Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Condensation inside the refrigerator on the corner/roof
There water build-up on the inside roof of the refrigerator
  • 78 Answers
You need to defrost the fridge by switching it off for atleast 8 hrs.
Posted on May 25, 2009
The blobs of water are inside my salad drawer on the roof
condensation
probably from placing ambient temperature food ( from the shop) into a cool environment ( draw)
Dec 15, 2015 | Refrigerators
My coleman air conditioner 7300 series is leaking water on the inside
Water in an air conditioner is generally condensation building up on the indoor coil. This happens when the temperature of the coil is below the current dew point of the atmosphere. You have possibly two issues going on.
1) the condensation drip line, which carries the water to the outside is blocked or disconnected (most likely blocked with wet dust build up etc) and can typically be cleared by using an air hose to blow the blockage clear.
2) excessive water can be an indicator that you may have a slow leak in the refrigerant system. reduced pressures will lower the temperature of the coil causing it to condense more water, more frequently. While you might enjoy the seeming better performance of the unit, if there is a leak it will eventually reach a point where the water will freeze(cutting off the air flow so no cooling) and eventually stop working altogether. Have a certified technician check your system for leaks. Remember that most rooftop units use R-22 refrigerant, not R-134a automotive refrigerant. The wrong refrigerant in the system can be very damaging to components and seals, and can cause the unit to function improperly.
Jun 19, 2014 | Dometic Rooftop RV Air Conditioner
My LG Model LRTN18320WW is leaking water inside frig. on bottom below produce drawer. has occurred since summer. what is solution?
Drain in freezer compartment is plugged.
Mold (fungus) buildup sometimes restricts water flowing into condensate tube in the defrost cycle, and water somehow can enter in the refrigerator compartment and out the bottom of the refrigerator door.
You must clean the condensate tube!
You must remove back cover in freezer. One screw in left upper corner behind plastic screw plug will allow you to remove the cover exposing evapourator coil and condensate drain tube hole below it. Must also remove back cover at rear of refrigerator exposing the condensate drain tube END which may be restricted also.Tube must be totally cleared to allow the water created from defrost cycle to exit to the drain pan in the bottom of the refrigerator.
Oct 05, 2010 | LG LRTP1231W Top Freezer Refrigerator
What is causing water to build up inside the refrigerator section? there is water in the crispers and on the shelves.
A condensation problem inside a fridge, normally means either, you are puting uncoverd food /or food that has a high water content (i.e.salads) into the fridge, which may be warmer than the inside temperature of the fridge, hence condensation(leaving the door open too long has the same effect)only remedy is paper towels in bottom of crisper so that salads dont go soggy.and wipe out fridge as often as needed.
Mar 10, 2010 | Whirlpool ES5FHAXS Side by Side...
Water leaking from the roof of the fridge inside.
That is condensation. The rubber insulator (gasket) on the door may be damaged or worn. The door does not close and seal properly.
Make sure that nothing that is on top of the refrigerator is "hanging" into the path of the door seal (like a bread bag ponytail).
Also to consider:
Door hinge is loose so that door is not aligned for proper door seal.
Refrigerator is not "level" so that door is not ...
Freezer is defrosting (heating elements will warm up the coils, so "dew point temperature" may have been reached.
Check the door gaskets.
Sep 21, 2009 | Kenmore Refrigerators
Water dripping out under freezer
Just like an ac unit, angle it up on one corner and use say a drip pan,and see if that makes any difference. (It's common physics/Refrigeration) "Condensation"
Aug 11, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Coleman 1300, condensation buildup inside unit, ceiling wet
Check for plugged drains under cover on roof, sticking out at base of unit usually. It should be running off roof.
Aug 04, 2009 | Heating & Cooling
Leaking water
Look at your door gaskets. If they ain't kosher then excessive humidity will build into the frig.
Jan 02, 2009 | Frigidaire GLRT188WD Top Freezer...
LG Refrigerator
  • the drain line in the freezer may be clogged forcing water to drip into the freezer. clean out the freezer and pour some hot water in the back of the freezer to unclog the drain.
  • another cause of this would be if the door is not sealing properly then the inside of the refrigerator will build up condensation.
Jul 05, 2008 | Refrigerators
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
403 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
