Question about LG 32LG30 32 in. LCD HDTV
Vibrates when shound turned up, tried different sound modes, it is the bass that is a problem deep voices etc
The tv vibrates when the sound is high, which is most of the time as hubby bit deaf, how can I fix this, tried having in different sound modes.
  • 1 more comment
  • sueflngn May 28, 2009
    The speakers are part of the TV ! Thanks anyway.
    Thank you so much, yes pictures would be very useful, sorry I am such a numb skull.....
  • sueflngn May 30, 2009
    Many Thanks for the pictures, will have to give it a go....wish me luck..
  • 187 Answers
Rattling speakers on a LG TV is fixed by placing a small square rubber between the speakers and the chassis.
Of course the speakers will need to be replaced too
Posted on May 27, 2009
  • 1 more comment
  • Carlos Figueroa May 28, 2009
    Of course the speakers are part of the TV, in order to fix it you have to remove the back cover, replace the speakers and attach the small rubber between the main chassis and the speakers (all is done inside the TV). I can send you a before-after pic if you need it.
  • Carlos Figueroa May 29, 2009
    There you go
  • Roger Calcutt Jan 20, 2012
    Take off back panel and fit rubber blocks to inside evenly spaced. Now screw back panel back on, squeezing rubber blocks against back panel. It works fine on my
    LG 47" 3D TV. It is nothing to do with the speakers it is vibration from the loose steel back panel!
I have an LG 47" 3D TV had same problem with noise on low voices.
Take off back panel and fit soft rubber blocks to inside - evenly spaced, then screw back back panel which will now squeeze against rubber blocks as you screw it back on. It is the back panel that rattles on speech not the speakers!
Mine is fine now :-)
Posted on Jan 20, 2012
Can't get balance, bass and treble to work when connecting Bose Acoustimass 5II to HK AVR 525
On my yamaha 375 receiver if I connect digital or hdmi it disables the balance/bass treble etc but they work with anolog don't know if yours might be the same just abit strang if anolog doing it aswell
Jan 15, 2014 | Harmon Kardon Harman Kardon Avr 525 7.1...
LG LK53-TV cracling noise
One, it has to be under warranty if 2 months old....
What you may be doing is just driving the speakers (a lot of sets have tiny ones now) too hard with the bass set up===literally rattle them in their frames----if the set has a connection on rear for external speakers that might be a option.
Some of these sets (check the specs) have a very small audio output circuit under 5 watts and with volume up and bass up sound will be hard in deep bass situations....
Mar 29, 2012 | LG 32LC2D Television
I cant get my jl audio w6 10s to give off much bass with the jl audio 500/1 amp
here is a manual for your subwoofers: http://mobile.jlaudio.com/pdfs/8-12W6_BDS.pdf
use the wiring diagram for 1.5? (1.5ohm) with 2 speakers. the diagram for 3 speakers will not work, because it would bring the load down to 1 ohm, and the amp cannot go below 1.5 ohm.
to set up the amp:
under "preamp output section", on the "output mode" switch, select "amp filter"
to set up the levels: start with the amp gain pretty far down- with the input voltage on low for line level outputs from the deck, and on high for speaker outputs from the deck. now turn your cd deck as far up as it will go until it distorts, then turn the cd deck down to just where it stops distorting. now, you can start to turn up the gain on the amp.
on the filters, youll prolly want the cutoff filter around 100hz @ 24db slope. start with the infrasonic filters off, but, if you do get into them, try centering between 30 and 60hz on either, and, possibly dropping the cutoff filter to 80hz.
Jan 31, 2011 | Jl Audio 500/1 Car Audio Amplifier
I have a brand new LG 37" television. Picture quality is perfect but the in-built speakers vibrate heavily to a deep bass sound. I played "Close Encounters of the 3rd Kind" through the dvd player and in...
i also have this tv.same problem too.i bought two multimedia bose speakers for 100$. they are actually designed for a laptop but trust me....they are better than most so called surround sound speakers designed for tv's.these tv's are not known for their built in speakers.
Aug 17, 2010 | LG 37LG50 37 in. LCD HDTV
Audio hum or vibration
spkr problem you can replace that for a new one.
Apr 05, 2010 | LG 42LG50 42 in. LCD HDTV
The text message sound alerts on my Glyde phone arent working
Nokia phones call them "profiles" , a set of preset modes where you can have different volume levels and tones for different occasions i.e General, meeting, loud, silent etc. I was suggesting trying a different preset mode If available to see if it worked for you.
Jan 14, 2010 | Samsung Glyde SCH-u940 Cellular Phone
Poor sound/ Unable to play anything load without distortion.
i can tell you right now base on the vehicle you have a bad system hook wosrt if you are using factory head unit
Mar 25, 2009 | Kenwood KAC-8151D Car Audio Amplifier
LG flat screen TV speakers make a vibrating noise
I have this problem with my 37LG30.
They all seem to have the same factory flaw.
The plastic bezel and rear is vibrating against itself I have found.
Tonight, just now, I just took all the front bezel screws out,(from the back) loosened the other 4 big screws in the rear center(I don't recommend removing them)and loosened the stand screws also and tried separating the bezel from the back as I went around the set. This did not really help much except around the bottom where the noise/vibrating comes from-the speaker area.
The two plastic pieces are vibrating against one another.
The vibrating was coming from the speaker area without doubt.
The next thing was to try separating at the bottom where the speakers are with my fingers and a stiff metal nail file carefully..fingers seemed to work best for me.
As I separated the front bezel from the rear housing (at the speaker location)most if not all the buzzing/vibrating /distortion went away.
I then inserted small pieces of cotton (you can use felt, or similar I suppose) and buttoned it all back up;put the screws in
Almost all the distortion and speaker buzz/vibratingis gone except on very low frequencies.
good luck!
Jan 29, 2009 | LG 42LC2D 42 in. LCD HDTV
Just bought a new car. i removed old stereo and put in my kenwood kdc-w808. whenever there is base in a song it distorts i have to turn my base rite down to get rid of it. worked perfectly well in my old...
your speakers probably cant handle the bass.,also they are probably full range speakers ,so hwen the base hits at the same time a voice is singing the woofer is vibrating to produce the basss,there fore distorting the highs and mids {or voice}.You need to add a seperate sub woofer.And puyt capicitossr on the full ranfge speakers to limit the bass..Rating please. :}
Jun 16, 2008 | Kenwood Car Audio & Video
TV makes high pitched noise
In 1080i the horizontal frequency more than doubles from 480i. This means that possibly the high voltage transformer or a linearity coil is occilating at that lower frequency.
Jan 26, 2007 | Samsung TXN3271HF 32" TV
LG 32LG30 32 in. LCD HDTV Logo
1,700 people viewed this question
Computer Repairing
Computer Repairing
