Question about Cen Racing Mitsubishi Pajero RADIO RC NITRO GAS-POWERED CAR
My 93 Pajero speedometer has stopped working
I went to check the cable to a garage but they did not the problem with my pajero speedometer so help me to solve this problem
  • 3 Answers
May need new or second hand speedo cable,or it could be the gearing that goes into the side of gear box at the tail end.More chance that is the cable ,check at the back of the gear box above the fuel filter you will see a little round plug with the cable attached to it ,unscrew this and make sure the wire and pin are connected as they are common for breaking leaving the pin to sit in the side of gear box with the cable not even connected.
Posted on Aug 01, 2010
How do i know if i need transmission oil for my pajero 2001
Probably more than you want to know, but here is the workshop manual on the transmission. I had a friend with a Pajero, and it had some kind of jangling bell if he went over 68 mph. Drove us mad going to the airport on a 325 mile trip.
http://www.pjchris.myqth.com/Pajero/23.pdf
  • Pajero automatic transmission fluid and filter change ... www.youtube.com/watch?v=3maUkwGcFgo
    • BY ELBOON GABE
    • 3 MIN
    • 7.7K VIEWS
    2015-06-23 · fluid and filter change in my 2006 Pajero. ... (Transmission Fluid Change) 2001 Mitsubishi ... How to check automatic transmission oil ...
  • What Type of Transmission Fluid for Mitsubishi Pajero ...
  • cararac.com > Fluid for transmission > Mitsubishi Engine Oil for Mitsubishi Pajero; ... Recommended Type of Transmission Oil for Mitsubishi Pajero. ... 2001: Dexron VI. BMW 7045E.
  • Mar 04, 2016 | Cars & Trucks
    All my power went off as i was driving and even my speedometer went off and my steering became hard to work. when i stopped and turned the key off it would not turn over and now there is a very loud...
    Battery is drained, probably because of a bad alternator. Try jumpstarting it or use cables to try and get it started and take it to a garage.
    Jun 29, 2014 | 2004 MG TF 160
    Speedometer not working
    try clean the dirt from your speed sensor .with switch cleaner.
    Dec 11, 2013 | 1992 Mitsubishi Pajero
    No overdrive on a 2.8 pajero and then speedo stopped working
    In 2.8 Pajero the speedo receive electronic signal from the VSS sensor, but if the speedo for any reason stop working, O/D will stop work because the Trans ECU needs signal from the speedometer electronics to made the gear change into O/D
    Feb 13, 2012 | 1995 Mitsubishi Pajero 1.1
    Speedometer not working on 1990 camry
    check cable connections/ends sometimes moisture buildup forming small ice crystals caused non-function of speedometer on Honda solved by parking in heated garage overnight
    Jan 18, 2012 | 1990 Toyota Camry
    My speedometer is not working and my dash lights are very dim, and my car is starting very hard almost like the battery is dead.
    you are probably right ... have your battery checked at any full service auto parts store or garage.
    Oct 14, 2010 | 1995 Honda Civic
    Tach and speedometer both went out. Fuse is good. all other instruments are good. What could the problem be?
    Check the battery is fully charged and in good condition, a slightly low voltage or not enough current can mess up the cars computer and the first things to suffer are usually the tacho and speedometer, as it gets worse you get misfires and lights flashing on and off.. any garage should test your battery for next to nothing.
    Jan 26, 2010 | 1997 Volkswagen Cabrio
    Speedometor went out.
    The mechanic should check the if it is worn out or destroyed . if worn out or destroyed it should be replace. You have to check the speedometer cable if it is still connected if not reconnect the speedometer cable.Because of the speedometer cable is disconnected then the speedometer will run out or it will not work.But then if the cable is connected and it don't run then the speedometer is worn out or destroyed that's why you have to replace it or repair it.
    Sep 15, 2009 | 2000 Dodge Caravan
    Cen Racing Mitsubishi Pajero RADIO RC NITRO GAS-POWERED CAR Logo
    1,886 people viewed this question
    Top Cen Racing Toys Experts
    Andrew Taylor
    Andrew Taylor
    Are you a Cen Racing Toy Expert? Answer questions, earn points and help others
