Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Missing files after refresh
When I save something on USB it shows on the USB file window. But when I click on refresh they disappear.
  • 31 Answers
Give it some time to refresh. Maybe the computer is using most of tis resources and it takes some time to show the contents again. Also, check what type of view you have( under view= thumbnails, list, etc)
Some previews will take forever to show.
Posted on May 25, 2009
How do I recovery temporary files in Audacity ?
If you are on Windows you can get it to display hidden files (such as system files) With luck it might show up your missing files. Just type "show hidden files" in the help on Windows and follow the instructions.
Aug 09, 2014 | ION Audio TTUSB 10 Vinyl Recording USB...
Toshiba 1TB external hard drive does not show on menu
Open the file and cick save as. In the window that opens, select the external drive in the list.
or, right click the file and click copy. Open the external drive in my computer and click paste.
Mar 16, 2014 | Toshiba Computers & Internet
I can not save my pictures?
Dear Darlene
To save your photos, you should already have done the following:
You clicked on "Create New Slide Show". A new window appeared - it is called "Slide Show Creator - Select Photos". You clicked on "Add Photos". You looked for your photos on your computer, selected them and then clicked on "Open" to add them to the slide show. (I'm leaving out the parts on transition, soundtrack and duration, since they do not relate directly to your question.)
Now, click on the "Next" button at the bottom of this window. You are now at the window called "Slide Show Creator - Options". At the section called "Name Slide Show" type a name for the show. To save the photos: 1) click on the "Finish" button at the bottom of the window. The window disappears and you are now back at the Menu window (where you started). 2) Click on the word "File" at the top left of the window. Go to "Save Project" and click on it. A window called "Save As" appears. Type in the name you want to give to the project and click on "Save" at the bottom right. You have now saved the project (including photos) on the computer - it should be in your "My Documents" folder.
If you go and have a look in your "My Documents" folder, you will notice a file (or files) with a ".slw" extension. These kind of files contain information about the slide shows you've created. They form the individual parts - or chapters - of your project. They are only used by the SlideShow Expressions programme. You will also notice another kind of file, one that ends with a ".ssp" extension. It should contain the name of your project, because that's what they are: project files. It contains all the information that is needed for the programme to burn or view your project: the chapters, the photos, the soundtrack, etc. This is the file you will load when you've just opened SlideShow Expressions and want to continue making or editing your existing project(s). If both these kinds of files are there, "slw" and "pps", it is a good sign and means that your project (and therefore the photos contained in them) has probably been saved correctly.
I hope I understood your question correctly.
If you have a legitimate copy of the programme, there will be a User's Guide on the install disc. It is good to consult this when you have questions. Simply insert the install disc and once it activates a window on your screen, click on the relevant link (something like "User's Guide") to access the guide. You can also copy the User's Guide from the disc to your computer. This will be usefull if you're going to use the guide a lot. To copy it, insert the install disc and then go to "My Computer". Right-click on your ROM/Writer drive (it may display the name of the programme), and click on "Explore" to look for the User's Guide on the disc. It is a pdf file. You can copy it and then paste it somewhere on your computer for quick access.
If you still have questions, you may make use of the free online support: go to www.individualsoftware.com/support.
The best of luck to you.
Nov 05, 2012 | Individual SlideShow Expressions
Hello, I have a Nuvi205w...it was working fine this morning and now it is showing on the screen the following message...no detailed maps found that support routing. The nuvi cannot be used without them. Is...
The "No Detailed Maps Found That Support Routing" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
To get your unlock codes you must have registered your satnav. If you haven't already done so you can by connecting your satnav to your computer. Go to www.garmin.com Click on myGarmin and then on Register Your Garmin Product. You'll have to create a username and password to register. Note them down and keep them safe as you'll need them anytime you want to update maps.
