Question about Garden
I have a 1641 cub cadet, when I turn the key I hear a click and tractor will not turn over
  • tmeints May 25, 2009
    oil & gas are full
    the spark plugs are new,it acts like maybe it's a starter or starter switch
  • 323 Answers
Okay, there are only so many things that will cause this problem.
A: The battery must have a full charge with no dead cells.
B: The cables at the battery cannot be corroded; if so, they must be taken off and steel brushed clean, with a little oil on them. Brush the connectors clean as well. Make sure the terminals are tightly tightened to the wires.
C: Make sure the wires on the solenoid are securely tightened.
D: If you look at all of these and it still clicks, it has to be the solenoid. Cubs are notorious for burning up starter solenoids.
I have two Cubs myself, and I have replaced solenoids on both, one of the twice.
Posted on May 25, 2009
    Sergeant:
  • 322 Answers
Does it have any fuels? maybe there is no fuels.
  • Marc Eballa
    Marc Eballa May 25, 2009
    Is there a spark plug? try checking it.
Belt routing for cub cadet 1641
Easiest way is to remember; flat side of belt goes onto flat pulleys and small V shape goes into V shaped pulleys.
Oct 08, 2014 | Garden
Cub cadet 1641 how to remove starter motor
The top bolt is very difficult to reach. I ended up bending a 1/2" combination wrench to a right angle as close to the box end as I could. It was tedious to use, but it worked.
Jan 09, 2014 | Cub Cadet Garden
Starter wont engage on 1641 lt cub
sometimes the shaft that the gear rides on gets dusty dirty and the Bendix gear cannot slide up. Is that what you have? You can hear it spin but doesn't engage the engine? A week battery will do that too. Thees CC starters like their voltage high
Nov 10, 2013 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet will not start
The click you normally hear is the fuel shut off solinoid in the bottom of the carb, if there is no power here and no click you have either no power in the battary, the battary terminals are loose, or there is an inline fuse gone.
Jun 18, 2012 | Cub Cadet Garden
1641 cub cadet how to check fuel shut off solenoid
it wont start at all if the solenoid is unplugged try and see if it will run with the choke about half way on if so you have trash in your carb
Apr 21, 2012 | Cub Cadet Garden
Cub Cadet 1641 won't start....
sounds like the battery doesn't have enough power to crank the engine
May 12, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet 1641 lawn tractor won't start
Beings you can get to the solenoid I would check it first. There is a small post (not battery or starter), touch a jumper wire from battery to this post. Then with a test light check the wire to that post w/key in start position (remember you must be in regular start condition for this test). If no light, you can only go to each switch one at a time and bypass then try to start again. Not sure how many there are.
Apr 26, 2010 | Cub Cadet Street Sign- tractor lawn riding...
I have a Cub Cadet GT1554. I used it yesterday
Check the seat safety switch and the pto safety switch.
Aug 18, 2017 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
63 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
