Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
USB not woking
I have a problem with my usb drive which I bough a week ago. It was working for few days, and then suddenly it stopped. When I plug-in the drive, system does recognize it as a usb drive and install averything but I can't access the drive nor format it. When I try that it showes a massage "Please insert a disk into drive" and a letter of that dirve. I've checked it with WinXP, NT, Vista with same result on every each one.
Thanks for any suggestions.
  • enigma11150 May 03, 2008
    flash drive can't be modified
    Brigadier General:
  • 6,966 Answers
Based on your post/description, your USB drive is faulty. You can try salvage/repair it but chances are all data/information would be lost. If Windows can't do anything try using HP's USB FlashDrive Utility. File name "cp006049.exe."  Do a Google, download, install and execute.
Hope this be of some help/idea. Pls post back how things went or should you need additional information.
Good luck and kind regards.
Posted on Oct 21, 2007
Computer doesn't recognise hardrive
It may seem obvious, but did you try a different USB port? Did you try a different computer? and did you try a different cable/cables?
Oct 03, 2012 | Freecom ToughDrive external hard drive -...
My external has stopped working- it also has an odd sensation when I pick it up rather like two identical magnet ends being held together. I only bough it 4 months ago and want to get the data from it!
is the issue a power 1 or does it power up but your computer doesn,t regonized the harddrive within the external...have you tried a separate power supply/usb cable....or try a different usb port in another computer
regards Tony
Mar 31, 2011 | Hitachi 1TB External USB 2.0 Hard Drive
My simple drive external harddrive now lists itself as Local Disk (F) in my computer folder, and when I try to open it says, F:/ is not accesible the file or directory is corrupt and unreadable. it work a...
If it worked a few days ago then you could restore your system to a week ago and it should recognise again
i see no mention of what oprerating system you are using so I will assume XP.Vista or Windows 7
Using XP then follow these steps
Go to Start
Then All Programes
Then Accessories
Then System Tools
Then System Restore
This will give you a calendar to choose an earlier date
select one and click accept or continue and wait for the machine to shut down and restart
Once restarted a message should appear saying if the restore was completed.
Plug in your drive and test for fuctionality.
Let me know if you need the procedures for Vista or Widows 7 because they are a little more envolved.
All tho the steps are simalar I would much rather give you the correct infomation.
Hope this helps,Cheers Misterdj
Mar 27, 2010 | SimpleTech SimpleDrive Portable USB 2.0...
SIIG Hi-speed USB 4-port cardBus - iphone/flashdrive problems
Remove your device from the device manager and reboot unit.
Restart and reload device drivers.
Make sure the driver are for xp pro
Nov 14, 2009 | Electronics - Others
Bought a NetGear WPN111 RangeMax Wireless USB 2.0 Adapter a few months ago. It was working fine up until a few days ago. It started dropping my internet connection, and now it won't even detect any...
firstly you can try upgrading the drivers on the adapter. following is the link for the latest drivers
If the problem still persists
try changing the wireless settings on the wireless router.
Nov 12, 2009 | NetGear WPN111 RangeMax Wireless USB 2.0...
I have a WD passport 320gb, at first it worked one of my usb. then all of sudden, it stop recognizing my WD Passport with one usd port, so i plug it in another usb then it works. and after a couple of days...
Are you using an external power supply for the disk? If not, you might be overloading the USB port. It should not happen, but USB ports are limited in the amount of power they can output. Especially laptops might face such problems.
Do other USB devices still work on those USB ports? If so then the port is at least not broken.
Sometimes you can uninstall and reinstall the USB hubs and controller devices in the Device Manager to fix USB problems.
For other ideas on troubleshooting external hard disk issues, you can check:
Jun 13, 2009 | Western Digital Passport WDXML800UE...
Logitech Illuminated Keyboard (USB) Connection stops working
Hi, kreich.
I recommend that you take your keyboard to another computer, work for a while, and see if it happens again. The problem might exist due to improper USB drivers or faulty USB hub, especially if you have problems with other USB devices.
Also, make sure you reinstall SetPoint software which came with your keyboard.
Your responses are intended to improve the level of service provided. Please rate your experience.
Mar 18, 2009 | Logitech Illuminated Keyboard
Computer does not recognize my camera
Please use another USB connecting cord as old one seems broke.
Feb 11, 2009 | Fuji FinePix F20 Digital Camera
My PC is not recognizing my WD Passport 120GB USB external drive. I used just few days ago and connected the usb cable to my computer and the WD Passport drive and not recognized on my 2 laptop and 2 other...
I have the 80GB WD passport and it suddenly stopped working one day.  The unit lights up but nothing else.  Finally I cracked the case open and found, as I suspected, that the drive is simply a SATA laptop drive with a SATA-to-USB conversion card built in.  I suspected that the card was **** so I disconnected it and used a USB hard drive adapter ( and I can read/write to the drive just fine.  Best part is that the adapter I use has its own power supply so I'm not pulling juice through the USB cable for a SATA drive.
Even though mine "works" again I don't recommend these drives to anyone.  They're just not sturdy enough or well designed.
Sep 09, 2008 | Western Digital Passport WDXML800UE...
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
130 people viewed this question
Top Kingston Computers & Internet Experts
Alun Cox
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
