Question about HP iPAQ hw6515 Pocket PC
HP IPAQ 6515h
Phone does not turn on from power button. it turns after battery remove and fix but it again turn off after three step
  • 1 more comment
  • Anonymous Nov 14, 2007
    Phone often switches off by itself. Sometimes while receiving the call the phone switches off.
  • gkchennai Nov 15, 2007
    Checking with HP Service is no use. The "Service Engineer" behave like the Ipaq. He swithces himself off.I am trying to get a battery replacement on the assumption that the present battery is failing. But the Power status seems to be ok. The suggestion about a button at the back needing to be pushed with the back cover didnt work because there is not button at the back.
  • Anonymous Jan 27, 2009
    i had the same problem, no turn on with the red led blinking during charging, but no charge at all. hard reset not useful.
    During recharging i tried to push the turn on button while pushing the MINI SWITCH with the stylus, and the device turned on, with the fixed amber led. Now everything is working fine. Thanks a lot for your useful suggestions.
Had same problem. Fixed it by using schotch tape. Just to prevent door from moving. Everything fine now.
Posted on Oct 17, 2008
JUST SEE AT THE BACK THERE IS ONE MINI SWITCH THAT HAS TO BE PUSHED BY LEVER PLASTIC ON BATTERY COVER . ONE THAT IS ON TOP RT CORNER. INSERT SOME PIECE OF TISSUE PAPER SMALL ONE AND CLOSE THE COVER OVER IT IT WILL DO-ALLEY2100@YAHOO.COM
Posted on Oct 28, 2007
My hp ipaq 614 wif is not turning on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 23, 2012 | HP iPAQ 614 Business Navigator 2.8-tft...
HP Ipaq 4700 won't switch on -
try to remove the battery for a while. or reset the unit.
Sep 17, 2008 | HP Computers & Internet
Cannot get past opening screen or turn off unit. Unit seems frozen
Did you try to flash the BIOS/firmware of your device?
1.) Go to the Master Index of BIOS, FIRMWARE, & DRIVER Updates,
2.) Select the appropriate hyperlink for your model. (in your case it's here http://mobilitytoday.com/forum/showthread.php?t=4846)
3.) Download the most recent BIOS version SoftPAQ (SP) for your Model of iPAQ.
4.) Press the POWER + iTASK + CONTACTS + RESET buttons at the same time so as to enter the FLASH Mode
5.) Make sure your USB connection to the Cradle is hooked-up.
6.) Place your iPAQ in the USB Cradle.
7.) Stop the MS ActiveSync session on your HOST PC: CTRL-ALT-DELETE > TASK MANAGER > PROCESSES.
8.) Hilight WESCOMM.EXE and select "End Process" button.
9.) Run the file you downloaded from HP in step 3.
10.) The iPAQ should now begin Flashing the iPAQ's ROM BIOS
Jan 11, 2008 | HP iPAQ HX4700 Pocket PC
I want to restart of shut down my HP iPAQ rx3115
For the HP iPAQ rx3115 and rx3715 models, hold down the Mobile Media button (on the far left) and the iTask button. Then press down the reset button with the styles for a few seconds until the screen goes dark.To turn on your HP iPAQ after your hard reset, either press the reset button again, or plug it into an AC power source.
Mar 01, 2011 | Cell Phones
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
TOUCH SCREEN NOT RESPONSIVE-IPAQ 6515h
Take your phone to replace the touch screen. There are nothing else to do.
Feb 07, 2009 | HP iPAQ hw6515 Pocket PC
HP IPAQ 111 Handheld PDA
If you want to "wipe" the PDA heres how:
-you may need two people to do this,
-hold all three buttons together: START, OK, VOICE
-keep holding these buttons and push reset for 3 seconds
-let go the reset
-then let go the 3 buttons
-the Ipaq will go into CLEAN BOOT mode and start over again
Let me know if these worked.
Feb 11, 2008 | LG KU990 Viewty
H6315
I got the same problem. I even tried to plug the battery to the second battery charging slot, still couldn't get it back to life. But the Ipaq screen lights on with progress bar progress for about 5 seconds, then dead again. I even doubted the battery was toasted.
I gave it a final shot:
1. Remove the battery, and then put it back.
2. While the screen lights on, within 2 seconds, cold reset the unit by press the hole with stylus and push the power button at top in the same time.
In my case, the progress bar will keep going until I see the tap screen instruction and everything back to normal. But it reminds me that the removable battery is totally discharged. So I put it in cradle and I am able to synch it with my PC. Everything seems o.k. while it sits in the cradle, except the charging light won't turn red.
When I remove it from the cradle, it still lights on, battery shows 99% which is healthy. but when I turned it off, it won't start anymore. I have to repeat the above steps to revive it. Sometimes I have to remove the battery and wait for a while and then put it back, so that the screen can light on to give me chance to cold reset.
Conclusion: Maybe need a new battery. I will check Ebay to get one.
Please post if you have other solutions.
Dec 22, 2007 | HP iPAQ h6315/h6365 Pocket PC
IPAQ 2795 freezes during boot up.
I had the same problem. Contacted HP customer service chat, and got the following answer that
solved the problem:
1. Remove the battery for 30 minutes.
2. Insert it again in the iPAQ.
3. Perform a clean reset on the iPAQ and at the same time charge the iPAQ.
To perform a clean reset please follow these steps:
Press and hold the Calendar button, the Power button, and the Messaging button.
While holding these buttons, use the stylus to lightly press the Reset button on the bottom of the HP iPAQ.
The problem can also be solved by getting a new battery, and performing the clean reset while charging (using the portable charger, not the cradle).
Nov 16, 2006 | HP iPAQ HX2795 Pocket PC
Hard Reset HP 6515
Hold down the POWER button and press the reset hole for approx 5 seconds, then remove stylus from reset hole first, follow by release of POWER button.
Sep 07, 2005 | HP iPAQ hw6515 Pocket PC
HP iPAQ hw6515 Pocket PC Logo
199 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
