Question about Logitech Cordless Mouse
CURSOR JUMPING ALL OVER
I CONNECTED BOTH PORTS ON THE BASE STATION TO MY NEW DELL INSPIRON 350 USING A CONVERTOR CABLE AND THE CURSOR IS JUMPING ALL OVER THE PLACE....SHOULD I CONNECT ONLY THE USB PORT TO THE COMPUTER
  • 31 Answers
I think the best solution would be to get a new mouse and see if that has the same issues if it does not, it is your mouse. If it is it could be a number of things... faulty mouse software (easily fixable),driver problems, or it may even require you reformat your entire computer, depending on where the source of the problem is. Try a new mouse first and keep me posted...gl
Posted on May 25, 2009
    Scholar:
  • 89 Answers
Hi
yes only connect the USB port to the computer, this should stop Windows from seeing both a USB mouse and a PS/2 mouse.
Also make sure that you are not using it on Glass or another surface that could cause the mouse to jump.
Put a blank white piece of paper under it and try it
Let me know if it works for you!
Dell Inspiron 1110 connecting HDMI to TV
make sure you RGB cables connected in the right order in the ports on the convertor and TV
Oct 01, 2017 | Dell Computers & Internet
Jumping cursor of a
Hi! I think youre probably having a jumping cursor where the cursor jumps from one place to another while typing an email or something. You may got to control panel - hardware - mouse then look for the check box that you can tick on that says "Tap off while typing" and this should fix the problem. Thanks for visiting FixYa.com!
Jun 04, 2010 | Dell Inspiron 1525 Notebook
I have a inspiron 1721 and the cursor jumps all over the place
If the cursor is jumping while typing, then go to the touch pad settings and enable palmcheck or it's equivalent to disable the touchpad while typing
Apr 26, 2010 | Dell Computers & Internet
I want to add a second hard drive (SATA) to a Dell insperon 530. Where does it connect to the motherboard?
Every SATA enabled motherboard has atleast 2 SATA ports. Trace the first SATA cable and you'll find another port closer. If your Optical drive is connected to it, and if you can find an IDE port on your motherboard, buy an IDE to SATA convertor and plug it in.
Apr 10, 2010 | Dell Inspiron 530 Desktop Computer
While typing on my laptop, my cursor jumps to other places on the page, then types where the cursor has moved to . I don't use a mouse.
I guess the 'other places of the pages' is mostly the beginning of the line? It usually happens when the key stroke is not proper while using combination keys. Or also it happens when if you dont release a key when you press the next in between your speedy typings.
Mar 28, 2010 | Dell Inspiron 1525 Notebook
How can I watch a DVD on my TV from my Inspiron
if u have a TV out signal port on ur laptop, u will need a DIN adaptor to connect from laptop to ur TV
else u need a convertor box that will convert ur connect to ur VGA out port on ur laptop and will send the signal to TV via the box to the audio/video in slot in the TV...u will also need some special cables...thsi will come along with the convertor box....look in google or ebay
Feb 04, 2010 | Dell Inspiron 6400 Notebook
How can I stop cursor from moving to new location on its own in XP how can I remove and reload the touch pad driver on a Dell Inspiron 1525 running xp Pro sp3? I also have the original Vista still...
Oh man!...
First, the mouse:
[Control Panel]
[Mouse]
[Pointer Options] tab
uncheck "Automatically move pointer to the default button..."
TouchPad:
Right-click [My Computer]
[Manage]
[Device Manager]
open the +Mice and other pointing devices
Right-click on your touchpad entry (if you can't tell which one, pick one - no harm will come)
You can update driver...
or you can uninstall it and WINDOWS WILL RE_INSTALL IT>
Let us know the outcome ... and how many seconds it took to fix...
Sep 22, 2009 | Dell Inspiron 1525 Laptop Jet Black
Problem printing from Dell Inspiron 1720 with Vista Home Premium to Epson Stylus Colour 1160 using Nikkai USB to Parallel Convertor. Cable supposed to be plug and play. Any pointers?
You pretty much said it when you mentioned "Other than buying the cable in the first place" I have never successfully used a USB to parallel converter cable on any system. My suggestion, asisde from getting a true USB printer, is a parallel port card
http://www.newegg.com/Product/Product.aspx?Item=N82E16839328010&nm_mc=OTC-Froogle&cm_mmc=OTC-Froogle-_-PC+Cards/PCMCIA+Add-on+Cards-_-Syba-_-39328010
May 16, 2009 | Dell Computers & Internet
Not charging off the power jack
One wrong spark and you'll need a new laptop. Take it to a reputable repair person. A jack is an repair.
Mar 29, 2009 | Dell Inspiron 600M Notebook
Dell Inspiron 2200 to Phillips 47 " TV
check this out http://answers.google.com/answers/threadview/id/762913.html *A VGA connector and cable are used to carry analog video signals plus display and graphics data. The VGA is a 15-pin connector commonly found on laptops and other devices. With this port you need a PC-to-TV Convertor to connect laptop to TV. You simply plug the VGA cable from the source into the convertor, and use an S-Video or RCA cable out to the TV. The converter is USB powered, so there’s no external power adapter to carry around, making this laptop to TV connection entirely portable. you will need a seperate audio cable unless you are going to use your laptop's speakers
Feb 04, 2009 | Toshiba Tecra M1 Notebook
Logitech Cordless Mouse Logo
168 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
