Question about Kohler CH25 PA-CH730-0040 Command Gasoline Engine
Kohler k321as engine- misfiring.
Engine runs erratic at times, has top end load up- runs rich, backfires at times. Could you tell me the point gap setting/ or any other useful hints. Kohler K321AS 14hp, cast iron line, SPEC# 603224/ SER#9296564. Thanks ,mark K.
    Sergeant:
    Champion:
  • 226 Answers
Sometimes there is a adjustment screw that you can turn just like a car.CAREFUL NOT TO TURN TO MUCH.to burn lean or rich.also you might want to change the fuel and air filter's first,then try to adjust.
Posted on May 26, 2009
Back fires rich exhaust
Preventing Backfire on Motorcycle Exhausts ' DoItYourself ...
www.doityourself.com/.../5-tips-to-preventing-backfire-on-motorcycle-e...
When the engine on your motorcycle has an emission system malfunction, such as anexhaust leak or a moment of running rich or running lean, backfire can ...
Exhaust backfire, popping when letting off throttle - Motorcycle Forum
www.motorcycleforum.com > ... > General Motorcycle Discussion
Apr 26, 2009 - 28 posts - ‎17 authors
Exhaust backfire, popping when letting off throttle General Motorcycle Discussion. ...You can damage the engine by running too lean or rich. Backfires on deceleration
Jan 24, 2015
What causes a bike to back fire?
Jul 15, 2012
At my wits end! Backfiring and fouled plugs on ...
Feb 26, 2011
More results from www.motorcycleforum.com
Glad That You Asked. Why Do motorcycles Backfire? at Cyril ...
cyrilhuzeblog.com/.../glad-that-you-asked-why-do-motorcycles-backfire...
Jun 12, 2010 - A visible flame may momentarily shoot out of the exhaust pipe. ...Another backfire situation occurs when the engine is running rich, meaning ...
Is backfire when decelerating a bad thing? : motorcycles
Jan 31, 2016 | Motorcycles
Bike misfiring? Vibration not smoothing out when giving it gas, running rich.
Well to me it needs the plugs properly gapped or the motor jumped timing try the timing test and check your spark plug gapping
Mar 24, 2014 | Motorcycles
02 bmw 325i misfire cold start
plugs and wires. yes wires are the biggest issue with a misfiring engine. check the gap on the plugs. sometimes they are gapped to far and cause a cold misfire issue. simply pulling plugs and look at color of the insulator will tell the condition of the engine. normal should be a golden tan color darker means its to rich or burns oil white ask means to hot and should use a colder plug
Dec 02, 2013 | 2001 Dodge Neon
Have a farmall super m need gap measurement on the points
The point gap should be 0.013 inches. You should also check the end play and run out on the shaft before point installation (vertical & horizontal movement)- should be minimal or the engine will run erratic or not at all if too loose.
Aug 19, 2013 | Farmall Tractor A-i,av,super A ,super Av...
Tecumseh engine backfires and wont start
remove the top cover from the engine and then the nut on the top of the flywheel look down at the space between the shaft and flywheel the key between the two might have sheared happens more if you hit a rock
Apr 30, 2012 | Craftsman Garden
Is it harmfull to run with a PO105 oroblem
P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction,
Symptoms of a P0105 check engine light code may include:
  • Poor running engine
  • Engine runs rich
  • Engine won't idle
  • Engine backfires through tailpipe
  • Engine misfire under load or at idle
  • MIL (Malfunction Indicator Lamp) illumination
  • In some extreme cases there may be no symptoms other than MIL illumination, could be caused by:
    • MAP sensor vacuum hose disconnected or plugged
    • Bad MAP sensor
    • Bad TPS good-day !
Apr 07, 2012 | Jaguar XKR Cars & Trucks
HEVROLET BLAZER 2000 MISFIRING
Timing is off,problem with timing chain,also check fluids in ******,plus also if you have a distributer in your vehicle,if it is cracked,moisture getting in and ruining the points,-that is if your vehicle has a distributer! This will make a vehicle run rough as well.
You can have new plugs put in,but if your spark plug wires are cracked or worn,this will also creat misfire and backfiring.
Jan 25, 2012 | 2000 Chevrolet Blazer
Engine Performance problem 1997 Chevy S-10 4
According to my book, the first code is the brake control rough road sensor, and P0302 is a cyllinder #2 misfire. Check the gap on your plug, and make sure the plug wire is on all the way. Give the boot an extra good push. Backfiring or misfiring under load is always caused by poor ignition. You may also have a faulty plug or wire.
Oct 21, 2009 | 1997 Chevrolet S-10 Pickup
Trying to find free repair guide for 1984 honda ATC 200ES
points gap adjustment ,timing adjustment. carburaor set clean w/ synchronization,check for exhaust gasket leaks between cylinder head and head pipe.check valve tappet clearance adjustment.clean and oil, or replace air filter. need cylinder compression test to determine mechanical state of motor top-end
Feb 18, 2009 | 1974 Honda CB 200
Plugs
For a carbureted engine, backfires can be caused by the valve train timing being way out.
Set your timing properly first, and then move forward from there.
Blackened plugs definitely mean too rich a mixture, and maybe not enough spark to burn it all.
I've never seen a bad vacuum hose cause backfiring, but it will help very much to fix any vacuum leaks you can find.
Sep 12, 2008 | 2004 Pontiac GTO
Kohler CH25 PA-CH730-0040 Command Gasoline Engine Logo
1,417 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
Wayne McNeil
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
