1994 Lincoln Continental Logo
Posted on May 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
DCL light comes on and then goes back off
DCL light goes on and off
Anonymous
Level 3:
President:
  • Master 2,004 Answers
  • Posted on May 25, 2009
Anonymous
Master
Level 3:
President:
Answers
2004
Questions
Helped
702590
Points
7857
Please take the car for a scan.
1994 Lincoln Continental check DCL error comes and goes, where are the connections that cause this problem?
dcl stands for data communications link. a communications path between various in-vehicle electronic modules
Check DCL keeps lighting up on dash
Surely you have decades of experience with check lights on your dash,
of any number of vehicles
They have been on all vehilces in north america buy govt emission
mandates since 1981,some 30 years
As usual, you have a possible system fault or failure,that should not
be a suprise , eg: your car needs repair,possibly,at least check it out
You can not & do not want to make the light on the dash go away
So goes the info stored to find the faults
Just go to a repair shop
What does check dcl mean
DCL is Data Communincations Link... the communication connection between the computers in the instrument cluster and the rest of the car. its usually caused (99% of the time) by a bad connection.
The Data Communications Link (DCL) is a wiring system that allows the sharing of information between the Electronic Engine Control System (EEC-IV) , the Electronic Instrument Cluster (EIC) and external equipment.
The EEC-IV system transmits the following information through the DCL to the EIC:
Engine RPM.
Engine coolant temperature.
EEC-IV malfunction indication.
Fuel used.
The DCL system transmits Malfunction Indicator Lamp (MIL) information to the EIC. The EIC uses MIL information to generate a CHECK ENGINE warning in the event of an engine sensor failure.
The EIC will display the message "CHECK DCL" on its Message Center Display if it is not receiving data from the EEC-IV. This warning is turned off whenever data communication is restored.
The EEC-IV monitors the Data Communication Link for faults. If a fault occurs in data communication a continuous Memory Code is set in the EEC-IV. The DCL Codes (529 for EEC-IV and 533 for EIC) can occur separately or together. These codes are not immediately cleared when data communication is restored.
The existance of a DCL code does NOT mean that a module has failed. also I would check for an oil leak or coolant leak that would be the cause of the smoking under the car.
Check this link for some help on fixing it: http://www.lincolnsonline.com/tech/00086.html
Hope helps.
1helpful
How do you check the DCL and charging system?
GO TO THIS LINK FOR A CODE TEST, DCL STANDS FOR "DATA LINK CONNECTOR" THE SYSTEM IS CALLED EEC IV, THIS STANDS FOR "ELECTRONIC ENGINE CONTROL, FOURTH GENERATION". HERE IS A LINK TO TEST OUT THIS SYSTEM.
http://check-engine-light-codes.blogspot.com/2006/04/ford-1985-95-obd1-code-self-retrieval.html
4helpful
3answers
My 1994 Lincoln Continental dcl light keeps coming on and then afterwards the the oil pressure light comes on. What is the problem?
it is a very common electrical problem with digital displays on lincolns, and unless you have extensive wiring experience, I'm afraid that your only option is to replace the display itself, I had to do it on my own 1990 continental twice before the problem went away, my brother's 94 continental still has that issue...luckily most auto salvage yards have these parts available, some even let you pull them out yourself, which makes things even cheaper, I hope this helps.
P.S. if you need instructions on how to take out the display let me know (or go and buy Chiltons)
1helpful
2answers
1994 Lincoln Contiental DCL warning light keeps coming on.
uve entered the computer universe-my condolences--today everyting is connected in almost an imposible logic-u have an OBD 1 system-before 96-go hav car scanned to obtain a data stream to translate the codes that may appear-repair manuals explain these
1994 lincoln continental dcl warning light keeps on coming on
the vehicle module sees a problem and without a scanner to retrieve the proper codes, it will be hard to correctly diag your problem....best to have a dealer/shop check that first.... GL
Check Data Communication Link (DCL)
Look for a missing ground in the circuit. Almost sounds like your missing ground is being sought through other accessories. You will need a ground/power test light - This type lights Green for ground/and Red for power to find the problem.
Start with a schematic
3helpful
What does "check DCL" on my dash board mean?
DCL stands for Data Control Link.
Basically The Engine computer sees some error with the communication to the instrument cluster. Sometimes the connections are loose, sometimes the cluster is malfunctioning and needs to be replaced.
I think you'll have to end up going to the dealer for a proper diagnosis.
I have this same problem, I had it before, but I can't remember what I did to make it go away. I think it was triggered right after I replaced the air-suspension, with a tranditional one, but I can remrember. I am getting this same problem again, my car has 207K+ miles on it.. --Alfredo
Top Lincoln Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Lincoln Expert? Answer questions, earn points and help others
