Question about Logitech Z-4 Computer Speakers
Logitech Z4 sound from one side only
Couple of days ago my Logitech Z4 speakers started only having sound on the right.
I thought I got rid of the problem by unplugging and plugging it back into my comp, which worked for about a day or so until the left side decided to go mute again.
I unplugged and plugged it back in and now its working again.
Any ideas whats going on and how I can fix this once and for all without having to unplug and plug everyday?
    President:
  • 995 Answers
Reconnect all the wirings in your speaker set. Be sure you connect all the cords properly.
Posted on Nov 03, 2009
I have logitech Z4 speakers, and my speakers always just stop working, then when they're un plugged and re-plugged in they start to work again. This issue used to happen every couple of days, and
• One possible reason could be a faulty power supply for the amplifier.
• Transformer could be overheating or possibly the main amp itself.
here is a link , should you need to DIY
or just a guide and use it as a reference.
404_118x100.png Computer Speakers
let me know if you need more assistance.
Sep 11, 2012 | Logitech Z4 Computer Speakers
Sound comes out of the right speaker with the z4 volume set at minimum. however the sound can be controlled by the windows volume control. When you turn up the volume on the z4 the left speaker works....
open your subwoofer because main system is inside in your subwoofer than clean it with a air blower ..
this happens when dust is inside the system....
Dec 26, 2010 | Logitech Z4 Speakers
Crackling sound
The crackling could be due to a faulty wire or jack connection. If you have any other sound device (e.g. headphones), try connecting that one instead of the Z4 and see whether the crackling disappears (in which case it's the Z4) or not (in which case it's the jack or the computer). Could arguably be an EM or electrical interference, but you'd need a laptop running on batteries to check the second, and trying orienting differently the speakers to try checking the first.
The music slowing down means something's wrong in the computer: the Z4 are purely passive, they can't do anything to the music tempo. Try running an antivirus check or try Task Manager (or Process Explorer) and see whether anything's eating more CPU than it should.
Mar 28, 2010 | Logitech Z4 Speakers
Logitech webcam+ Z4 speakers - installation of application&device
Try setting the speakers as default on your computer first
Right click on the speaker icon in the system tray and open 'Playback Devices'
If you have 2 sets of speakers I would expect to see them displayed here with one set checked as default
Click on the set of speakers you want to set as default and Click 'Properties'
Click tab 'use this device enable' click 'Apply' and 'OK'
Open the sound tab again right click on the speaker icon and 'test'
All OK ?
Restart your computer and configure to the chat program
Jan 27, 2010 | Logitech QuickCam Pro 9000 Web Cam
How do you get the best sound out of logitech z4 speakers
If you have a newer model computer chances are you'd be getting the best sound quality now. If you want to improve the quality some look into sound cards at most tech retailers.
Jan 12, 2010 | Logitech Z4 Speakers
I have some logitech Z4 computer speakers
If your TV has a headphone socket, then plug the speakers into there, then (you have to do this for some TVs, but not others), go into the set-up menu and turn the headphone volume to 70%. Switch on the Z4 and sound should come out, assuming all connections are correct.
Jan 03, 2010 | Logitech Z-4 Computer Speakers
Logitech Z4 speakers not working at all. Checked all connections, computer registering them?... but when I plugged my mobile phone earphones in front jack there's still no sound?!
Please click on the Volume icon in the system tray and make sure that the speakers or other volumes are not muted. Windows has a habit of muting things on its own. And unless there is sound going to the speakers the headphone jack on the front of speakers will not function.
Dec 03, 2009 | Logitech Z4 Speakers
Logitech Z4 Speakers are both Dead.
The wires you put on are probably too small.  The gauge number is too high.  If the wires in the plug are okay, just get some light wire (like is on a table lamp) and use that.  It's similar to what they call monster cable but nowhere as expensive.   It's all about signal flow.
Jul 09, 2009 | Logitech Z4 Speakers
NO SOUND FROM MY RIGHT SPEAKER Z4
Open
Startmenu->control panel->sound and audio devices
Do you see a window which says "no audio devices installed" ?
  • If yes then its a driver problem, you need to install audio driver for your PC.
  • if no then, click on "Speaker volume button" below, then click "restore defaults" button.
This should fix the problem.
Otherwise I would suggest some more.
Jan 17, 2009 | Logitech Z-4 Computer Speakers
Logitech mm50 very little sound coming from right speaker
Check the cables and see if there is a tear, or unscrew the cover of the speaker (if possible) and see if the contact is frayed or only holding by a couple of wires. This will reduce the sound quality.
If not, the speakers are faulty, and they are not worth replacing. Just purchase a new set.
Dec 31, 2007 | Apple Logitech Inc MM50 Portable Speakers...
Logitech Z-4 Computer Speakers Logo
963 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
