Question about Smeg 28 in. P752 Electric Cooktop
Dual ring shows letter E
Smeg Hob. Dual ring shows letter E. I have turned off at mains and it still appears wehn switched on again.
Not aware of having done something wrong. .
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
My 5 ring induction hob works fine but has stopped showing H or h. Is it possible to turn this feature off accidentally or is it a fault?
do not think there is any OFF switch for the HOT indicator .if it all works why even worry about it .
Aug 08, 2015 | Neff Cooktops
Turn hob on and only get letter L on each hob and will not turn on
child lock is activated , switch on hob press - and + button simultaneously hob will return to normal. if zeros dont appear try pressing and hold - key slightly before pressing +key hold both for a few secs.
Jun 23, 2010 | AEG 23 in. 6410KF-N Electric Cooktop
Hob problems
Take a closer look at the wiring diagram on the base or in the book.Check you have put in the relevant links.If not wired properly you may only get half the hob working.
Hope this helps.
May 19, 2010 | Smeg 28 in. P752 Electric Cooktop
I have a neff T1.D20 dual circuit hotplate but although the inner lights up and gets hot the outer part doesnt. Is the outer part supposed to?
I have a T172 model which also has a dual circuit hotplate.
In the control area you should find a dual circuit control pad - this has two concentric circles on it. With the hob switched on, pressing this button will chnage the mode of the dual circuit hot plate bewteen:
1. Just the inner part
2. Both the inner and outer together.
When the hob is switched off using the Standby control pad, it remembers which mode was selected and will therefore work the same next time it is switched on. However, it is worth noteing that when the mains power to the hob is interuppted, either by an isolator switch/breaker, or a power cut, the hob defaults back to just the inner ring mode.
Oct 03, 2009 | Neff T1323 Electric Cooktop
Smeg gas hob ignition
There is a problem with the board. It has malfunctioned onto an ignition mode. By switching it off, it shows the capacitor is holding chage untill flat.(Hence the continual sparking) Replace it.
Sep 20, 2009 | Cooktops
Smeg SA435 - spark and loud sound
hi gud day,much better call an electrician to check ur main power & the outlet of ur unit.if ok i think the problem is inside the unit,open wire or have a ground inside coz of over using the item that may coz of the wire is melting.tnx
Feb 04, 2009 | Smeg 23 in. SA435X Electric Cooktop
Aeg hob
It is child lock.
Turn cooker on, press two + at front of oven, this will then take it off for that cooking session.
To turn child lock off switch on hob, and touch - for 5 seconds.
Sep 29, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Hob not working
It is child lock.
Sep 16, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Apr 04, 2007 | Smeg 23 in. SE64 Gas Cooktop
Smeg 28 in. P752 Electric Cooktop Logo
133 people viewed this question
Top Smeg Cooktops Experts
Timllfixit
ray gallant
On-Time Appliance
On-Time Appliance
Are you a Smeg Cooktop Expert? Answer questions, earn points and help others
