Question about HP Pavilion dv8000z Notebook
My typing goes uppercase without hitting the caps lock
I will be typing away and lowercase becomes uppercase without hitting the caps lock.  If I move my cursor, it starts highlighting everything I have typed up to that point.  I have to turn off my machine and restart.
  • caw186 Dec 14, 2007
    MYSELF AND A COWORKER WITH THE SAME COMPUTER HAVE THE SAME PROBLEM> NO I"M NOT YELLING THE CAPS IS STUCK ON AND THIS IS THE RESULT> IF ANYONE HAS ANY SOLUTIONS _ I HAVE CLEANED THE KEYBOARD TRILLIONS OF TIMES< HAVE CHECKED STICKY KEYS ON OR OFF AND RESTARTED AND SOMETIMES IT STILL IS STUCK ON CAPS> HELP!
I have the HP Pavilion and cap locks does the same thing.
THIS WORKS EVERY TIME. Hit both the right and left shift lock simultaneously about 5 to 10 times. It immediately disengages the cap locks. It is a little bit of a hassle, but I'm just used to it. It may happen 3 times per week, but I LOVE the machine, so I just fix it this way!
Posted on Jan 16, 2008
The simultaneous pressing 10x of the left and right shift keys work to disengage Cap lock problem!!
Posted on Nov 11, 2009
    New Friend:
I've had this problem before. Try the on screen keyboard. Maybe the Caps Lock button is on.
Posted on Dec 18, 2013
My HP does the same thing sometimes, and I found that the shift key just gets 'stuck', not literally stuck down but it's as if the computer thinks I'm pressing the shift button. All I do is tap it and everything goes back to normal. My control key has also done this.
Posted on Feb 13, 2008
Check left mouse key to see if it has warped downward and it just on the hairy edge of actuating the micro switch. I'm thinking of using a hairdryer to bend mine back up
Posted on Nov 18, 2007
    Problem Solver:
  • 8 Answers
Laptop keyboard trays are sensitive to a lot of things. Mine will occasionally jump to the beginning of the line while I'm typing as if I hit the "home" key but I didn't. I think these are similar problems. Give your keyboard a good cleaning with some compressed air and it may help. Try typing without your hands resting on the computer for a little while and see if it still does it. I realize you can't do this for long because it hurts after a while, but it may be the pressure of your hands is causing something to get pressed like the left mouse key.
Posted on Oct 21, 2007
Typewriter is stuck in uppercase; carriage not moving?
get a typewriter repair shop involved - few typewriter repairmen are available anymore, as most folks use computers and word-processing programs for efficiency.
Mar 24, 2018 | Brother Office Equipment & Supplies
Where can I find the vertical typebar adjustment?
Guessing the buffer resting stops for smalls and possibly capitals have moved ir come loose? They should be adjustable with a small spanner and screwdriver. Or if not adjustable you might have to slightly slightly bend the resting stops! However before doing any off the a both check the plate under machine where the shift lock rests. That might be very loose abd give some similar problems. Best
Jul 16, 2014 | Olympia Office Equipment & Supplies
Quiet deluxe typewriter
This is called motion adjustment
I assume the "segment" or the type faces go up and down when you shift? otherwise the "platen" where paper goes goes up and down either way there are a bump stop that is adjustable. usually with a flat blade screwdriver and a 5/16" wrench. there will be a bump stop on each side that must be adjusted equally however only one may be loose causing the problem. but first you should check the linkage for bends or binds shift lock should hold it to the maximum against the stops. Let me know
David Hughes been working on TW since 1975
Jun 01, 2017 | Royal 1940s Antique "Quiet Deluxe"...
Want to make german Umlaut symbols on keyboard
Every so often you may find you need to type a character on your computer that is either foreign or just not available on a standard keyboard.
The German umlaut is once such symbol.
Used in the German language to indicate a change in sound, the umlaut can sometimes be found in names and words we use in the United States as well.
The literary Bronte sisters, for example, use an umlaut over the E in their last name.
Umlaut's can be found over the vowels A, E, I, O, U and Y in both lowercase and uppercase forms
Hold down the alt key on your PC.
