Question about Nokia N70 Cellular Phone
No reception or calls allowed,all else working.
All my functions work on my phone except incoming and out going calls,no texting either.a x appears where my reception should
    Problem Solver:
  • 14 Answers
Probably, the phone's radio might be off? depending on your phone, it would be in options and maybe in the network tab... which you would have to enable to ON. Alternatively, If not, it might be in OFF mode in the profiles, you know like vibrate, loud, quiet, etc...change your profile to maybe quiet or loud if not already that. Thirdly, it might be set to flight mode too, where it turns your cellphone's radio off but leaves all other functions working, so as not to interfere with the plane's radar and other radio frequencies? if there's an X where the reception should be, definetely means your phone is not recieving or transmitting data, and should be easily fixable without having to call a support center unless you've done those three steps with no improvements.
Posted on May 25, 2009
How can I change the direction of incoming calls to various extensions?
Just a guess but maybe changing the connections for the lines on the switchboard. This may also change their numbers though.
Apr 10, 2015 | Panasonic KX-DT333-B Digital Phone
My Motorola Photon Q will not receive or send texts or calls, what can I do?
I would check with sprint to see if your account is up to date. Otherwise, I would suggest going to your settings and see if you can update your phones's prl and profile. go to settings, tap "About phone", Tap "System updates", then tap each option. Good Luck!
Dec 05, 2012 | Motorola Mobility Sprint Photon Q 4g Lte...
My service has worked fine for months and i had been using the 50 dollar a month unlimited prepaid plan. 2 weeks ago i changed my plan to the prepaid 30 a month 1500min/text plan instead to save a bit of...
Did you change phones? Sim cards? I am assuming you have the same phone, and they switched out the sim card (or maybe not?) when you changed plans.
Also, all 4G phones are also 3G and 2G phones, and they simply pick the best available. So if you lose 4G coverage, it will simply switch to the wider 3g network and when you're really remote, drop to 2G. This effects data speed primarily, there isn't any qualitative difference between them for voice and text.
It sounds like you might have something screwy with your sim card when the plan changed happened, I would call T-Mobile or visit a store and ask for a new sim card and be vocal about the poor reception after the plan change. Changing plans shouldn't normally effect reception, only changing phones/networks.
I myself experienced reception issues like yours, and the problem was a bad simcard. I'm sorry for the vague answers, but I think your best bet is to go to a T-Mobile store. They should replace the sim card free of charge.
Oct 20, 2012 | Nokia 1616 Blue T-mobile Cell Phone -...
SEND TEXTS DIAL OUT OK INCOMING CALLS GO STRAIGHT TO CALL BOX NO INCOMING TEXTS WHEN I CALL OUT PHONE WORKS OK THEN STOPS GOING BACK TO FAULT ABOVE
You need to contact your service provider and have your Voicemail reset. The carrier can reset everything. This includes fixing your incoming text problem.
Aug 06, 2011 | RIM BlackBerry Curve 8520 Smartphone
Call barring
Use the network services menu for this...
Use this menu to access network services. Please
contact your service provider to check their availability and subscribe to them, if you wish.
This network service allows you to restrict your calls.
1. Select a call barring option:
All outgoing: prohibit outgoing calls.
International: prohibit international calls.
International except home: only allow calls
to numbers within the current country when
you are abroad, and to your home country.
All incoming: prohibit incoming calls.
Incoming while abroad: prohibit incoming
calls when you use your phone outside of your
home country.
Cancel all: cancel all call barring settings,
allowing to be sent and received normally.
Change barring password: change the call
barring password obtained from your service
provider.
2. Select the type of calls to be barred.
home country.
provider.
if you have any queries about your mobile..you can have a look at this user manual which can be downloaded from
http://safemanuals.com/user-guide-instructions-owner-manual/SAMSUNG/SGH-D600-_E
hope this helps :)
Dec 16, 2008 | Samsung SGH-D600 Cellular Phone
Caller id
First you need to verify if the caller id does that to all incoming calls, showing numbers only, or if it only does that to only numbers stored in directory. If it does that to all incoming calls then you need to check manual to see if there a setting to allow both name and number of all incoming calls. Either way you need to make sure caller id functions allows both name /number on display.
Oct 13, 2008 | Panasonic KX-TG5672 Twin Cordless Phone
Samsung E870 has no reception!
Check your network setting usually quadband phone has a network setting for GSM 850/1900 and GSM 900/1800.
Feb 09, 2008 | Samsung SGH-E870 Cellular Phone
Sharp UXB700 Fax
Below is for when you are using machine in fax mode, is that how you use it or are you also using the answering machine function? ie TAD mode
If desired, you can change the number of rings on which the fax machine
answers incoming calls in FAX mode. Any number from 2 to 5 can be
selected.
1 Press FUNCTION once and 3 times.
Display:
OPTION SETTING
To select FAX mode, press
(with no document
in the feeder) until the arrow in
the display points to FAX.
RESOLUTION/
RECEPTION MODE
RESOLUTION/
RECEPTION MODE
FAX
A.M.
TEL
Using TEL Mode
58
2 Press once and once.
3 Press once.
4 Enter the desired number of rings (any
number from 2 to 5).
Example: 3 rings
5 Press to return to the date and time display.
Note: If you are using Distinctive Ring, the fax machine will answer calls after
two rings regardless of the above setting.
Oct 16, 2007 | Office Equipment & Supplies
Nokia N70 Cellular Phone Logo
102 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
