Question about Boxlight XP-58z Multimedia Projector
Auto-Off Boxligh XP-58z problem:Tha Auto-Off Setting stays alway in ON Can't be saved as OFF... any ideads?
  • 2,237 Answers
Reset the settings to factory default.
Posted on Jan 28, 2010
How can I access on my computer the way to adjust the time that my display window stays open
Start, Control Panel, Appearance and Personalization, Personalization - Power saving setting. You can keep everything on always. Windows 8 will differ, but same thing - Display settings.
Then your screen will always stay on.
Apr 19, 2015 | HP Computers & Internet
How can I fix blue color in the projection?
its an inside adjustment. If you wouldn't mind buying another one then try to fix it,now you need another because you messed this one up.
Jul 22, 2014 | Boxlight XP-58z Multimedia Projector
How can I fix green vertical lines in the background of my projector?
I can see by your name that you are trying to fix the entire box .I would have to say that it has probably cost you almost as much for parts then a new one would cost.
Setting the clock on a brinks timer 44-1011
I finally found the instructions for the Brinks timer 44-1011 and they work.
    • BRINKS DIGITAL TIMER 44-1011 INSTRUCTIONS
    • CURRENT TIME SETTING
    • 1*Press and hold the OK button for 4 seconds. Hour Display flashes.
    • 2*Press +/MANUAL or - to select the hour. Press OK to confirm.
    • 3*Minute display will now flash. Press +/MANUAL or - to select the minute. Press OK to confirm.
    • 4*Press MENU to exit the time setting mode. Now the timer is in clock mode.
    • PROGRAM SETTING NOTE: This timer can be set up for up to 2 different programs. We will use PROG 1 for this example, however these steps can be repeated for any of the 2 programs. To cycle through the individual programs use the +/MANUAL or - after pressing MENU in step one until the desired PROG "#" is flashing. To clear a program setting hit the RECALL button when you have the program selected.
    • 1*Press MENU button, PROG 1 "ON" will flash, press OK.
    • 2*Hour will flash. Cycle with +/MANUAL or - to desired hour, press OK.
    • 3*Minutes will flash. Cycle through minutes +/MANUAL or - to desired minute, press OK.
    • 4*Program will be flashing again. Press +/MANUAL to get to PROG 1 "OFF" blinking, press OK.
    • 5*Repeat steps 2-4 to complete PROG 1 setting.
    • 6*When done setting programs press the MENU button to return to clock mode.
    • 7*Press +/MANUAL to have LCD showing either "AUTO ON" or "AUTO OFF" for the timer to execute the programmed settings.
    • DAYLIGHT SAVING TIME SETTING (DLST)
    • 1*In clock mode, press RECALL to turn on or off the Daylight Saving Time.
    • 2*Turn on DLST, the below of LCD shows +1H. Time is adjusted by adding one hour.
    • 3*Turn off DLST, +1H will disappear and LCD shows the real time. MANUAL OVERRIDE AND ALWAYS ON/OFF When in clock mode the +/MANUAL sign cycles through
    • 4 settings that serve as manual override. **ON - Indicates that the timer is in the ON mode, and will always be on regardless of the programmed setting. **AUTO ON - At this selection, the timer will come on regardless of the programmed setting, but it will follow the next programmed command. **OFF - Indicates that the timer is always off (i.e. the wall socket is turned off) **AUTO OFF - Indicates that the timer is in the OFF mode until the next programmed step that turns it ON.
    • NOTE: For normal timer function, the selection must be either "AUTO ON" or "AUTO OFF". RESET At any mode, press RESET for 5 seconds. All settings will be cleared, return to clock mode, 12:00 MO, AM, AUTO OFF will be shown on LCD
I hope this is helpful. It was a bear to find.
Dec 24, 2012 | Hardware & Accessories
Need diagram to show route for belt
I spent 2 hours changing my serp belt .Always ended up too long. Called auto zone and they had a diagram for my belt. Just need to know year, make and engine size. I was so mad that I could have saved all tha time and frustration.Hope that helps
Mar 07, 2011 | Ford Taurus Cars & Trucks
Backlight on Flybook V5
Hi Piergiorgio,
Nothing in the registry or BIOS however, in the Flybook control center, you can manually set your brightness on the system and turn off auto backlight. That way the system will always turn on and your system will always remember the setting of the back light.
Let us know if that helps!
Feb 17, 2010 | Microsoft Dialogue Technology Flybook V5
Hello i have a cuisinart dcc-2000 i can't seem to find the user guide i need to know how to keep the coffee maker on it usually turns off in about an hour after coffee is brewed. leticia
The user guide is available from www.cuisinart.com
Turn the coffeemaker to Auto-Off - by default, it will say "2:00," but it may have been manually changed to "1:00"
Hold in the hour button until the clock starts flashing, and then advance the hour button until the display says "4:00" (remember: this is on the auto-off setting only).
Now, whenever auto-off is activated, it will stay on for 4 hours.
-Tha Mp3 Doctor
Jan 24, 2009 | Cuisinart DCC-2000
Disable music auto refresh
Disable auto-sync in Windows Media Player and it will stop doing this.
-Tha Mp3 Doctor
Dec 05, 2008 | SanDisk Sansa Clip MP3 Player
I have a 1992 acra legend,that has only 37,000 original miles and the abs light on the dash stays lit.Is there a way to have it reset?
you can disconnect the battery but if a sensor broken light will come back as soon as you drive the car it will come back hope it help fixya our post thanks pierre
Jul 19, 2008 | 1991 Acura Legend
Top Boxlight Office Equipment & Supplies Experts
jasbo
jasbo
Computer Links
Mike Charette
Are you a Boxlight Office Equipment and Supply Expert? Answer questions, earn points and help others
