Question about Insignia IS-LCDTV32 32 in. Television
Lines with occassional picture
When we turn on the Insignia TV we get about 3 sets of horizontal lines, occassionally they are vertical lines and sometimes we get the picture for a short while.
    President:
  • 814 Answers
This is a problem with the main board. This board does the signal processing and sound audio processing. The problem may just be some over expanded solder connections that have lost the ability to stay in contact with the board. It could also be a problem with some component failure. If this unit is still under warranty call the Insignia customer support at this telephone number 1-877-467-4289. Give them the model number of you television and they will tell you how to get service for it. The Insignia customer support website is www.insignia-products.com. Go to the customer support and ask them for help with your model of television.I hope this information helps you with your problem.
Posted on May 25, 2009
I have an Olevia 242TFHD LCD tv, and there is a faint black line running vertically from top to bottom on the right hand side. There are also occassional red and blue lines running horizontally. The tv is...
You may have failing T-CON board. you will get more lines as time goes by. Try cooling it with freeze spray for electronics troubleshooting.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jul 02, 2010 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
Vertical lines on a Philips plasma tv
It is most likely an internal fault with the screen & the only remedy is to have the screen replaced unfortunately. Occassionally it can be caused by one of the buffer boards flexible cables connecting to the screen needing to be re-located but this very rarely fixes this fault.
Oct 04, 2009 | Philips Televison & Video
TV doesn't turn on. Insignia 32LCD
check the power supply boards apply fresh solder also apply fresh solder to inverter board. scan budged capacitors from secondary power supply.
Jun 04, 2009 | Insignia IS-LCDTV32 32 in. Television
Insignia 32" Tube TV NS-RTV32
The vertical output IC LA7847 is failing. It will likely fail permanately and you will have just the horizontal line. The set will require service. Just do not run the set very long in this state. That thin white line can likely burn into the crt phospher and will show all the time thus ruining the glass picture tube...
Jun 05, 2008 | Televison & Video
Problem with my insignia tube tv!!!!
if that look like horizontal line shuld be vertical problem. check vertical ic around it of resistor& capacitor. good luck!
May 26, 2008 | Insignia NS- 27" TV27 TV
Horizontal lines
i suggest you change video board .
Apr 19, 2008 | Samsung SyncMaster 152N 15" LCD Monitor
Insignia LCD 27" w/vertical lines for picture
Happens with mine also usually happens when you change channels alot all you need to do is shut tv off and turn it back on.
Mar 09, 2008 | Insignia LCDTV26 26 in. Television
To fix or not?? 1990 Hitachi big screen
Sorry the answer is no. If the rolling pic was the only problem you had then yes throw a new signal board in and move on. In this case your picture not being as sharp as it used to be will also be tubes going bad..18 years not a bad run on three tubes that run extremely warm. Have fun on your upgrade to lcd or dlp proojection this will cost less than the fix of your tv.
Josh
Feb 28, 2008 | Televison & Video
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Insignia IS-LCDTV32 32 in. Television Logo
185 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
