Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Seagate 750GB usb HDD asks to format,when opening by double click
I have Seagate 750 GB USB HDD, it was working fine till yesterday.
Now when i connect it to my PC it asks to format the HDD.
I tried to see from disk management, it shows as basic disk.
Please suggest what to do.
My OS is winxp SP II.
  • ithelpdesk_s May 25, 2009
    i can not format the HDD as it has very important data in it
  • Morne Swart May 11, 2010
    It sounds to me as if your HDD died on you, If you try to format the disk, does it allow you or not?
    Master:
  • 969 Answers
Use computer management to access and view drive status. Go to Seagate website and download Seatools, free.
Posted on Aug 25, 2014
  • 79 Answers
Remove the HDD from the Bay, and install it in a PC, as an extra drive, then see if you can access it that way just to get all you data!
Posted on May 25, 2009
  • 34 Answers
The disk is either damaged or the USB interface is damaged.
1) You could try opening the external case and connect the disk to your computer directly (Using IDE/S-ATA cables)
2) Format the HD and use data recovery software/service.
I have a 500 GB Seagate portable external hard drive model 9ZA2AH-500. It was working fine untill yesterday. Now when I plug it in all I get is a faint beeping sound Then it stops. I have tried plugging it...
It may be the interface that has failed but I suspect the hdd has failed.
Take the hdd out of the case and fit another drive. If that one is OK the hdd is dead. If it doesn't work, try a new usb to SATA interface.
Sep 25, 2017 | Seagate Free Agent Go Small 12 GB USB...
Can't open up the files I've copied
In what format are your documents before the backup?
Apr 12, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Hi,how can i format my seagate freeagent goflex 750 to fat32 ?
Welcome to Fixya. Once you connect the harddrive on the computer go to my computer or computer then right click on the seagate drive then select format. On the window that will pop out on the screen select Fat32 then format the drive. Please use windows xp or 7 because vista don't have fat32 but exfat.
Thanks
Jul 17, 2011 | Seagate FreeAgent GoFlex 750 GB USB 20...
I registered my seagate GOFLEX 750G portable drive on my MAC, but it does not work on my school MAC and pc, even after I registered, please help me
You dont need to register the product to use it. Please make sure you have admin privileges at both computer in order to install new hardware.
Mar 22, 2011 | Seagate 750GB FREEAGENT SATA/USB 2.0 750...
I have problem with my hard drive can not open, when i put in computer it doesnot show on .
it seems its not formatted - if you have Windows, try this:
Start > control panel. Then Go to Administration Tools (or somethine like that, dont have windows in english) and find Computer Management icon. Run it. Now explore to Disc management - there you will see your USB HDD. Click on them with right mouse button and create new partition, etc..
Sep 21, 2010 | Seagate 750 GB USB Hard Drive
Friend sent me a usb stick that I can't open
don't format it...most usb sticks actually have two partitions. That partition that is saying to scan or reformat is the partition that has the usb stick setup files. Open the icon "My Computer" and see if there is another drive listed in there....like drive "K" or something else. Usually once you click on not to format, another windown will open and ask what you want to do with this drive. If the other drive is listed, just click on it to open it and retrieve the files. If it isn't listed, try another usb port or reboot the computer and try again and make sure you have an internet connection to see if there is a driver that is needed.
Jun 11, 2010 | Verbatim External, USB 2.0, 750GB...
My computer doesn't detect my FreeAgent Pro 750GB (seagate)!!!
Do not despair - check out the documentation on page 3 (you'll need Adobe Reader to open this PDF file):
http://www.seagate.com/support/freeagent/FA_Pro_15_QSG_US.pdf
Hope this helps
Sep 20, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent 750GB ext HD - not recognized, bleeps fan noise
You generally can't repair the case unless you have another one of the same model for spare parts. Also if you open the case you will void any warranty the drive and case had.
If you are ok with those two points, you can simply buy an empty SATA drive enclosure and pop the free agent apart, place the HDD into the new enclosure and try it on your computer. If this works you're done. However if it doesn't and you require the files from the drive you will be stuck paying for data recovery. There are several more economical options, the one I like best is Armor-IT. Small company in Canada, they do charge a diag fee which a lot of companies don't do but their prices are pretty reasonable for most drives.
Hope this helps,
Chris
May 08, 2009 | Seagate 750GB FREEAGENT SATA/USB 2.0 750...
Cant format 400gb usb flash drive
So the disk is recognized? And there is a valid partition on the disk?
What is the error you are getting?
Have a look at this external hard disk troubleshooting, maybe it helps you along.
Jules
Apr 21, 2009 | Seagate Maxtor 750GB One Touch 4 Plus...
Ihave purchased a SeagateFreeagent 500 gb USB external HDD.It was working very well till I tried to create partitions by using Paragan Disk Management software. In the middle of formatting the partition...
After plugging ur HDD, verify the device is detected or not in Device manager and Try Partitioning Again GUI mode (means in XP).. or follow the steps..
1- Go to Computer Management, Click Disk Management
2 - You will find you External HDD in the Right side
3 - Just Right Click the Drive, if it asks Initialize HDD, just Initialize and Create Partition as u like.
Have Fun
- Rajkumar
Mar 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
430 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
