Question about Ricoh Cameras
How to advance the film in a Ricoh Shotmaster 110-ZP
  • masterazmaso May 25, 2009
    There is no lever to advance the film and polarity is correct....Rob
  • 495 Answers
Hi, check the camera set in auto /manually in auto function, check battery might drain the current , dis engage camera to lense to release the mirror by pressing button beside lense , turn lense in left or right .
Posted on May 25, 2009
  • Manoj Rout
    Manoj Rout May 25, 2009
    Check the polarities of the battery also
    Brigadier General:
  • 3,917 Answers
Please check the polarities of the battery. Also check for the lever which is responsible for advancing the film. Does it sound like mal functioning.
Thank You
My advance lever is stuck o my Ricoh camera. I had a roll of film get stripped in it and took it out in the dark room and developed it but now even with no film in it the lever won't advance. I've looked...
Your camera is in cocked position with shutter fully cocked and that is why you cannot advance the film advance lever. Set the shutter to x position ( on your shutter speed dial on the right hand side and top of your camera ) . The shutter should release and then you should be able to advance the film advance lever.
Oct 18, 2013 | Ricoh KR-30SP 35mm SLR Camera
My Ricoh kr-5sv's rewind button is still pressed in after i rewound andd took out the film. how do i get it to pop out again?
The rewind button will usually pop out once you turn your film advance lever. In order for you to be completely familiar with your camera, here's a link to a user's guide in pdf format:
http://www.butkus.org/chinon/ricoh/ricoh_kr-5sv/ricoh_kr-5sv.htm
Hope this helps.
Mar 25, 2011 | Ricoh KR-5SV 35mm SLR Camera
Film advance lever will not advance
Sometimes film jamming in the film can cause the shutter to be very difficult to **** . I had an Pentax years ago that was similar in design to the Ricoh and loved it.
Using a little, but NOT a lot more force may help you to complete the cocking action. Other than that I would remove the film and blow out the mechanism with compressed air. Don't know if this will definitely solve the issue. But hopefully it will.
Best Regards, Mark
Jan 23, 2011 | Ricoh KR-30SP 35mm SLR Camera
My cameras advance lever will not spring back and allow the film to move to the next frame. How do i fix it?
push the film release on the bottom of the camera and try to continue forward then. If you are trying to get 27 pictures on a 24 exp. roll you may have advanced your film so far that it is stuck on the piece of tape that attaches the film to the spool. Take only 24 pictures.
May 20, 2010 | Ricoh KR-5 SUPER II 35mm SLR Camera
Blank film
Make sure when you load your film, that the cogs are actually winding the film. Many a roll has been "shot" with the film ever advancing. If you see what your taking, that is really about all that it could be.
Jun 28, 2009 | Ricoh XR-10M 35mm SLR Camera
Mirror is stuck in "up" position and film will not advance
Normally, stuck mirror is due to weak batteries with a elcetromagnetic shutter like the Ricoh. Try with brand new silver oxides and see if it helps!
Feb 21, 2009 | Ricoh XR-10M 35mm SLR Camera
Film advance lever stuck
The shutter parts are most likely broken. That is usually the tell-tale sign of a broken camera, not advancing. Repairs for film cameras are very expensive and if parts are needed, it may be impossible for a 20+ year old camera. My suggestion is to find a replacement film camera system. Your Ricoh lenses will fit on a Pentax camera, but not work in Auto Mode. Prices of used Pentax cameras with built in motor drives are around $100. Check on line cameras stores. They have lots of use cameras/lense. A lens to use on that is another $75 or so. Only Nikon and Canon make new film cameras anymore. If you want an indestructable K-mount, find a Pentax K1000. Many lenses are available but no motor drive nor auto exposure on that model.
Apr 09, 2008 | Ricoh KR-30SP 35mm SLR Camera
35mm Film Camera Ricoh XR-2
You can replace it with the available lever.Most of the cameras lever can suit
Feb 23, 2008 | Photography
Cameras Logo
237 people viewed this question
Top Ricoh Cameras Experts
teddyboy
Are you a Ricoh Camera Expert? Answer questions, earn points and help others
