Question about JVC AV-56P575 56" Rear Projection HDTV-Ready Television
Drooping seal inside screen
JVC model av56p575. Drooping seal or gasket at top center of viewing area.
Did you ever find a solution?
Posted on Nov 26, 2011
The top left of the screen is drooping down and is green,red goes across where green is drooping from.
This is a common problem. Its called a convergence failure. You can get all the parts from www.TvRepairKits.com
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 28, 2011 | Hitachi 46F500 46" Rear Projection...
Rrk150OB is drooping an dthe pin keeps falling out
I assume you mean the pivot pin on which the top half of the mixer pivots to remove the bowl is sticking out of the side of the stand. Turn the mixer upside down and look up inside the stand which is hollow. You will see a screw. Tap the pin back into position and then tighten the screw.
Now to fix the drooping, and I assume you mean the beaters are hitting the bottom of the bowl, tip the mixer back and look into the hinge area. You will see a rather large screw. Turn it ccw a turn and check the beater to see if it is still hitting the bottom of the bowl. Repeat the procedure until you have 1/4 inch clearance or so from the bottom of the beater to the bowl.
Mar 28, 2010 | KitchenAid RRK150 Stand Mixer
I have a jvc projection the top of the screen is misaligned (drooping)convergence dosent help whats wrong
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 24, 2009 | Televison & Video
Color seperation and red drooping line
You have defective Convergence IC's. It's best to have a service company verify and do the repair if you wish. Normally runs about $250.00
Jul 14, 2009 | Zenith R45W46 45" Rear Projection...
We have a 31 inch Proton TV. At the top of the screen, you can see where the seal has pulled away fron the screen on the inside. It is drooping a bit on the left side at top, but quiet a bit on the right...
you would need to take the back off the tv to access the tube,apply adhesive and allow it to set for a few hours.you would have to place it face down on a soft surface for the seal to take hold
Dec 05, 2008 | Televison & Video
AIR HISSING NOISE COMING THROUGH DOORS CHROME TRIM.
Trim generally does not have much to do with body sealing. Check to make sure that the rubber door seals are intact and are actually touching the door frame. Make sure your door is properly aligned in the frame. Sometimes the hinges wear and cause some drooping. If condition is not severe, sometimes you can "fatten up" the door gasket by sliding a length of rubber hose inside it. As far as trim goes, most trim on Jeeps is glued on.
Good Luck
Nov 11, 2008 | 2005 Jeep Grand Cherokee
Tv screen
this is your convergence amp
for cheep repair call
719 687 6997
Nov 11, 2008 | JVC AV-48WP30 48" Rear Projection...
Drooping screen
This is usually an indication of either bad connections at the convergence ICs or defective ICs. If you can solder, resolder the connections first. If that fails to resolve the problem replace the ICs. These will be large black ICs attached to a heatsink and marked STKxxx.
Dan
May 19, 2008 | Akai PT5598HD 55" Rear Projection...
65 in.JVC bad picture
You may have a convergence problem that means, there may be convergence ic's bad or related components.
If you know something about tv's, try checking things out.
You can get a repair manual from websites to download.
If you do not normally fix tv's the best thing is to call a tv repair technician.
Feb 22, 2008 | JVC AV-65WP55 65" Rear Projection...
LINE ACROSS TOP OF SCREEN-LOOKS LIKE A GASKET
I have the same problem with the gasket dropping from the top of the screen. I took the back casing off (approximately 16 screws) don't forget to take off the adaptor box with two screws. and the additional 8 screws located at the bottom of the panel casing. After that the back panel will come off. Remove the tv screen from the front casing, approximately eight screws. Be careful not to dislodge any wires while remove the screen. Finally remove the gasket. All of this can be done at any local tv repair shop for about $150 dollars.
Dec 02, 2007 | Protron PLTV-32 Television
JVC AV-56P575 56" Rear Projection HDTV-Ready Television Logo
81 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
