GE AHG40LA Dehumidifier
Problem for GE AHG40LA Dehumidifier
Ice buildup on the back screen. Water does not empty into the hose connected to the drain connection
By keyzj on May 25, 2009
There is ice buildup on the back screen. The water is not emptying into the hose attached to the drain connection.
Best Solution
posted on May 25, 2009
Very Helpful)
alex_salve
Rank: Wiz
Rating: 80%, 50 votes
switch off the machine for atleast 6 hrs and restart again.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for GE AHG40LA Dehumidifier
Questions and Unsolved Problems for GE AHG40LA Dehumidifier
Do you recommend GE AHG40LA Dehumidifier?
Answer
Answer
Do you stock replacement 5Ltr tanks for an Amcor TC120 ?
Answer
I need a user manual for the following Dehumidifier: Model - Airforce BQWDH - 816EAH
Answer
water pours out onto the floor when unit is hooked to a gravity flow hose why
Answer
Doesn't shut off when RH reaches pre-set value; shows "P1" in the LED readout.
Answer
I have a GE AHK40LKG1 dehumidifier that is two years old. The fan and display come on, but the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE AHG40LA Dehumidifier:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
