Question about Goldstar GW-HD5000 Window Air Conditioner
AC tripping breaker.
Hello, My ac unit which is a Trane XR13 keeps tripping the breaker, it is less than 2 years old. The service tech says there is nothing wrong with it at all and he doesn't know why its tripping? Can anyone help?
  • 700 Answers
Check its wiring connection. Could be loose connection, corrosion.Or the breaker is already retiring. If the breaker is fairly rated to the aircon unit. Also insect could be the culprit.
Posted on May 25, 2009
Amana RCE24C2A trips circuit breaker
tripping the circuit means the unit is has a ground, "means some peeled wire inside is touching its metal case"
Jun 01, 2013 | Amana Heating & Cooling
We plugged in the sharp comfort touch model # AFR120BX It tripped the breaker. Now it wont turn on how can we reset the AC? Thank You
if unit trips breaker from second circuit unit has dead short possible bad compressor or controlls related problem. doesn't look good..... mike 20 year HVAC service tech
Jul 03, 2011 | Sharp Heating & Cooling
Trane XL 1600, The heat pump when running will dim the lights in the house and at night it will trip the breaker on the "small electric" line. The ac will trip the same breaker but only at...
the breaker may need replaced, I would start there first. I am assuming that it has a dedicated line (meaning only the heat pump is off that circuit), if not then it will need to be wired that way...Good Luck Tim
May 29, 2011 | Heating & Cooling
I have a TRANE XR12 central AC UNIT, when i turn my thermostat on i get a click sound and ac unit does not come on. i checked the circuit breaker to make sure it's on.i have not turned this ac on for a...
There is a time delay on the stat to the AC unit, in addition the AC unit likely has one also, so immediate activation as desired isnt likely, however in 10 minutes of asking for AC if its not on still Id check the time delay fuses in the service disconnect at the AC unit, its a small grey box with the power cords running to and from it, there is 2 time delay fuses inside this box.
Jan 12, 2011 | Heating & Cooling
Hi: I have a Carrier 38CMC42300 AC unit which will not turn on and the air handler is blowing hot air. The 40 amp breaker for the AC unit trips right away when reset. Could this be a condenser or motor...
Your compressor or the start components are bad...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 30, 2010 | Carrier 38CKC036 Air Conditioner
Breaker keeps tripping after several hours of runtime. System has 40 amp breaker & is only drawing 31 amps.
electric motors (when they start to break-down) will run normally for hours (and read amps within the tolerance level).
Then after a long run time - the amps will 'spike' and trip the breaker.
This is a fairly common occurance - although there are other things that can cause a similar problem (though less likely), i.e. a dirty condenser coil, an improperly charged unit - or a bad breaker.
Bottom line. I think you need a Service Tech to take a look at the AC.
hope this helps
Jun 06, 2010 | Haier HC48C1VAR Central Air Conditioner
One year old Danby dac8075ee, HAS NO POWER, what could be wrong ? please help
your air conditioner has no 'power' on it's own. It must get the power from an electrical outlet.
It is possible that the outlet you are plugged into is 'dead,' i.e. not working. One simple way to test this is to plug in another electrical appliance, hair dryer for example to test it and see if it's working.
If you do this and the other electrical device works then you know your AC is getting the 'power' it needs to operate - in which case you have a problem with your AC, and will probably need to call a Service Tech.
If, however, you plug in another device and it - too - does not work then you know the problem is within the outlet, probably a 'breaker' that is off or has tripped off. So, you need to locate the breaker - box.
This "breaker - box" (in most houses) will be located in the garage, utility room, or behind a door somewhere in the house, i.e. kitchen or bedroom.
If your outlet is not working - just go to the breaker box and open the door and look for a breaker (looks like a light switch) that is in the off position or perhaps half way off and half way on. Once you find this breaker - be sure your AC is plugged in and - just flip it (breaker switch) back in the "on" position.
Note: if the breaker switch trips right back off - then you know you have a direct short in your AC and probably will need the help of a Service Tech.
If this is the problem and the breaker stays in the on position and the AC runs and cools - you are probably ok, unless the breaker trips again in a short time span.
If that happens you most likely have a problem in the unit although it's possible the breaker is bad - in any event you are probably in the need of a Service Tech.
good luck!
May 05, 2010 | Danby DAC8003D Air Conditioner
When turning on central air, our main electrical breaker is tripping. This is a brand new home barely over 1 year old. Should the AC have a warranty not covered by a builders contract??
Builders give a one year warranty but your air conditioner has five years on all parts. Anything outside the unit is not covered under the ac warranty. Breakers,stopped up drain and dirty coils.
Jun 09, 2009 | Weather King 10AJA6001AH Air Conditioner
Compressor is showing ground fault
Things happen, how old was the compressor that failed?
May 01, 2008 | Ruud UPMC036 Air Conditioner
My ac circuit breaker keep tripping
If your outside condenser has a locked rotor or short circuit, than the unit WILL trip the breaker - as it should. On the other hand if a breaker is tripped a few times it will have less of a capacity that the rating, (this is designed in it). You will need to determine if the unit is locked (and broken) or the breaker has become too sensitive.
Apr 20, 2008 | Heating & Cooling
Heating & Cooling Logo
731 people viewed this question
Top Goldstar Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
