Question about Canon i 320 InkJet Printer
Printer problem The orange light keeps flickering Eight times, I was in the process of changing the colored ink tank.
I went out and bought a new printer, the technical assistant said there were no replacement parts for the Model I had.
Posted on May 26, 2009
I have a Canon iX4000 color printer which is now showing a Error 5C00\r\nplease help
Your 'waste ink tank' is supposedly getting full.
Note that it may actually be getting full, if it is, and you keep printing, it can get messy. very very messy. ;>
I'd use a piece of folded newspaper about the size of the printer underneath the printer just to be safe. If you do this waste tank counter reset a few times, you WILL leak ink.
Power off the printer. Hold down Resume button, keep holding.
Hold down power button, wait for beep, release resume button while still holding power button down.
Press Resume twice, and release all buttons. Wait for indicator light to settle (stop changing). Press resume either 3 or 4 times, the indicator light will turn orange when you have pressed it enough times. Do not hold, just press.
When the light is orange, press power.
If you still get the error, you may have enough ink to actually physically block a sensor in the tank. When that happens, not only are you close to ink stains, you have to disassemble the printer and clean the pads and 'tank' out. This is even messier than an ink leak. ;>
Sep 08, 2010 | Canon PIXMA iX4000 InkJet Photo Printer
Where is the waste ink tank?
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Dec 17, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Tank for used ink is full - how do I change it?
Dec 14, 2009 | Canon PIXMA iP2000 InkJet Printer
Absorber tank is full
Dec 01, 2009 | Canon Office Equipment & Supplies
The middle light keeps flashing 7 times then stops then repeats. the other button to change the paper type. i dont think its a ink issue possibly a paper one.
This mean multiple ink tanks of the same color installed or Ink tank in a wrong position.Check your ink tanks.This ink tanks has a memory chip.Sometimes this chip fails.
If the green light blinks with a orange 7 times this mean the waste ink tank is full.Follow this:
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Nov 04, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Blinng orange light
Answer Part 1 of 2
An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take appropriate action.
Two flashes: Out of paper or paper feed error
Reload the paper correctly and press the RESUME/CANCEL button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
Four flashes: Ink tank is not installed properly
Open the Print Head Cover and check whether an ink tank is installed. If an ink tank is installed, push the button of the ink tank, and reinstall the ink tank properly.
Five flashes: No Print Head installed, or Print Head failure
Install a Print Head.
When the error continues, contact a Canon service representative.
Eight flashes: Waste ink absorber almost full
Ink used for cleaning is absorbed in a waste ink absorber placed in the printer. Eight flashes indicate that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so that you can continue printing.
Important
If this error occurs, replacement of the waste ink absorber and maintenance of the printer are required. Canon recommends to contact a Canon service representative as soon as possible. Once the waste ink absorber becomes completely full, it cannot be printed until the Waste ink tank is exchanged.
Nine flashes: A specified period of time has lapsed without receiving a response from a digital camera or digital video camcorder / The digital camera or digital video camcorder connected is not compatible with this printer
Sep 30, 2009 | Canon PIXMA iP90 Mobile Printer
Tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Sep 14, 2009 | Canon i350 InkJet Printer
The Orange light flashes Eight Times when I turn the Printer on.
This error is a head pump error its worth trying to clean the head with warm water to soften any dired ink in the head if that dnt work its time to replace the head
Rgards Al "alstech"
May 24, 2009 | Canon BubbleJet i320 Printer
When i turn my printer on the light flashes green once and then orange 5 times. cannot get past this stage - any ideas?
Here are all the flashing explanations:
See Paper Jams
Four flashes: Empty ink tank
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. After printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it may cause damage to your printer.
Refer to your Quick Start Guide for instructions on how to replace an ink tank.
Five flashes: No print head installed/Defective print head
Install the print head. Also, ensure that the protective tape has been removed.
If reinstalling the print head does not solve the problem, replace it with a new one. Contact the Customer Care Center.
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact the Customer Care Center.
Mar 08, 2009 | Canon BubbleJet i560 InkJet Printer
Canon i 320 InkJet Printer Logo
59 people viewed this question
old marine
old marine
