...
Lanier 5622 says following output tray is full please remove paper. However it can be empty, half full, or completely full of paper and this error will not go away. Just replaced the photo conductor...
Hello!
Why did you change the fotoconductor Unit???? This part of the machine is to create the image.
Your problem is in the tray. Meaby a broken switch. Take out the all tray and look inside to see if there is same obstruction.
If you do not see anything i advise you to call a Tech.
Dont waste more money if you dont know what your doing. This is the best advise i can give you.
See you!
Aug 31, 2011 | Lanier 1205 Copier
I have a Lanier LP226cn printer. Under the alert status it is telling me to ''Prepare a New PCU'' and ''Replace CPU Black Soon'' I understand it means to replace my Black Toner soon as someone mentioned...
Sorry, You do not need Black toner, you need a Black PCU (Photo Conductor Unit).
I have this same printer with the same warning.
Unfortunately, This unit seems to be rather expensive.
Good Luck
Mar 01, 2010 | Lanier Office Equipment & Supplies
After a few copies are made, black streaks start showing up on the copies and gets worse with each successive copy
for most copier those black streaks are caused by poor cleaning of the Photo Conductor Drum these can be fix by replacing the cleaning blade. after replacing them clean the Photo Conductor Unit and make some test copies.
Feb 27, 2010 | Office Equipment & Supplies
Where can I find parts for my Lanier 5613F paper tray?
Hello sir; Please contact with me by email, I can get it for you.
Jul 18, 2009 | Lanier 1205 Copier
Pc drum
Replacement of the Photo Conductor Unit
1. Select Tech. Rep. Mode → [Counter] → [Special Parts Counter] → [PC Life].
2. Press the Clear key to clear the counter value.
3. Turn OFF the main power switch.
NOTE
• Clear the PC Life counter before removing the IU.
• After clearing the PC Life counter, be sure to turn OFF the main power switch.
4. Open the Right Door.
5. Remove the IU. Carefully pull on the two green handles
6. Remove four screws (silver) on the sides and disassemble the Photo Conductor from the Developing Unit.
7. Replace the Photo Conductor Unit
8. To reinstall, reverse the order of
removal.
NOTE
• Replace the Toner Filter (Developing
Unit) with a new one at the same
time.
Jun 06, 2008 | Office Equipment & Supplies
Lanier Printer
You need to change the 'Photo Conductor Unit'. Some of these units are rated at 200-250 hours of use and need to be changed. Shop around and try to find a good deal, these units are not cheap.
You didn't state what type or model you have, but you can download the support user manual from lenier website.
http://www.lanier.com/downloads/Default.aspx?hbn=manuals
May 23, 2008 | Office Equipment & Supplies
Printing problem with lanier 6720 printer
Check your photo conductor (drum) unit. This is often caused by an old or light damaged unit.
Sep 15, 2007 | Lanier 5235 Printer
Color Photo Conductor Unit
the vertical line that you saw is an indication of either it is normally worn out, or something has caused the scratched, by any material ( PC drum is very sensitive to any material and can easily damaged or scratched any solid and unwanted dirt inside) see you actual meter reading. if it falls on the first thousand copies or print then it might have caused by a scratched, if it falls beyond the PM parts repalcement then there is nothing you can do but to replace this.
sometimes you can swap the colors, by the affected color use the yellow drum unit to the affected drum, the vertical would not that be obvious.
Sep 12, 2007 | Ricoh CL3000E Laser Printer
545 people viewed this question
Top Lanier Office Equipment & Supplies Experts
George Mclaughlin
Anthony Karuku
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