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Creating an unlock code file for PC:
  1. Plug your Garmin device into the USB port
  2. Double-Click on My Computer or Computer located on the desktop
  3. Right-Click on the Garmin or nuvi drive
  4. Click Explore
  5. Double-Click on the Garmin folder
  6. Right-Click in a blank space in this window
  7. Move your mouse over the word New
  8. Select Text Document
  9. Press Enter / Return on your keyboard
  10. Double-Click on the New Text Document. This will open the New Text Document in a window called Notepad
  11. Type the unlock code that is listed in the Manage Maps section of your myGarmin account in all upper-case letters with no spaces
  12. Select File
  13. Select Save As
  14. Change the Save As Type to All Files
  15. Type gmapprom.unl in all lower-case letters for the File name
  16. Select Save
  17. Close the Notepad window
  18. Delete the New Text Document file
  19. Disconnect the GPS device from your computer
Creating an unlock code file for Mac:
  1. Open the TextEdit application located in the Applications folder on the Mac HD
  2. Click Format
  3. Select Make Plain Text
  4. Type in the unlock code that you retrieved from your mygarmin account. The unlock code should be in all capital letters and with no dashes.
  5. Click Save As and name the file as gmapprom.unl (Note: Be sure to uncheck the box If no extension is provided, use .txt)
  6. Copy the gmapprom.unl file to the GARMIN folder on your device. (Note: Save the file directly to the Garmin mass-storage device if connected)
If you have a second map on your satnav e.g. if USA is your main map and you purchased a map of Europe which you need to unlock also
  4. Click Explore
  11. Type the European unlock code that is listed in the Manage Maps section of your myGarmin account. This will need to be typed in all upper-case letters with no spaces
  12. Select File
  13. Select Save As
  15. Type gmapprom1.unl in all lower-case letters for the File name
  16. Select Save
Enabling maps on the GPS device:
  1. Touch the wrench icon on the Where to/View map screen
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
  5. Select the checkbox next to the maps to be enabled on the device
Aug 10, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
I am having the exact same problem listed above. I will copy it in case you can't read it for some reason: Drive is mounted on the desktop (Mac OS 10.4). There are no problems with it according to Disk...
for one the drive will not be mounted to the desk top , since it has no operating system installed on it , it will fall redundant to the C drive
in my computer , disappearing is the hard drive booting to the C drive
are you able to use this drive ? if you are I suggest emptying it and
reformatting the drive then fill it back again if the drive doesn't work
check all power cords , cables ect. give me more details to better help you wit this problem David terminalcon
Jan 11, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
All the pictures i had have disappeared and my memory card says no images! when i tried to get them processed it just kept counting up images to over a thousand..
Hi. The most probable cause for this problem is a virus. Your memory card might be infected and the virus might have hidden your files. You can check this by scanning the memory card using an updated antivirus, then unhiding all hidden files. To do this (after scanning the memory card), open Windows Explorer, go to "Tools >> Folder Options >> View" On the advanced settings, Hidden Files and Folders option, click the "Show hidden files and folders" button. Uncheck "Hide extensions for known file types". Click OK to save the settings.
Now go to your memory card via "My Computer" or Windows Explorer to view the files (images). You can unhide them so they may be accessible again.
Hope this helps.
Sep 01, 2009 | SanDisk 2GB microSD Memory Card
I have a Freecom 60GB hardrive. It used to back up only updated/new files but then I had trouble and re-formatted the drive and re-loaded the software from CD. It now seems to be re-saving all files when I...
In you software the file images are still there and its searching for it location automatically - refresh or delete the mirroe image of file name which are previous ones.
Jul 02, 2008 | Computers & Internet
Micro 8GB cruzer
Save all your files on your computer before doing this.
Uninstall U3 from settings on launchpad.
Format your USB. Do not Quick format.
Reinstall U3: http://www.sandisk.com/Retail/Default.aspx?CatID=1411 (only works with Sandisk)
Drag your files into the USB. No more problems!
If anymore problems, reply!
Hope this helps!
Nicholas CHUM
Apr 22, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
78 people viewed this question
Top Kingston Computers & Internet Experts
Cleverer2
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
