Question about GE (PSS26MSRSS) Side by Side Refrigerator
Freezer side not freezing
Freezer not freezing.
  • sh_para May 26, 2009
    Thanks, for your quick response.
    The compressor fan motor is running and the freezer fan motor is running.
    Yes, there is ice buildup on the rear freezer wall.
    How to change defrost heater and defrost thermostat?
  • steve
    steve May 11, 2010
    Look for ice buildup on the rear freezer wall.
    If ice is there, replace the defrost heater and defrost thermostat.
    Is the compressor fan mptor running?
    Is the freezer fan motor running?
  • GE Master
  • 3,361 Answers
Turn off the refrigerator.Remove the freezer shelves/bins and rear panel.
Take a hair dyer and thaw the ice completely. The defrost heater will be across the bottom of the freezer coil. The defrost thermostat will be attached to a refrigerant coil at the top of the freezer coil.It is about the size of a quarter and 1/2 inch thick.There will be wires from top to bottom on the sides of the coil.
Posted on May 26, 2009
Freezer freezing and refrigerator freezing
Search round the top/bottom/sides of fridge and freezer for a regulator switch. Usually a small serrated wheel numbered 1-5. It should be set at 2 or 3. Any more and you will freeze up.
Jul 12, 2012 | GALAXY Microsystems 25.4 cu. ft....
Side by side Admiral freezer freezes but fridge
check the damper vent door between the refrige and freezer and make sure its opening up to let cold air from freezer into the refrige,sometimes they freeze up and cant open and close when called upon to do so,if so deice it with a hair dryer,the side being hot is good telling you the compressor is operating correctly
Jul 28, 2010 | Admiral 26 cu. ft. Side-By-Side...
The freezer side not freezing just cool, the
Open freezer door, pull food off shelves on lower half of inside freezer and look if you have frost building up on the back wall of freezer. If you do then you have a defrost heater or thermostat possible gone bad.
Advise if you have frost build up and I will advise on how to check it.
Oct 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE side by side. The freezer will freeze up with
Replace the defrost heater, located at the bottom of the cooling coils, behind the back wall of the freezer.
Aug 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer stopped freezing
It is possible that the fanmotor in the freezer compartment is faulty which would cause a freeze up and prevent the air from circulating.
Mar 05, 2009 | Kenmore 44103 Side by Side Refrigerator
Freezer compartment of refrigerator not freezing
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
So, how can the Ref side be cold and the freezer side not freezing?
1. Coolant leak. There is enough coolant to keep the Ref side cool but not enough to freeze on the freezer side.
2. Defrost system failure. The coils on the freezer side are clogged with ice and it's just a matter of time when the Ref side won't cool either. The back wall in the freezer will be covered with ice/frost
Jan 09, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
259 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