The next step depends on the vowel and case you want for your umlaut.
If you want a lowercase A with an umlaut, type the numbers 0228 on the keypad while holding down the alt key.
If you want an uppercase A with an umlaut, hold down the alt key and type 0196.
Hold down the alt key and type 0235 for a lowercase E with an umlaut.
Hold down alt and type 0203 for an uppercase E with an umlaut.
Hold down the alt key and type 0239 for a lowercase I with an umlaut. Hold down alt and type 0207 for an uppercase I with an umlaut.
Hold down the alt key and type 0246 for a lowercase O with an umlaut.
Hold down alt and type 0214 for an uppercase O with an umlaut.
Hold down the alt key and type 0252 for a lowercase U with an umlaut.
Hold down alt and type 0220 for an uppercase U with an umlaut.
Hold down the alt key and type 0255 for a lowercase Y with an umlaut.
Hold down alt and type 0159 for an uppercase Y with an umlaut.
Typing an Umlaut on a Mac
Hold down the option key on a Mac computer and press the letter u.
Then release both keys and type the letter for which you want the umlaut.
For example, if you want a lowercase A with an umlaut, you would hold down option and u, release, and then type the letter a.
If you want an uppercase A, you would hold down option and the u key, release and then type the letter A.
Hold down option and u, release, and then type the letter e for an umlaut over a lowercase E.
If you want an uppercase E, you would hold down option and the u key, release and then type the letter E.
Hold down option and u, release, and then type the letter i for an umlaut over a lowercase I.
If you want an uppercase I, you would hold down option and the u key, release and then type the letter I.
Hold down option and u, release, and then type the letter o for an umlaut over a lowercase O.
If you want an uppercase O, you would hold down option and the u key, release and then type the letter O.
Hold down option and u, release, and then type the letter u for an umlaut over a lowercase U.
If you want an uppercase U, you would hold down option and the u key, release and then type the letter U. And for an umlaut over an uppercase Y, hold down option and u, release, and then type the letter Y.
For a lowercase Y, hold down option and u, release, and then type the letter y.
Apr 21, 2013 | Computers & Internet
How to change the uppercase and lowercase letters
Either by pressing and holding the shift key (on left and right of keyboard, looks like up arrow) while typing, or by pressing the CAPS LOCK key to put capitals on or off. The caps lock key is usually one above the left shift key.
If you cant find them just advise your make and model of computer and I could tell you exactly where the keys are.
Oct 31, 2010 | Computers & Internet
What is uppercase letter
What I am typing now is 'lowercase' letters. WHAT I AM TYPING NOW IS 'UPPERCASE' LETTERS. Use either the 'shift' or 'caps lock' keys on your computer keyboard to change between the two.
Aug 10, 2010 | Computers & Internet
Letter remains in uppercase
Is the caps lock key light on? If so hit the caps lock key to get the light to turn off. If it doesn't turn off then your keyboard is bad and will need to be replaced.
Jan 29, 2009 | E-Machines eMachines Desktop PC
I dont know anything about cap locks i have to get a new password every time i log in to facebook and i dont know why they keep rejecting my password HELP
Caps lock is that key on the left side of your keyboard. When pressed, it makes all letters that are typed in into uppercase letters. For example; without caps lock pressed: "pressure". With caps lock pressed: "PRESSURE". If it mentions something about passwords being "case sensitive," this means that an uppercase letter A (A) is recognized differently than a lowercase letter A (a). Since you can't see your password being typed, it is important to make sure caps lock is not pressed. If this becomes too complicated, open up MS Word, notepad, or wordpad and type your password there so you can see it, then copy and paste the password into the password space on facebook. Good luck with that.
Nov 15, 2008 | Computers & Internet
CAPS LOCK PROBLEM!!! URGENT HELP NEEDED!!!!
On some keyboards, there's a hidden 'feature' where if you hit CAPS LOCK and Shift at the same time, everything works backwards, until you hit that combo again.
Try this and let me know if it pertains to you...
Dec 29, 2007 | Computers & Internet
HP Pavilion dv8000z Notebook Logo
3,803 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
