Question about Vizio Gallevia GV42LF 42 in. LCD Television
Blue screen on fios screen that says no signal
No signal from fios on my vizio
4 Suggested Answers
  • 10 Answers
SOURCE: VIZIO LCD VX20L, intermittant video/audio with Blue screen message "No Signal"
If the tuner is bad, changing the mainboard should fix the problem.
Posted on May 23, 2009
SOURCE: vizio say's no signal tried auto search for
Fully check your antenna system... check your plug connection check you have plugged it in the right socket & there is a signal, try the antenna on another unit.
Posted on Feb 05, 2010
  • 8457 Answers
SOURCE: The LED vizio comes on the front of the
Tries unplug the tv and the cable or satalite boxes too.Replug it all back like an hour later.The tv know will reset itself back to the factory setting.The cables or satalites boxes it upgrading it softwares.The tv should have incomming broadcasting signal and work now.Not,call the cables or satalites compannies to replaced those inputs boxes first,have the same problems with those new input cables or satalites boxes.Than the tv,the Tuner signal board have problems and the cause.That the board,where the incomming broadcasting signal cable plug into it.That the tv Tuner signal board.Tries websites Shopjimmy.com,Ebay.com to buy a whloe refurbish Tuner signal board for the replacement.
Posted on Nov 07, 2010
Blue screen vizio vo371
Blue screen could be a bad main board or a no signal issue---do you get picture with DVD player connected?
Aug 29, 2012 | Vizio VO37LHDTV10A 37 in. LCD TV
Can't get full screen on Vizio VA19LHDTV10T
This is either due to some incompatibility or change of format of picture. Also the color system should be same like PAL/SECAM etc.
Aug 03, 2012 | Vizio VA19LHDTV10T 19 in. LCD TV
32in vizio tv problem. blue screen
You can if it has it connect to cable fitting and or the various av jacks on set---use original remote and switch inputs to make sure you are on the one you are hooked up to.
Mar 12, 2012 | Vizio Televison & Video
Vizio TV with Blue Screen says, "Aucun Signal!"
Guys aucun signal just means no signal in french
Mar 01, 2011 | Vizio L37 Television
No sound after I change the channel. If I turn the
There is an incompatibility between Fios and Vizio audio. To fix the problem, on the Fios box, press "Power" then "Select" then "Menu", one right after the other. This accesses a secret menu on the Fios box. Using the arrow keys on the front of your Fios box, arrow down to "Additional HDMI Settings" then press the right arrow. Another menu will appear (may take a few seconds). Arrow down to "Audio Out" and press the right arrow to change from "Auto" to "L-PCM". Press the Power button to exit the menu. This should solve your problem. Thanks to Vizio tech support for the answer.
Apr 29, 2010 | Vizio L37 Television
The tv had blue screen briefly showing "no signal" then turns off. ... and I am getting the same blue screen-no signal.
If your television is displaying a blue screen or no signal message and then turning off, your TV may be at an inactive input. Here's how you can get back to watching your TV:
1. Powering on your TV and press the INPUT button on the VIZIO remote control repeatedly until a picture re-appears.
2. If this does not work, try again but press the button slower this time.
I got this off the vizio website.
Feb 21, 2010 | Vizio GV42L 42 in. LCD Television
Hook up vizio tv to fios box
Run HDMI from FIOS to TV directly, then run Digital coaxial or optical to the cbl/sat audio input of your receiver. That's it. If you have any more questions, just post a comment and I can help more.
Aug 08, 2009 | Pioneer VSX-D509S Receiver
May 18, 2009 | Vizio VX20L 20 in. LCD TV
Vx37l stopped working with FiOS remote
I read in another forum where Vizio sometimes uses Vidtech codes. I got 0205 to work on my new Vizio V037L with my Verizon FiOS remote (Phillips RC144).
Oct 02, 2008 | Vizio VX37L Television
Vizio Gallevia GV42LF 42 in. LCD Television Logo
615 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
